Rudder rehingeing
CA
Rudder rehingeing
Hi Gang,
I plopped my plane down on the tail today and ripped out a CA hinge. Can I just use my slot machine to cut a new slot in the same spot as the old ones? Any suggestions gratefully accepted.
Mum
Mum
RE: Rudder rehingeing
Yes, I have cut a new slot along the old hinge (with a knife not the hing machine) And folded the new hinge and slid it into place and CA'ed it in. No issues...
Conventional wisdom says that if you put a new CA hinge in place of an old one, the CA will not soak into the wood because it is already CA'd. If you've pinned it and it seems strong, then you are probably fine. Just keep an eye on it.
Good luck
Good luck
My Feedback: (19)
The easiest way to remove broken CA hinges is with a "hot knife". The hot blade melts through the plastic hinge and cured CA without tearing up the wood around it. The slot is fairly clean and the new CA hinge is a snug fit, so the repair is as good as new.
My Feedback: (13)
NJ
ORIGINAL: Dave McDonald
The easiest way to remove broken CA hinges is with a ''hot knife''. The hot blade melts through the plastic hinge and cured CA without tearing up the wood around it. The slot is fairly clean and the new CA hinge is a snug fit, so the repair is as good as new.
Evan, did you have to fold the new hinge because the slot was now oversize and you wanted to double the hinge size or ?
I have a question about the hot knive. After one use, my first one (Tower Hobbies hot knive, uses #11 exacto blades) sort of froze up and it was really hard to get a new blade in or out. Is this typical after you use them?
thanks, GREAT idea about using a hot knive to open that slot up again!
Ernie
Ernie
ORIGINAL: Ernie Misner
Evan, did you have to fold the new hinge because the slot was now oversize and you wanted to double the hinge size or ?.....
Ernie
Ernie
The hot #11 blade works great!
J.
Ernie,
Sorry, been away for a while. I've flown all of them but never really owned the 25 or the 65. Right now i have an old 40 ARF and have been flying the Primo a lot! Great birds no matter the size!
J.
J.
