Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
AJ-2 Construction Revisited
Old 05-26-2012, 03:48 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AJ-2 Construction Revisited
On the second wing the hole overlapped the carbon fiber laminant. Don't cut the carbon as it provides strength at the wing center section.
I slid the 1/8" thick plywood plate under the carbon fiber and left it intact.
The wing center section is covered with several layers of fiberglass cloth. The carbon laminant will not be exposed.
ID:	1766102   Click image for larger version
sahartman21 is offline
Old 05-26-2012, 06:41 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Temporarily attach the wing with masking tape.
Locate the rear wing mounting holes
Remove the wing and use a hole drill as needed.
ID:	1766128   Click image for larger version
ID:	1766129   Click image for larger version
ID:	1766130   Click image for larger version
Old 05-27-2012, 10:27 AM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pieces of 3/4" diameter dowels are glued in place with an epoxy micro-balloon mix.
ID:	1766237   Click image for larger version
ID:	1766238   Click image for larger version
ID:	1766239   Click image for larger version
Old 05-27-2012, 10:29 AM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One inch square pieces of 1/4" thick plywood are glued in place with Shoe Goo.
ID:	1766241   Click image for larger version
ID:	1766242   Click image for larger version
Old 05-27-2012, 05:23 PM
D.E.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looks good,,,, two is better than one! and can be built almost as fast as one.
how are you getting your pics to load? I tried a couple of times but got error message both times.
DE
D.E. is offline
Old 05-27-2012, 06:40 PM
  #31
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I set the camera at low resulution.
When loading I have to load 1 picture at a time.
Scott
Old 05-27-2012, 07:07 PM
  #32
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some pictures of servo tray installation.
ID:	1766490   Click image for larger version
ID:	1766491   Click image for larger version
ID:	1766492   Click image for larger version
ID:	1766493   Click image for larger version
ID:	1766494   Click image for larger version
ID:	1766495   Click image for larger version
ID:	1766496   Click image for larger version
Old 05-28-2012, 03:58 PM
  #33
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some pictures of the wing tip installation:
ID:	1766792   Click image for larger version
ID:	1766793   Click image for larger version
ID:	1766794   Click image for larger version
ID:	1766795   Click image for larger version
ID:	1766796   Click image for larger version
ID:	1766797   Click image for larger version
Old 05-28-2012, 04:02 PM
  #34
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A piece of window sheer is tacked in place using 3M77. This plus the fiberglass cloth makes the aileron hinge.
ID:	1766799   Click image for larger version
Old 05-28-2012, 04:05 PM
  #35
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some 2 ounce fiberglass cloth was used instead of 3/4 ounce cloth.
Three more layers of fiberglass cloth were tacked in place at the wing center section. The widths were approximately 11", 9", and 7 ".
Approximately 1.5 ounces of finishing epoxy was used on each side of the wing or a total of 3 ounces of finishing epoxy.
The wing was then placed between layers of peel ply (nylon fabric) and placed in a vacuum bag. The finishing epoxy needs to dry approximately 8 to 12 hours before attempting to remove the wing from the peel ply.
ID:	1766801   Click image for larger version
ID:	1766802   Click image for larger version
ID:	1766803   Click image for larger version
ID:	1766804   Click image for larger version
ID:	1766805   Click image for larger version
Old 05-31-2012, 06:03 PM
  #36
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing was removed from the peel ply and it was cleaned up a little.
I use a sanding block to trim the excess fiberglass from the trailing and leading edges.
Lightweight Spackle is spread on with a squeegee to fill up the pores and low areas.
ID:	1767691   Click image for larger version
ID:	1767692   Click image for larger version
Old 06-03-2012, 04:14 PM
  #37
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some pictures of adding the aileron torque rods and making the skinned hinges.
ID:	1768681   Click image for larger version
ID:	1768682   Click image for larger version
ID:	1768683   Click image for larger version
ID:	1768684   Click image for larger version
ID:	1768685   Click image for larger version
ID:	1768686   Click image for larger version
ID:	1768687   Click image for larger version
ID:	1768689   Click image for larger version
ID:	1768690   Click image for larger version
Old 06-03-2012, 04:18 PM
  #38
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing is still light at this point. It weighs about 15.55 ounces.
ID:	1768693   Click image for larger version
Old 06-05-2012, 06:33 PM
  #39
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The aileron servo is installed in the following pictures.
This method avoids cutting a big hole in the top of the wing that can reduce wing strength.
ID:	1769614   Click image for larger version
ID:	1769615   Click image for larger version
ID:	1769616   Click image for larger version
Old 06-11-2012, 05:39 AM
  #40
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing and landing gear are installed in the following pictures:
ID:	1771104   Click image for larger version
ID:	1771105   Click image for larger version
ID:	1771106   Click image for larger version
ID:	1771107   Click image for larger version
ID:	1771108   Click image for larger version
ID:	1771109   Click image for larger version
ID:	1771110   Click image for larger version
Old 06-11-2012, 10:11 AM
  #41
PylonDave
PylonDave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do you tape the belly pan on or is it glued??
PylonDave is offline
Old 06-11-2012, 10:41 AM
  #42
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
At this point the belly pan is just stuck in place with tape.
You can build it like you want it. If you glue it on, then there needs to be a split to allow for the landing gear.
Old 06-11-2012, 10:53 AM
  #43
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The horizontal tail surfaces are shaped in the following pictures:
ID:	1771169   Click image for larger version
ID:	1771170   Click image for larger version
ID:	1771171   Click image for larger version
Old 06-11-2012, 10:57 AM
  #44
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A layer of window sheer is tacked in place on the top surface.
Additional pieces of 2 ounce fiberglass cloth is applied over both the top and bottom surface.
Finishing epoxy is squeegeed over the surface.
ID:	1771173   Click image for larger version
ID:	1771174   Click image for larger version
ID:	1771175   Click image for larger version
ID:	1771176   Click image for larger version
Old 06-11-2012, 10:59 AM
  #45
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The tail surfaces are placed between layers of peel ply and placed in the vacuum bag.
The bag consists of 4 mil plastic sealed with latex caulking.
ID:	1771178   Click image for larger version
ID:	1771179   Click image for larger version
ID:	1771180   Click image for larger version
Old 06-11-2012, 01:18 PM
  #46
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The tail surfaces were removed and cleaned up with a sanding block.
Lightly sand the surface with 220 grit sandpaper on a sanding block.
ID:	1771234   Click image for larger version
ID:	1771235   Click image for larger version
Old 06-16-2012, 02:26 PM
  #47
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some planning was done on routing of the flexible cable.
Use a nylon connector with the metal control horn. This prevents the hole in the control horn from gradually wearing and getting too big.
ID:	1772645   Click image for larger version
ID:	1772646   Click image for larger version
Old 06-16-2012, 02:28 PM
  #48
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A slot is cut with an exacto blade.
This is followed with a cut off wheel.
ID:	1772648   Click image for larger version
Old 06-16-2012, 02:31 PM
  #49
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A large control horn is made from 3/32" wire, wheel collars, and sheet metal.
Parts are soldered together with silver solder.
ID:	1772650   Click image for larger version
ID:	1772651   Click image for larger version
ID:	1772652   Click image for larger version
ID:	1772653   Click image for larger version
ID:	1772654   Click image for larger version
ID:	1772655   Click image for larger version
Old 06-16-2012, 02:34 PM
  #50
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The control horn is tacked in place with CA glue.
A mixture of finishing epoxy and micro-balloons is applied in the gap.
ID:	1772657   Click image for larger version
ID:	1772658   Click image for larger version
ID:	1772659   Click image for larger version
ID:	1772660   Click image for larger version
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
