electric profile
electric profile
HI I finished this the other week,I scratch built it ,the wing span is 916mm and the weight with no lipo is 500grams ,im running a park 480 1020kv outrunner and 12x6 prop with hitec hs 65 servos,and a spektrum 6110e reciever,I used white covering for the top of the plane cause in the past i had a few problems with orientation of the plane so this should fix any unwanted crashes from not knowing which way is up, and i used see thru red for the bottom of the plane ,so if i crash i can see whats broken.I test flew it early in the morning when there was know wind ,the plane is very easy to hover and harrier both upright and inverted,and did pretty cool looking flatspins which is 1 of my favourite tricks and cause i build the planes with a tall fuse knife edges are so easy and slow.the lipo i am running is a 2200mah 3s and run time is about 10 minutes.check out more scratch built profiles sickbats blog.
Thanks Fella,s ,id like to build and sell planes for a job but ,that's the sought of job you don't mind going to.
