Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
AJ-2 Construction Revisited
Reply
Old 06-16-2012, 04:35 PM
  #51
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AJ-2 Construction Revisited
In a couple hours the finishing epoxy mix has hardened to the consistency of soap.
I use a razor to scrape the surface flush.
ID:	1772696   Click image for larger version
sahartman21 is offline
Old 06-16-2012, 04:39 PM
  #52
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you happen to cut too deep into the surface and damage the hinge, here is how to fix it.
1) Cut a piece of 2 ounce fiberglass cloth on the 45 degree angle.
2) Mix a small amount of finishing epoxy and apply it to the damaged surface.
3) Place the fiberglass cloth on.
4) Apply a piece of plastic wrap over the top of the patch.
5) Pull it tight and tape it in place.
ID:	1772700   Click image for larger version
ID:	1772701   Click image for larger version
ID:	1772702   Click image for larger version
ID:	1772703   Click image for larger version
Old 06-17-2012, 04:12 PM
  #53
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Next is planning and installing the elevator flex cable.
ID:	1773120   Click image for larger version
ID:	1773121   Click image for larger version
ID:	1773122   Click image for larger version
Old 06-17-2012, 04:14 PM
  #54
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Test fit the tail surface with screws prior to gluing on the tail.
Double check the incidence of the wing and tail.
The tail surface was then glued on with 30-minute epoxy. The tail was upside down to allow the glue to flow into the glue joint,
ID:	1773124   Click image for larger version
ID:	1773125   Click image for larger version
Old 06-17-2012, 04:20 PM
  #55
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The flexible cable was glued in place with Shoe Goo. This is vibration resistant and does a good job of holding parts in place.
ID:	1773127   Click image for larger version
ID:	1773128   Click image for larger version
Old 06-17-2012, 04:22 PM
  #56
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The model is getting close now. Just a few more steps and then it is ready for painting.
ID:	1773130   Click image for larger version
Old 06-24-2012, 12:17 PM
  #57
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A balsa wood post was glued in place with epoxy.
ID:	1775297   Click image for larger version
Old 06-24-2012, 12:20 PM
  #58
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I initially tried the fiberglass rudder but found it was a little thin. I chose to cut one out of 3/8" thick balsa.
ID:	1775303   Click image for larger version
ID:	1775304   Click image for larger version
ID:	1775305   Click image for larger version
ID:	1775306   Click image for larger version
ID:	1775307   Click image for larger version
ID:	1775308   Click image for larger version
ID:	1775309   Click image for larger version
Old 06-27-2012, 05:35 PM
  #59
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I piece of 3/8" diameter dowel rod was installed in the rudder.
ID:	1776415   Click image for larger version
ID:	1776416   Click image for larger version
Old 06-27-2012, 05:37 PM
  #60
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The rudder is being covered with 2 ounce fiberglass cloth and finishing epoxy.
This is later placed between layers of peel ply and placed in the vacuum bag.
ID:	1776418   Click image for larger version
ID:	1776419   Click image for larger version
ID:	1776420   Click image for larger version
Old 06-29-2012, 07:21 PM
  #61
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following pictures show how to make the cowl.
Scissors and a Dremel tool were used to shape the surface.
ID:	1776966   Click image for larger version
ID:	1776967   Click image for larger version
ID:	1776968   Click image for larger version
ID:	1776969   Click image for larger version
ID:	1776970   Click image for larger version
Old 06-30-2012, 07:03 AM
  #62
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The model is now ready to seal, prime, and paint. Here are a few pictures prior to painting:
ID:	1777120   Click image for larger version
ID:	1777121   Click image for larger version
ID:	1777122   Click image for larger version
ID:	1777123   Click image for larger version
ID:	1777124   Click image for larger version
ID:	1777125   Click image for larger version
ID:	1777126   Click image for larger version
ID:	1777128   Click image for larger version
Old 06-30-2012, 03:37 PM
  #63
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I began by washing the fiberglass parts with shampoo and water to remove any release agent. It was allowed to dry.
The fuselage was then lightly sanded going down to 220 grit paper.
Larger holes were then filled with polyester filler (Bondo). This stuff dries in a few minutes. Sand it smooth and then go down to 220 grit sandpaper.
ID:	1777265   Click image for larger version
ID:	1777266   Click image for larger version
ID:	1777267   Click image for larger version
Old 06-30-2012, 05:47 PM
  #64
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I then applied lightweight Spackle to the surface with a squeegee. This fills the pinholes.
ID:	1777285   Click image for larger version
ID:	1777286   Click image for larger version
ID:	1777287   Click image for larger version
Old 07-01-2012, 03:17 PM
  #65
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sand the surface with 220 grit sandpaper to remove the majority of the lightweight Spackle.
The goal is to leave the surface smooth and ready to prime. The Spackle does an excellent job of filling the pinholes.
ID:	1777597   Click image for larger version
ID:	1777598   Click image for larger version
Old 07-03-2012, 07:52 PM
  #66
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used white Klasskote epoxy primer on the models.
Approximately 4* ounces of primer was mixed per model. *Note: If done again I'd suggest 5 to 6 ounces per model.
The primer was thinned with 1 part thinner per part of primer. The Klean-Strip Lacquer Thinner worked fine to thin the primer.
ID:	1778381   Click image for larger version
ID:	1778382   Click image for larger version
ID:	1778383   Click image for larger version
ID:	1778384   Click image for larger version
Old 07-04-2012, 08:14 AM
  #67
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lightly wet sand the primed surface of the model.
Use a sanding block on flat surfaces and a loose sheet of wet-and-dry sandpaper on other surfaces. I used 400 grit wet-and-dry sandpaper.
ID:	1778483   Click image for larger version
ID:	1778484   Click image for larger version
ID:	1778485   Click image for larger version
ID:	1778486   Click image for larger version
Old 07-04-2012, 08:20 AM
  #68
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is what the model looked like after wet sanding.
I am planning to paint the model yellow. Yellow tends to be transparent and therefore the surface must be perfectly white with no grain or imperfections, or they will show up after painting.
I took the opportunity to fill a few more pinholes. Another coat of primer will be applied.
ID:	1778488   Click image for larger version
Old 07-06-2012, 10:08 AM
  #69
diggs_74
diggs_74's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks great Scott.. Can't wait to hear how it flies..
diggs_74 is offline
Old 07-08-2012, 05:47 AM
  #70
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
An additional coat of primer was applied and later sanded (220 and 400 grit sandpaper).
ID:	1779823   Click image for larger version
ID:	1779824   Click image for larger version
Old 07-08-2012, 05:51 AM
  #71
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are my spray gun and materials used for the color coat. The spray gun is available from Harbor Freight for about $15.
I mixed about 5 ounces of paint (acrylic enamel and hardener) per model.
The final mix was about 3 parts paint and 1 part reducer.
ID:	1779826   Click image for larger version
Old 07-08-2012, 05:56 AM
  #72
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A light coat of paint was applied first and after a couple minutes the remaining coats were applied.
The model was initially white and the yellow covered it great.
FYI - I've tried painting yellow over darker colors and had less that perfect results. [&:]
ID:	1779828   Click image for larger version
ID:	1779829   Click image for larger version
Old 07-09-2012, 06:12 PM
  #73
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After about 24 hours you can wet sand the surface to remove dust, runs, etc.
2000 grit wet-and-dry sandpaper works fine for this service.
Old 07-13-2012, 06:00 PM
  #74
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wanted the model to be unique and very visible in the air.
What do you think?
The clear coat will go on tomorrow.
ID:	1781589   Click image for larger version
ID:	1781590   Click image for larger version
ID:	1781591   Click image for larger version
ID:	1781592   Click image for larger version
Old 07-13-2012, 06:48 PM
  #75
jeffk464
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey, the go fast sticker actually say fast.
jeffk464 is offline
