Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
AR-6 Construction Thread
Reply
Old 12-21-2012, 05:03 PM
  #76
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AR-6 Construction Thread
I checked the wing and motor incidence before going to the next step.
There is just a tad of down thrust when the wing is level. This is very good!
sahartman21 is offline
Old 12-22-2012, 10:50 AM
  #77
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following pictures show the slotting of the horizontal stabilizer:
ID:	1832795   Click image for larger version
ID:	1832796   Click image for larger version
ID:	1832797   Click image for larger version
ID:	1832798   Click image for larger version
ID:	1832799   Click image for larger version
ID:	1832800   Click image for larger version
ID:	1832801   Click image for larger version
Old 12-22-2012, 10:54 AM
  #78
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Temporarily slide the horizontal stabilizer into the fuselage and plan out the pushrod installation.
I prefer longer elevator horns to reduce the play on the elevator installation.
A 1 5/8" long (to the connection) control horn is shown in the picture.
ID:	1832804   Click image for larger version
ID:	1832805   Click image for larger version
Old 12-22-2012, 11:02 AM
  #79
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following pictures show the construction of the elevator control horn. Silver solder is used in construction.
I ended up using a 1 3/8" long control horn (center of 3/32" music wire to hole).
ID:	1832809   Click image for larger version
ID:	1832810   Click image for larger version
ID:	1832811   Click image for larger version
ID:	1832812   Click image for larger version
ID:	1832813   Click image for larger version
ID:	1832814   Click image for larger version
ID:	1832815   Click image for larger version
ID:	1832817   Click image for larger version
ID:	1832818   Click image for larger version
Old 12-22-2012, 02:32 PM
  #80
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following show how the elevator and horn are installed in the fuselage:
ID:	1832869   Click image for larger version
ID:	1832870   Click image for larger version
ID:	1832871   Click image for larger version
ID:	1832872   Click image for larger version
ID:	1832873   Click image for larger version
ID:	1832874   Click image for larger version
Old 12-22-2012, 06:20 PM
  #81
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing and horizontal stabilizer were checked with incidence meters (sorry no pictures) and the tail needed to be adjusted a little.
Components were checked again and then the horizontal stabilizer was glued in place with epoxy.
ID:	1832958   Click image for larger version
ID:	1832959   Click image for larger version
ID:	1832960   Click image for larger version
ID:	1832961   Click image for larger version
Old 12-23-2012, 06:07 AM
  #82
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Balsa was added to contain the epoxy and micro-balloons mix.
A small amount of finishing epoxy was mixed. Micro-balloons were added until the mix was the thickness of toothpaste.
The mix was added to fill and the model was set out of the way to dry.
ID:	1833036   Click image for larger version
ID:	1833037   Click image for larger version
ID:	1833038   Click image for larger version
ID:	1833039   Click image for larger version
Old 12-24-2012, 08:19 AM
  #83
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A Dremel tool was used to remove the majority of excess epoxy and micro-balloon mix.
Follow with a scraper blade to bring the surface flush.
ID:	1833359   Click image for larger version
ID:	1833360   Click image for larger version
ID:	1833361   Click image for larger version
ID:	1833362   Click image for larger version
Old 12-24-2012, 12:43 PM
  #84
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The rudder was cut off and hinged in the following pictures:
ID:	1833456   Click image for larger version
ID:	1833457   Click image for larger version
ID:	1833458   Click image for larger version
ID:	1833459   Click image for larger version
ID:	1833460   Click image for larger version
ID:	1833461   Click image for larger version
ID:	1833462   Click image for larger version
ID:	1833464   Click image for larger version
ID:	1833465   Click image for larger version
ID:	1833466   Click image for larger version
Old 12-27-2012, 04:08 PM
  #85
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some pictures showing how to install the rudder horn:
ID:	1834094   Click image for larger version
ID:	1834095   Click image for larger version
ID:	1834096   Click image for larger version
ID:	1834097   Click image for larger version
ID:	1834098   Click image for larger version
ID:	1834099   Click image for larger version
ID:	1834100   Click image for larger version
ID:	1834102   Click image for larger version
ID:	1834103   Click image for larger version
Old 12-28-2012, 04:22 PM
  #86
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A slot is made for the rudder pushrod.
An access hole is made for the elevator horn.
ID:	1834304   Click image for larger version
ID:	1834305   Click image for larger version
ID:	1834306   Click image for larger version
Old 12-28-2012, 04:25 PM
  #87
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The skid was attached with Shoe Goo. If done again I would consider epoxy instead.
ID:	1834308   Click image for larger version
ID:	1834309   Click image for larger version
ID:	1834310   Click image for larger version
Old 12-29-2012, 06:24 PM
  #88
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The installation of the servo tray is shown below:
ID:	1834775   Click image for larger version
ID:	1834776   Click image for larger version
ID:	1834777   Click image for larger version
ID:	1834778   Click image for larger version
ID:	1834779   Click image for larger version
ID:	1834780   Click image for larger version
ID:	1834781   Click image for larger version
ID:	1834783   Click image for larger version
ID:	1834784   Click image for larger version
ID:	1834785   Click image for larger version
Old 12-29-2012, 06:28 PM
  #89
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The aileron servo mount installation follows. The 3/8" diameter dowel pieces are glued in with 6-minute epoxy.
ID:	1834791   Click image for larger version
ID:	1834792   Click image for larger version
ID:	1834793   Click image for larger version
ID:	1834794   Click image for larger version
ID:	1834795   Click image for larger version
ID:	1834796   Click image for larger version
Old 12-30-2012, 04:28 PM
  #90
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The engine kill is being installed in the next few pictures.
A piece of 3/8" tubing (OD) is being installed in the firewall.
Pulling the fuel tubing bends it to shutoff the fuel to the engine.
ID:	1835227   Click image for larger version
ID:	1835228   Click image for larger version
ID:	1835229   Click image for larger version
ID:	1835230   Click image for larger version
ID:	1835231   Click image for larger version
ID:	1835232   Click image for larger version
ID:	1835233   Click image for larger version
Old 01-01-2013, 09:20 AM
  #91
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following pictures shows anchoring the motor mount with fiberglass and epoxy.
Thirty minute epoxy was added to cut fiberglass cloth pieces.
Dab in place and let dry.
ID:	1835801   Click image for larger version
ID:	1835802   Click image for larger version
ID:	1835803   Click image for larger version
Old 01-01-2013, 11:25 AM
  #92
PylonDave
PylonDave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Happy New Year Scott!!!
Will this one fly at the Basin??
Which Motor Mount is that???
PylonDave is offline
Old 01-01-2013, 12:46 PM
  #93
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm planning to fly this model (AR-6). I will also bring my AJ-2 (Matney's Models Kit). I will race what I am most comfortable with.
The mount is from Jett. It comes complete with needle valve for about $60.
No more messing around. It's time to finish them up. [8D]
Old 01-01-2013, 01:00 PM
  #94
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The access hole at the elevator horn was filled with a piece of fiberglass cloth. I just stuck it in place with CA.
A scrapper blade was used to remove the edge at the fuselage joints.
Some lightweight automotive body filler was used to fill holes bigger than 1/8". Just follow directions. It dries in a few minutes and is easily sanded with a sanding block.
ID:	1835896   Click image for larger version
ID:	1835897   Click image for larger version
ID:	1835898   Click image for larger version
ID:	1835899   Click image for larger version
ID:	1835900   Click image for larger version
ID:	1835901   Click image for larger version
ID:	1835902   Click image for larger version
Old 01-04-2013, 08:02 PM
  #95
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wash the exterior of the fiberglass parts with water and dish soap to remove any trace amounts of release agent.
Place the fuselage out of the way to dry.
ID:	1836881   Click image for larger version
Old 01-05-2013, 11:22 AM
  #96
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A squeegee was used to spread lightweight Spackle over the surface of the model.
This was done to fill up pinholes prior to applying primer.
ID:	1837035   Click image for larger version
ID:	1837036   Click image for larger version
ID:	1837037   Click image for larger version
Old 01-05-2013, 04:34 PM
  #97
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There was this heat wave in Texas, got up to 45 F, so it was time to prime the model.
KlassKote white primer was used on the model.
Use a respirator when painting and spray outside. Initially the model dried outside.
The wing and fuselage were moved inside a couple hours after spraying.
ID:	1837146   Click image for larger version
ID:	1837147   Click image for larger version
ID:	1837148   Click image for larger version
ID:	1837149   Click image for larger version
ID:	1837150   Click image for larger version
ID:	1837151   Click image for larger version
ID:	1837152   Click image for larger version
ID:	1837154   Click image for larger version
Old 01-06-2013, 04:36 PM
  #98
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After the primer is dry it is time to wet sand it smooth. Don't skimp on this exercise. This is the most important part of the finish.
You want it smooth, without going through to the fiberglass.
ID:	1837569   Click image for larger version
ID:	1837570   Click image for larger version
ID:	1837571   Click image for larger version
Old 01-06-2013, 04:39 PM
  #99
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I mixed about 4 ounces of acrylic enamel paint and thinned it about a third with fast reducer.
The paint was ordered from Restoration Shop, and the color was Swift Red.
I was very happy with the paint as it covered well and worked fine in the 45 F outside temperature.
ID:	1837573   Click image for larger version
ID:	1837574   Click image for larger version
Old 01-06-2013, 07:33 PM
  #100
s-10promod
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking nice Scott!!
Now it just needs my trim colors and numbers!!!
s-10promod is offline
