Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
AR-6 Construction Thread
Reply
Old 12-01-2012, 11:47 AM
  #51
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AR-6 Construction Thread
The wing will weigh about 15.4 ounces after installing the torque rods.
ID:	1825534   Click image for larger version
sahartman21 is offline
Old 12-08-2012, 10:31 AM
  #52
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In case you didn't catch on. Here is the second wing being glassed.
1) Begin by tacking on a piece of window sheer over the top surface of the ailerons. The purpose is to provide a hinge surface.
2) Tack a layer of 1.6 ounce fiberglass cloth over the entire surface of the wing.
3) Tack another layer of 1.6 ounce fiberglass cloth over the wing tips.
4) Tack a wide (15.5") piece of fiberglass cloth around the center of the wing.
5) Follow with 3 more layers of fiberglass cloth (each getting gradually narrower) around the center of the wing.
6) Mix about 1.5 ounces of finishing epoxy. Add 10% more 91% alcohol to thin the epoxy. Drizzle this over one side of the wing and use a squeegee to spread out the epoxy. Do the other side the same way.
7) Place the wing between layers of nylon fabric (peel ply).
ID:	1827795   Click image for larger version
ID:	1827796   Click image for larger version
ID:	1827797   Click image for larger version
ID:	1827798   Click image for larger version
ID:	1827799   Click image for larger version
Old 12-08-2012, 10:34 AM
  #53
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More pictures:
8) Put the wing in the vacuum bag and apply about 5" Hg vacuum to the wing.
9) It's cold so the vacuum bag was placed between layers of electric blanket. This warms the epoxy enough that it dries.
ID:	1827801   Click image for larger version
ID:	1827802   Click image for larger version
ID:	1827803   Click image for larger version
Old 12-09-2012, 07:16 AM
  #54
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gary provided some background on the AR-6. The Sportsman Pilot article is real interesting.
Thanks Gary!
ID:	1828123   Click image for larger version
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 12-09-2012, 10:48 AM
  #55
GSJames
GSJames's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: sahartman21
Thanks Gary!
You're Welcome, Have Fun!
GSJames is offline
Old 12-09-2012, 03:53 PM
  #56
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
On a recent project the first flight showed that there was a slight twist in the wing.
I chose to check the wing on the AR-6 before proceeding to the next steps.
Should there be a twist, it can be removed by heating the wing (with a heat gun or heater like shown here) and twisting it in the opposite direction of the twist.
Remove the wing from the heat and continue holding until the wing is cool.
Recheck the wing at several locations to confirm the wing is straight.
ID:	1828310   Click image for larger version
ID:	1828311   Click image for larger version
Old 12-11-2012, 08:30 PM
  #57
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following pictures shows the installation of ailerons.
They are going to be configured like the ones on the yellow wing.
ID:	1829100   Click image for larger version
ID:	1829101   Click image for larger version
ID:	1829102   Click image for larger version
ID:	1829103   Click image for larger version
ID:	1829104   Click image for larger version
ID:	1829105   Click image for larger version
ID:	1829106   Click image for larger version
Old 12-11-2012, 08:35 PM
  #58
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More pictures:
ID:	1829109   Click image for larger version
ID:	1829110   Click image for larger version
ID:	1829111   Click image for larger version
ID:	1829112   Click image for larger version
ID:	1829113   Click image for larger version
ID:	1829114   Click image for larger version
ID:	1829115   Click image for larger version
ID:	1829117   Click image for larger version
ID:	1829118   Click image for larger version
ID:	1829119   Click image for larger version
Old 12-11-2012, 09:37 PM
  #59
PylonDave
PylonDave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Scott, On the kitchen table ??? Must be cold in the garage!! :-)
PylonDave is offline
Old 12-12-2012, 09:53 AM
  #60
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: PylonDave
I didn't think the epoxy would dry in the cold garage, so I brought the wings inside to dry.
Old 12-12-2012, 09:55 AM
  #61
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used a Dremel tool to remove the majority of excess epoxy & micro-balloon mix. This was followed by using a scrapper blade to bring the surface flush.
ID:	1829272   Click image for larger version
ID:	1829273   Click image for larger version
ID:	1829274   Click image for larger version
Old 12-12-2012, 10:00 AM
  #62
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wings weigh in at 14.95 and 15.4 ounces. Both are relatively light and allow a couple ounces for a painted finish.
My wings are ready to fly at nominally 19 to 21 ounces with the servo.
ID:	1829276   Click image for larger version
ID:	1829277   Click image for larger version
Old 12-12-2012, 05:09 PM
  #63
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lightweight Spackle is spread over the surface of the wing fill low spots.
The surface immediately in front of the hinge material (window shear) should be filled in this step.
ID:	1829358   Click image for larger version
ID:	1829359   Click image for larger version
ID:	1829360   Click image for larger version
Old 12-13-2012, 06:50 AM
  #64
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The horizontal tail surfaces are made from 3/8" light balsa sheet.
I've enlarged the tail a bit to get a tail about 16".
ID:	1829514   Click image for larger version
ID:	1829515   Click image for larger version
Old 12-14-2012, 12:40 PM
  #65
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following pictures shows the installation of 1/64" thick plywood strips into the edges of the horizontal tail surface:
ID:	1829927   Click image for larger version
ID:	1829928   Click image for larger version
ID:	1829929   Click image for larger version
Old 12-14-2012, 12:43 PM
  #66
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A Dremel tool and cutoff disk are used to cut the hole for the horizontal stabilizer.
Fiberglass and carbon fiber dust is present during the cutting. I used a respirator to protect my lungs.
ID:	1829932   Click image for larger version
ID:	1829933   Click image for larger version
Old 12-14-2012, 12:46 PM
  #67
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One inch square pieces of 1/4" thick plywood are glued in place for use as wing hold down blocks.
ID:	1829938   Click image for larger version
ID:	1829939   Click image for larger version
Old 12-15-2012, 09:41 AM
  #68
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The tail surface is shaped in the following pictures. Most of the actual shaping was done with a sanding block with coarse sandpaper (80 grit).
ID:	1830222   Click image for larger version
ID:	1830223   Click image for larger version
ID:	1830224   Click image for larger version
ID:	1830225   Click image for larger version
ID:	1830226   Click image for larger version
ID:	1830227   Click image for larger version
ID:	1830228   Click image for larger version
ID:	1830230   Click image for larger version
ID:	1830231   Click image for larger version
Old 12-15-2012, 05:20 PM
  #69
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following pictures shows the installation of skinned hinge and fiberglass cloth on the tail surface:
A piece of window sheer (chiffon) is tacked to the tail surface.
Pieces of 1.6 ounce fiberglass cloth are tacked over the window sheer and other side.
Apply finishing epoxy over the surface of the cloth. A plastic squeegee is used to spread out the glue.
Tail surfaces are placed between layers of peel ply (nylon fabric).
ID:	1830378   Click image for larger version
ID:	1830379   Click image for larger version
ID:	1830380   Click image for larger version
ID:	1830381   Click image for larger version
ID:	1830382   Click image for larger version
ID:	1830383   Click image for larger version
Old 12-15-2012, 05:21 PM
  #70
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More pictures:
The vacuum bag is made from 4 mil thick pieces of plastic tarp.
A layer of paper towel is applied on top of the surface before closing the bag.
Latex caulking is used to seal the edges.
The vacuum pump is set to pull about 5" Hg.
It is cold outside and therefore the parts were placed between layers of electric blanket to raise the temperature enough that the epoxy will dry.
ID:	1830385   Click image for larger version
ID:	1830386   Click image for larger version
ID:	1830387   Click image for larger version
ID:	1830388   Click image for larger version
Old 12-16-2012, 08:13 AM
  #71
PylonDave
PylonDave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Scott , is this a 1/4 inch balsa stab ??
Old 12-16-2012, 08:17 AM
  #72
PylonDave
PylonDave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh I see that it is 3/8 inch. Sorry
I wonder about sandwiching some 1/64 ply between say two 1/4 inch light balsa pieces to create a little thicker airfoil.
Have you ever tried that ?
Old 12-16-2012, 10:47 AM
  #73
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: PylonDave
The wood Sam-Rai tail surfaces are constructed with a 1/64" thick piece of plywood (with lightening holes) between layers of balsa wood. This works OK, but is heavier than wood that just has 1/64" ply added at the edges.
Initially I was apprehensive about shaping the 3/8" balsa sheet. It was actually easier than I thought and the second tail surface was shaped in about 20 minutes. The razor plane and sanding block work wonders on balsa.
Old 12-16-2012, 10:55 AM
  #74
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The tail surfaces were removed from the vacuum bag.
I cut off the caulking so it doesn't get it all over.
Use a sanding block to trim the edges and smooth out the surface.
ID:	1830787   Click image for larger version
ID:	1830788   Click image for larger version
ID:	1830789   Click image for larger version
ID:	1830790   Click image for larger version
Old 12-16-2012, 10:59 AM
  #75
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following pictures show the attachment of the wing to the fuselage:
ID:	1830792   Click image for larger version
ID:	1830793   Click image for larger version
ID:	1830794   Click image for larger version
ID:	1830795   Click image for larger version
ID:	1830796   Click image for larger version
ID:	1830797   Click image for larger version
ID:	1830798   Click image for larger version
ID:	1830800   Click image for larger version
Reply
Display Modes
