Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
AR-6 Construction Thread
Reply
Old 01-07-2013, 10:56 AM
  #101
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AR-6 Construction Thread
ORIGINAL: s-10promod
Looking nice Scott!!
Now it just needs my trim colors and numbers!!!
That can probably be arranged!
sahartman21 is offline
Old 01-08-2013, 05:40 PM
  #102
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing and fuselage had a few areas where the paint surface was dull, due to soaking into the Spackle.
I wet sanded the wing and gave it another coat of color. I wet sanded a few areas on the tail surfaces and fuselage. Those areas were also given another coat.
Old 01-10-2013, 07:27 PM
  #103
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After a couple days a wet sand (800 to 2000 grit wet-and-dry sandpaper) was done on the finish to remove dirt and bugs.
ID:	1839087   Click image for larger version
ID:	1839088   Click image for larger version
ID:	1839089   Click image for larger version
Old 01-12-2013, 10:18 AM
  #104
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The trim pattern will be similar to that of my AJ-2. Here are some pictures showing the configuration of the trim:
ID:	1839511   Click image for larger version
ID:	1839512   Click image for larger version
ID:	1839513   Click image for larger version
ID:	1839514   Click image for larger version
ID:	1839515   Click image for larger version
ID:	1839516   Click image for larger version
Old 01-12-2013, 02:03 PM
  #105
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The rest of the model was masked off to keep off in areas not wanted.
I used gloss black Krylon spray paint for trim.
Apply a light coat first. Let dry a few minutes and then spray until the paint covers.
In about 1/2 hour the paint is dry enough to remove the masking paper.
ID:	1839603   Click image for larger version
ID:	1839604   Click image for larger version
ID:	1839605   Click image for larger version
ID:	1839606   Click image for larger version
ID:	1839607   Click image for larger version
ID:	1839608   Click image for larger version
Old 01-13-2013, 09:06 AM
  #106
masama1107
My Feedback: (44)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great job as always Scott!!!
Look forward to seeing you at the Basin Q-40 race next month.
masama1107 is offline
Old 01-13-2013, 01:18 PM
  #107
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: masama1107
Thanks!
I'm looking forward to the race.
Old 01-13-2013, 01:20 PM
  #108
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wet sanded using a piece of 2000 wet-and-dry sandpaper and water.
Hopefully there will be some warmer weather for applying the clear coat.
Old 01-14-2013, 12:10 PM
  #109
SSAN
SSAN's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking good, Scott!Great work with many building tips and techniques and promoting the sport of Pylon racing in general.The model looks great, except maybe the color red. I prefer mind in yellow or gold color instead. ;-)
SSAN is offline
Old 01-16-2013, 05:41 PM
  #110
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The temperature warmed up from 20 F this weekend to about 50 F today.
I took this opportunity to spray on the clear coat.
A fast hardener was used as the temperature was cold. I thinned out the clear coat using a fast reducer, so it would lay down easier in the cold temperature.
A light coat was applied over the surface. It was let to dry a few minutes and then more coats were applied until the surface was shiny.
I set the parts out of the way to dry.
ID:	1841271   Click image for larger version
ID:	1841272   Click image for larger version
ID:	1841273   Click image for larger version
ID:	1841274   Click image for larger version
ID:	1841275   Click image for larger version
Old 01-16-2013, 06:24 PM
  #111
fizzwater2
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lookin' good, Scott!
fizzwater2 is offline
Old 01-19-2013, 04:46 PM
  #112
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following pictures show wet sanding and polishing the finish:
Use 2000 grit wet-and-dry sandpaper used wet to remove any dirt and runs.
ID:	1842262   Click image for larger version
ID:	1842263   Click image for larger version
ID:	1842264   Click image for larger version
Old 01-19-2013, 04:48 PM
  #113
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I followed with a cleaner polish. This is like the rubbing compound that we used to use. The picture shows a gradual improvement in the finish.
I finished with a liquid wax. The overall finish looks very good from 5 foot, so it's a 5-footer. [8D]
I'll have to wait until warmer weather for that super finish.
ID:	1842267   Click image for larger version
ID:	1842268   Click image for larger version
ID:	1842269   Click image for larger version
ID:	1842270   Click image for larger version
ID:	1842271   Click image for larger version
ID:	1842272   Click image for larger version
Old 01-20-2013, 01:01 PM
  #114
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I talked to Kevin Matney from Matney's Models about the difficulties when polishing out the wing.
After polishing the wing still had scratch and swirl marks. Kevin suggested going to a new foam bonnet and using a finer compound.
I used the foam bonnet and finer compound and now the wing looks considerably better. The following pictures show what the bonnet looks like:
The foam bonnet is standard equipment provided with a 6" Turtle buffer.
ID:	1842613   Click image for larger version
Old 01-25-2013, 05:07 PM
  #115
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The servos were installed using socket head screws.
http://www.microfasteners.com/catalo.../TWSSHWHMS.cfm
ID:	1844296   Click image for larger version
ID:	1844297   Click image for larger version
ID:	1844298   Click image for larger version
ID:	1844299   Click image for larger version
Old 01-26-2013, 10:20 AM
  #116
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The aileron pushrods were installed and the ailerons were cut free in the following pictures:
The aileron hinge line is freed up by moving the aileron at the hinge line.
ID:	1844491   Click image for larger version
ID:	1844492   Click image for larger version
ID:	1844493   Click image for larger version
ID:	1844494   Click image for larger version
ID:	1844495   Click image for larger version
ID:	1844496   Click image for larger version
ID:	1844497   Click image for larger version
Old 01-26-2013, 02:29 PM
  #117
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking good Scott, let us know how the flights go!!
Ill see ya at the Basin!!
MFLOOD3800 is offline
Old 01-26-2013, 03:00 PM
  #118
SSAN
SSAN's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Scott, Rather than using nylon clevis, use Hayes Steel Pin Clevis instead. Especially in our pylon racing models. You can purchase the steel pin clevis at Tower Hobby or any other hobby shop that carry Hayes products. Just a thought!
SSAN is offline
Old 01-26-2013, 03:14 PM
  #119
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I may have to try the Hayes connector at a later date.
Old 01-26-2013, 03:18 PM
  #120
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following shows the elevator pushrod construction:
ID:	1844637   Click image for larger version
ID:	1844638   Click image for larger version
ID:	1844639   Click image for larger version
ID:	1844640   Click image for larger version
ID:	1844641   Click image for larger version
Old 01-26-2013, 03:21 PM
  #121
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More pictures:
ID:	1844643   Click image for larger version
ID:	1844644   Click image for larger version
ID:	1844645   Click image for larger version
ID:	1844646   Click image for larger version
ID:	1844647   Click image for larger version
ID:	1844648   Click image for larger version
Old 01-26-2013, 03:29 PM
  #122
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Marty,
I'm looking forward to seeing you and others again.
FYI - Those engines you sold me have been running great![8D]
Old 01-26-2013, 04:55 PM
  #123
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The rudder pushrod is constructed similar to earlier pictures:
ID:	1844667   Click image for larger version
Old 01-27-2013, 07:59 AM
  #124
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The engine kill was installed in this sequence of pictures:
ID:	1844855   Click image for larger version
ID:	1844856   Click image for larger version
ID:	1844857   Click image for larger version
ID:	1844858   Click image for larger version
ID:	1844859   Click image for larger version
Old 01-27-2013, 02:56 PM
  #125
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following pictures shows the installation of the tank:
Initially mount the tank as high is it will go in the fuselage. Mine ended up about 1" above the wing.
ID:	1845089   Click image for larger version
ID:	1845090   Click image for larger version
ID:	1845091   Click image for larger version
ID:	1845092   Click image for larger version
ID:	1845093   Click image for larger version
ID:	1845094   Click image for larger version
