Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
AJ-2 Construction Revisited
Reply
Old 05-05-2012, 12:09 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default AJ-2 Construction Revisited
This thread will cover building a Kevin Matney's AJ-2 QM kit. The model flies great and is available at competitive pricing.
This is my second time for building this model.
The kit consists of:
1) Fiberglass fuselage
2) Wing cores
3) Tail cores
4) Landing gear
5) Plans
Here is a link to the site:
http://www.matneymodels.com/qm.html
ID:	1759129   Click image for larger version
ID:	1759130   Click image for larger version
ID:	1759131   Click image for larger version
sahartman21 is offline
Old 05-05-2012, 12:17 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AJ-2 Construction Revisited
Begin by making wing skins from 1/16" thick balsa sheets.
Use lightweight balsa for the bottom skins. The top skins should be made from medium weight balsa wood.
There is no need to glue the skins together. Just tape them together at this point.
ID:	1759138   Click image for larger version
ID:	1759139   Click image for larger version
ID:	1759140   Click image for larger version
ID:	1759141   Click image for larger version
ID:	1759142   Click image for larger version
Old 05-05-2012, 12:20 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The tail skins are made similarly.
The skins should be about 17" wide as the tail is glued together as one piece.
ID:	1759144   Click image for larger version
Old 05-05-2012, 07:14 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This wing is sheeted in one process.
The first step is to make a one piece wing skin. This is done by joining sections together with masking tape. The tape between the top and bottom cores makes a hinge.
Next is the addition of carbon fiber on the bottom skin. I tack it in place with 3M77.
Tack pieces of 5" wide fiberglass cloth at the joint between the top and bottom trailing edges. For the time being it will be a hinge between the top and bottom sheets.
A layer of 3/4 ounce fiberglass cloth is placed over the sheeting. The fiberglass cloth makes it easier to get just the right amount of finishing epoxy on the skins. It also adds some strength.
ID:	1759290   Click image for larger version
ID:	1759291   Click image for larger version
ID:	1759292   Click image for larger version
Old 05-05-2012, 07:18 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing cores and shucks are joined with 3M77 adhesive and masking tape.
Waxed paper is also tacked in place on the shucks to prevent the wing from sticking to the shucks.
ID:	1759300   Click image for larger version
Old 05-05-2012, 07:22 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mix about 1 ounce of finishing epoxy per wing half. About 0.1 ounce of 91% rubbing alcohol was added to thin out the epoxy. This was spread over the wing sheeting with a plastic squeegee.
The other wing half is done the same way.
Old 05-05-2012, 07:26 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cut the slot for the vertical sheer of carbon fiber. This acts like a spar and adds significant strength to the wing. Don't leave it out.
Mix about 0.4 ounce of finishing epoxy and spread it into place using an epoxy brush. Add the carbon fiber making sure there is a good glue joint.
Old 05-05-2012, 07:34 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing cores were slid between the wing sheeting. This was then placed between the shucks.
Verify the parts are straight by reviewing the markings on the sides of the cores. Kevin added marks so you can tell the wing is straight.
Temporarily pin the parts together and then tape parts together with masking tape. The pins should be removed prior to adding the parts to the vacuum bag. You don't need holes.
ID:	1759314   Click image for larger version
ID:	1759315   Click image for larger version
ID:	1759316   Click image for larger version
Old 05-05-2012, 07:39 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The bag is made from 4 mil thick plastic tarp and is sealed with latex caulking. A piece of rope goes around the perimeter of the wing and allows a channel for the vacuum to flow.
About 6" of Hg vacuum is applied and parts are allowed to dry overnight.
ID:	1759320   Click image for larger version
Old 05-06-2012, 12:30 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Trim off the outside of bag to remove parts. That way you don't have to mess with the caulking.
The leading and trailing edges are trimmed flush to the shucks.
Remove the tape and lightly sand the edges.
ID:	1759582   Click image for larger version
ID:	1759583   Click image for larger version
ID:	1759584   Click image for larger version
Old 05-06-2012, 12:34 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I glued the leading edge on with 6-minute epoxy. Draw a line down the center of the leading edge and then shape as desired.
The trailing edge was shaped with a sanding block. Sand down to a sharp trailing edge. The fiberglass cloth makes a nice thin edge.
ID:	1759586   Click image for larger version
ID:	1759587   Click image for larger version
ID:	1759588   Click image for larger version
ID:	1759589   Click image for larger version
ID:	1759590   Click image for larger version
Old 05-13-2012, 02:42 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The tail surface is a skinned foam core.
The balsa sheets should be about 1/4" wider than the shucks.
A piece of 0.021" thick carbon fiber is used at the joint.
Finishing epoxy is squeegeed on the balsa sheeting.
Lay the cores on the sheeting. Mix some micro-balloons and finishing epoxy. Apply the mix on the edges and carbon fiber.
Lay the top sheeting on and tape the sheets together.
ID:	1762361   Click image for larger version
ID:	1762362   Click image for larger version
ID:	1762363   Click image for larger version
Old 05-13-2012, 03:12 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The tail surface was placed between layers of peel ply (nylon fabric) and placed in the vacuum bag.
I'm building two AJ-2 models at this time.
ID:	1762372   Click image for larger version
ID:	1762373   Click image for larger version
Old 05-13-2012, 04:03 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After a couple hours the tail surfaces were removed from the vacuum bag and peel ply.
Here is what one looks like after cleaning it up a little. It weighs about 1.25 ounces.
I'm going to allow it to dry further before shaping.
Old 05-18-2012, 08:04 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
While you guys were dreaming of your next race a new wing was being born.
This one is similar to the earlier post except it uses carbon tow for reinforcement on the bottom.
Good luck MOKAN!
Old 05-19-2012, 11:36 AM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This morning the leading edge (1/4" x 3/8 balsa) was glued and shaped (with knife and sanding block).
What's better than one AJ-2? Two of course! [8D]
Old 05-20-2012, 01:01 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I installed the firewall (3/8" thick aircraft plywood) and engine.
The pictures show the sequence of events.
ID:	1764242   Click image for larger version
ID:	1764243   Click image for larger version
ID:	1764244   Click image for larger version
Old 05-20-2012, 01:08 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More firewall installation pictures:
ID:	1764253   Click image for larger version
ID:	1764254   Click image for larger version
ID:	1764255   Click image for larger version
ID:	1764256   Click image for larger version
ID:	1764257   Click image for larger version
ID:	1764258   Click image for larger version
ID:	1764259   Click image for larger version
ID:	1764261   Click image for larger version
ID:	1764262   Click image for larger version
ID:	1764263   Click image for larger version
Old 05-20-2012, 01:13 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Vaseline is spread on the backside of the motor mount prior to epoxying it to the firewall.
ID:	1764269   Click image for larger version
ID:	1764270   Click image for larger version
ID:	1764271   Click image for larger version
ID:	1764272   Click image for larger version
ID:	1764273   Click image for larger version
ID:	1764274   Click image for larger version
ID:	1764275   Click image for larger version
Old 05-20-2012, 01:18 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The front beams of of the motor mount are attached with epoxy and fiberglass cloth.
The last picture shows the engine installed on the motor mount.
ID:	1764280   Click image for larger version
ID:	1764281   Click image for larger version
Old 05-21-2012, 07:19 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I installed the firewall and engine in the second AJ-2 tonight.
The second time was much easier and quicker.
ID:	1764961   Click image for larger version
Old 05-25-2012, 07:24 AM
club 20 king
club 20 king's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Loving this build, keep it coming.
Thank You
J
club 20 king is offline
Old 05-25-2012, 08:13 AM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's good to see some interest! [8D]
In the USA most buy composite models.
I've found that if you are a good Q500 builder you can build a QM40.
I will continue this weekend.
Old 05-25-2012, 05:32 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A 1/4" thick piece of plywood is being installed in the following pictures.
Note: I am mounting the gear further back than shown on the drawings. This is to reduce bouncing on landing.
ID:	1765859   Click image for larger version
ID:	1765860   Click image for larger version
ID:	1765861   Click image for larger version
ID:	1765862   Click image for larger version
ID:	1765863   Click image for larger version
ID:	1765864   Click image for larger version
Old 05-26-2012, 01:04 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following pictures shows the installation of 3/4" diameter dowel and 1/8" thick plywood on the wing:
ID:	1766070   Click image for larger version
ID:	1766071   Click image for larger version
ID:	1766072   Click image for larger version
ID:	1766073   Click image for larger version
ID:	1766074   Click image for larger version
ID:	1766075   Click image for larger version
ID:	1766076   Click image for larger version
