Maidened my 47" OMP Pro Yak....:)
WA
Hey guys, 1st flights on my Pro Yak were great! I have the Fusion and the Edge (OS 55 and Saito 82) and I have to say the Yak is amazing and definitely more maneuverable than the Edge. Of course the Edge is lots of fun with it's big fat wing, the way it just wants to hang there all day with that Saito pounding, and it's laughablly slow landing speeds.... but the Yak has really nice flying manners with it's thinner and tapered wing and it will go into crazy flat spins real easy like the Yak's in Realflight.
CG came out real neutral with the OS 55 mounted slightly back (about 1/2" clearance still between the backplate and back of the mount area) and the 5 cell AAA (that's triple A, not double) mounted in the rear of the wing area. Rolling it over inverted takes very little down pressure on the elevator to maintain. Fun plane!!!
Ernie
Ernie
WA
RE: Maidened my 47
Hi David, the Fusion tracks like an arrow but the Yak transitions into a 3D move much easier for some reason. For example it seems to me the rudder on the Fusion will get a big bite all of a sudden when you try to slow down and go into a flat spin and it will snap out kind of nasty at times whereas the Yak just seems to know what you want it to do if that makes any sense. You could fly all 3 if you were here! What are you flying these days?
Ernie
Ernie
RE: Maidened my 47
Hey Ernie that is fantastic! Glad the ProYak is treating you well.
The Fusion and ProYak are totally different animals. The Fusion designed for precision and 3D (freestyle flying) while the ProYak is pure funfly 3D twist your tail off flying. Gotta have both! I do!
My Feedback: (9)
RE: Maidened my 47
Ernie, my everyday flyer is a 67" Fusion with Saito 1.25 for power. I had to retire the 52" Fusion and was thinking about the ProYak as a home for all the gear from it. I also like the looks of the new AeroWorks profiles. They just aren't any out to get a flight report on one. Since I have had such good luck with OMP, I think I will get something from them.
david
david
WA
RE: Maidened my 47
I just saw the ad for the new Aeroworks profile jobs too. Looks like they have a bit of a SFG on the tips. You will definitely want a Pro Yak, or both!
Dave, do you have a favorite way to enter a knife edge spin? Please PM me if'n you do..... thanks,
Ernie
Ernie
My Feedback: (9)
RE: Maidened my 47
Ernie, I PM'd this to you but thought I would post it in case anyone else wanted to know. david
Ernie, I can't say I have a favorite way because every plane I have likes something different. On the Fusion for example, I just use the inputs for a flat spin( full left aile,1/2 down elev,full right rudder, & half power) then after a few spins I bring the aile back toward the center, increase power and elev and take about 75% of the rudder out of it. The Fusion however is a different animal than most. It is so much stronger on the elev it takes some finesse. Another example: I still fly my GB Ult some. On it, I go on an up line and cut the power like I was doing a hammer head or stall turn. Halfway through the stall turn when the fuse in parallel to the ground, I hammer the power, go full down and let off the rudder.
david
david
TX
RE: Maidened my 47
As far as the OMP yak goes it was a great flying little plane, it has 1 design flaw in my opinion and thats the double wing tube. There are no stops in either wing to keep the carbon fiber tubes from sliding. On the planes last flight I was doing a low throttle flat spin when I leveled it out, everyone heard a very loud pop as the wings broke loose..
All the hardware survived, so the next day I ordered the Aero Works 40 size profile..
