Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
AJ-2 Construction Revisited
Reply
Old 02-27-2013, 07:03 PM
  #101
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AJ-2 Construction Revisited
The AJ-2 was flow at the Basin race this past weekend.
sahartman21 is offline
Old 03-03-2013, 06:41 PM
  #102
PylonDave
PylonDave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And it flew Well!!!
Thanks for sharing it with me Scott !!
PylonDave is offline
Old 03-09-2013, 07:39 PM
  #103
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After a little break for some racing, I took this opportunity to install the firewall and motor mount in another fuselage.
I'd done this several times as this is now my fourth AJ-2. Each time is easier.
Just take your time and follow the following link:
http://www.rcuniverse.com/forum/fb.asp?m=11087898
ID:	1860131   Click image for larger version
ID:	1860132   Click image for larger version
Old 03-31-2013, 04:18 PM
  #104
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is the latest wing.
This one was removed from the vacuum bag, trimmed, and touched up a little with lightweight Spackle.
This is what is looks like after about 8 hours of construction.
Old 04-06-2013, 01:53 PM
  #105
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The aileron torque rods were installed and the wing was fitted to the fuselage.
I now double check (with incidence meters) to insure that the wing is straight.
Old 05-05-2013, 12:49 PM
  #106
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another race is around the corner so it is time to finish this model.
Temporarily attach the tail surface with screws to align it up as needed.
ID:	1879394   Click image for larger version
Old 05-16-2013, 09:44 PM
  #107
PylonDave
PylonDave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Hartman!!! Your Sluffing off!! Finish this thing
Old 05-25-2013, 10:28 AM
  #108
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's how to seal the surface and get it ready for primer.
Wash the surface of the fiberglass with liquid soap and water. Dry the surface. lightly sand the surface of the model with 220 grit sandpaper used dry. Then dust the surface to remove any excess material.
Apply a layer of lightweight Spackle. I use a squeegee to apply the material in a thin smooth layer.
The fuselage had some larger holes that were filled with a polyester type filler. Let this dry and sand smooth.
Lightweight Spackle was applied to remaining surfaces.
Allow the surface to dry for a couple hours and then sand the surface smooth with 220 grit sandpaper used dry.
ID:	1885371   Click image for larger version
ID:	1885372   Click image for larger version
ID:	1885373   Click image for larger version
ID:	1885374   Click image for larger version
ID:	1885375   Click image for larger version
ID:	1885376   Click image for larger version
ID:	1885377   Click image for larger version
Old 05-25-2013, 05:39 PM
  #109
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The model was primed with white Klass Kote primer.
Approximately 8 ounces of primer was mixed, allowed to set for 20 minute, and an equal amount of thinner was added.
ID:	1885484   Click image for larger version
ID:	1885485   Click image for larger version
Old 05-26-2013, 12:30 PM
  #110
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Next is the fun part, wet sanding.
Take your time here as this is the step that determines what the color coat will look like.
Old 05-27-2013, 06:38 AM
  #111
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Acrylic Enamel was used to paint the model.
Mix in hardener per the directions and thin to your needs prior to spraying on.
An inexpensive spray gun from Harbor Freight was used.
ID:	1886074   Click image for larger version
ID:	1886075   Click image for larger version
Old 06-02-2013, 10:22 AM
  #112
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wet sanded the wing and tail surfaces and sprayed on another coat of red Acrylic Enamel paint.
The paint was allowed to dry thoroughly and then the surface was wet sanded again.
I used 2000 grit wet-and-dry sandpaper used wet.
Be careful or you may go through the color coat. I did and touched up the surface with a red marker.
ID:	1887938   Click image for larger version
ID:	1887939   Click image for larger version
ID:	1887940   Click image for larger version
Old 06-02-2013, 10:27 AM
  #113
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had Kevin send me a picture of the real AJ so that I could better duplicate the canopy outline.
Below is a link and picture:
http://cessnateur.blogspot.com/2011/...aj-2-n9aj.html
Old 06-02-2013, 11:45 AM
  #114
Stevem9
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Scott,
How many coats of the klass koat do you put on?
Stevem9 is offline
Old 06-02-2013, 11:52 AM
  #115
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Typically only 1 coat of primer (Klass Kote) is applied. You then lightly sand with 220 grit sandpaper as needed.
The goal is to end up with a perfectly sealed surface ready for paint.
Old 06-02-2013, 12:54 PM
  #116
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are a few pictures showing the trim pattern.
Double check the pattern by assembling the model prior to painting.
I've still got to mask off the remaining surfaces. Somehow paint seems to get anywhere it isn't masked off.
ID:	1887989   Click image for larger version
ID:	1887990   Click image for larger version
ID:	1887991   Click image for larger version
ID:	1887992   Click image for larger version
ID:	1887993   Click image for larger version
ID:	1887994   Click image for larger version
Old 06-02-2013, 06:13 PM
  #117
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The rest of exposed area was covered prior to spraying on the trim.
A very light mist of Krylon was sprayed on.
This was allowed to dry and several more light coats were applied until it covered.
After about 10 more minutes the paint was dry enough to removing the masking paper and stencils.
It's going to be a good looking model.
ID:	1888416   Click image for larger version
ID:	1888417   Click image for larger version
ID:	1888418   Click image for larger version
ID:	1888419   Click image for larger version
ID:	1888420   Click image for larger version
ID:	1888421   Click image for larger version
ID:	1888422   Click image for larger version
Old 06-03-2013, 06:41 PM
  #118
PylonDave
PylonDave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking Good Scott !! Should look Great after the Clear. Do you apply the clear untill it is glossy or does the wet sanding and buffing take care of that ???
Old 06-06-2013, 05:26 PM
  #119
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I try to spray enough clear coat that the rubbing and buffing will be minimal.
Wet sand the edges of the numbers and letters until they are smooth. Allow to dry.
Below are some pictures of the model getting a coat of clear coat.
Begin with a light mist first, let it dry about 10 minutes, and follow with more coats until there is gloss.
ID:	1889447   Click image for larger version
ID:	1889448   Click image for larger version
Old 06-07-2013, 05:27 PM
  #120
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wet sand the finish with 2000 grit wet-and-dry paper used wet. Sand slowly to remove the dust and minor imperfections.
Follow with buffing with cleaner and various waxes. The ones shown work well.
ID:	1889740   Click image for larger version
ID:	1889741   Click image for larger version
ID:	1889742   Click image for larger version
ID:	1889743   Click image for larger version
ID:	1889744   Click image for larger version
ID:	1889745   Click image for larger version
Old 06-23-2013, 11:27 AM
  #121
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following pictures shows the servo being installed in the wing:
ID:	1894403   Click image for larger version
ID:	1894404   Click image for larger version
ID:	1894405   Click image for larger version
ID:	1894406   Click image for larger version
ID:	1894407   Click image for larger version
ID:	1894408   Click image for larger version
ID:	1894409   Click image for larger version
ID:	1894411   Click image for larger version
ID:	1894412   Click image for larger version
ID:	1894413   Click image for larger version
Old 06-23-2013, 11:37 AM
  #122
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More radio installation:
ID:	1894415   Click image for larger version
ID:	1894416   Click image for larger version
ID:	1894417   Click image for larger version
ID:	1894418   Click image for larger version
ID:	1894419   Click image for larger version
ID:	1894420   Click image for larger version
ID:	1894421   Click image for larger version
ID:	1894423   Click image for larger version
ID:	1894424   Click image for larger version
ID:	1894425   Click image for larger version
Old 06-23-2013, 04:35 PM
  #123
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following pictures show engine installation:
ID:	1894507   Click image for larger version
ID:	1894508   Click image for larger version
ID:	1894509   Click image for larger version
ID:	1894510   Click image for larger version
ID:	1894511   Click image for larger version
ID:	1894512   Click image for larger version
Old 06-24-2013, 05:44 AM
  #124
PylonDave
PylonDave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice Tool !! Did you make that ?? You don't have to take the cowl off to tighten the collet nut.
Old 06-24-2013, 05:04 PM
  #125
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I copied the idea based upon AJ's tool.
A Dremel was used with cutoff disk to cut a grove in a hollow nut driver.
It works great!
