Go Back  RCU Forums > RC Airplanes > Pylon Universe - RC Pylon Racing
Reload this Page >
what engine should I put on my 57" p51 to make it a fast ?
Pylon Universe - RC Pylon Racing Discuss all your rc pylon racing here!
Old 06-08-2015, 09:38 PM
EBGFLIGHT
EBGFLIGHT's Avatar
I got ahold of a ys f 120 to use on an aerobatic plane and if I ever crash its going on my warbird racer.
Old 06-08-2015, 10:09 PM
airraptor
My Feedback: (66)
The 120 is a good engine
Old 06-09-2015, 10:14 AM
EBGFLIGHT
EBGFLIGHT's Avatar
Any tips on tuning this engine?
Old 06-11-2015, 04:15 PM
EBGFLIGHT
EBGFLIGHT's Avatar
Old 06-11-2015, 04:17 PM
EBGFLIGHT
EBGFLIGHT's Avatar
This engine unported with the OS-7b carb, which is almost twice the ID of the stock, and the tuned pipe, runs like a top. Screams like a banshee! I will get RPM's as soon as I get a proper 12x10 on it.
Old 06-11-2015, 04:18 PM
  #31
EBGFLIGHT
EBGFLIGHT's Avatar
https://mail.google.com/mail/u/1/?ui...&sz=w1542-h621
Old 06-11-2015, 04:19 PM
  #32
EBGFLIGHT
EBGFLIGHT's Avatar
Also starting a thread in nitro engines about my 75 build engine!
Old 06-19-2015, 09:16 PM
  #33
EBGFLIGHT
EBGFLIGHT's Avatar
The OS 8B carb is nearly twice the ID of the stock carb. I have fired it up with the pipe and it is really impressive, will know rpm's with a 12x10 next time I go to the field(too loud to run full rpm in my neighborhood, cranky neighbors).
Old 06-20-2015, 12:13 PM
  #34
EBGFLIGHT
EBGFLIGHT's Avatar
Airraptor, I tried to fire up my 120 engine today and cannot it to run at all. Just have a lot of fuel dripping out of the pipe, is that normal? What should I check to get it running?
Old 06-20-2015, 01:26 PM
  #35
airraptor
My Feedback: (66)
depends on how much but sounds like could be a bad plug or the regulator is sticking and not regulating the fuel. take glow plug out and then spin the engine over to clear it out. install the plug if good and try starting again
Old 06-20-2015, 02:47 PM
  #36
EBGFLIGHT
EBGFLIGHT's Avatar
I cleared the engine out of fuel, put in a new glow plug, got nothing still. Fuel just drips out of the pipe like it floods before it gets the chance to fire up. How do I rebuild the regulator?
Old 06-20-2015, 08:57 PM
  #37
EBGFLIGHT
EBGFLIGHT's Avatar
A good amount of fuel is coming out of the exhaust
Old 06-21-2015, 05:16 PM
  #38
airraptor
My Feedback: (66)
replace the plunger and Diaphram. Give YS parts a call at 775 267 9252. They can set you up with some new parts. It might just need to be cleaned though.
Old 06-27-2015, 10:00 AM
  #39
fujiman
My Feedback: (133)
my 2 cents. lite weight but strong airframe, large CID engine and one that can reach 15,000+ RPM, hi pitch prop & shorter dia., cleaned up parasite air drag (stuff hanging out in the wind). these are the formulas for speed!!!!!! the reno unlimited racers (full scale) have learned this over the years. a lite weight 51 will put a BIG heavy corsair or a sea fury with a huge r4800 rad. engine in the nose in the weeds. speed don't lie!!!!!!!! same rule applies to rc planes.
some yrs ago i put a ys.60 short stroke on a foam sure flite p-39 cobra (.40 sized). at first i had a rossi .40 w/pipe and it went like a striped ape. later i put the ys .60 w/open exh. (macs header) and omg the dang thing was scary fast. the cobra had clipped wings and horizon stab and modified vertical stab, no retracts but i used narrow slim wheels and wire legs. we put styro foam to the max. later (2yrs later) the flite switch failed at full throttle and it went in at low angle and about 100 plus mph (est) and i believe all the foam beads came de-bonded because it looked like snow upon impact!!!!!!!!
i now have an airborne, world models 57'' 51 with an os .61fx on it (yet to be finished).
the os .90's are built on a .60 block, ST .75 and the .90 are built on a .60 block, the evo .90, i believe, is also using a .60 blk size.
a guy at tammies hobbies put the os .90 on his and the wing failed and crashed. so i decided to go with the .61 os. but then again i'm not racing mine.
i believe jet engines also make a .60 - .90 speed engs. 4stks, although torky, are limited in rpm and larger CID 4stks are heavy for this .40 sized plane. smaller glow engs. can rev to over 15,000+ and are much liter and higher in horse power.
just remember the larger engines just won't reach the hi rpm needed to reach hi speed. hi tork = pulling power. hi horse power (hi-rpm) is what u need for hi speed. a smaller dia., hi-pitch prop will give u hi speed. there are dia./pitch = air speed charts to calculate air speed, so look into that and it will help u pick the correct eng. to use. HAVE FUN AND BE CAREFUL, REMEMBER ''SPEED KILLS'' (ha,ha)
Old 06-28-2015, 09:20 PM
  #40
airraptor
My Feedback: (66)
A YS 115WS is the way to go look at my Vendetta race plane with a 115WS in it? 184.5 mph two way average....
https://www.youtube.com/watch?v=cQ66l7nQOls
Old 06-29-2015, 08:49 AM
  #41
fujiman
My Feedback: (133)
HOLY MOWLY!!!!!!!!!! have to eat my words about 4stks. that 51 smoked it at 184mph. 60% nitro, wow, wonder if the YS is the super charged one.
Old 06-29-2015, 09:18 AM
  #42
airraptor
My Feedback: (66)
yes it is supercharged. All the YS four strokes are. The Piston is the supercharger the volume under the piston is reduce as much as possible and has a rear rotor to time it. The chamber and valve cover hold the pressurized fuel/;air mix till the valve opens. some are saying over 3.5 to 4 hp being made out of this engine but that is a just a guess.
