Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
AR-6 Construction Thread
Reply
Old 01-27-2013, 02:57 PM
  #126
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: AR-6 Construction Thread
The completed model weighed in about 2 ounces over the minimum.
ID:	1845096   Click image for larger version
sahartman21 is offline
Old 01-27-2013, 03:02 PM
  #127
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The AR-6 is now complete and ready for the test flights.
Many thanks to Lee Lavalley, Kevin Matney, Gary James, and others that helped make this come together![8D]
ID:	1845098   Click image for larger version
ID:	1845099   Click image for larger version
ID:	1845100   Click image for larger version
Old 01-28-2013, 05:59 AM
  #128
diggs_74
diggs_74's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks great Scott.. Can't wait to hear how it flies..
Thanks for all the work you did on the build thread, very good info..
diggs_74 is offline
Old 02-03-2013, 02:03 PM
  #129
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In the following pictures Lee's prototype fuselage got a new motor mount, wing, and horizontal tail surface.
ID:	1847646   Click image for larger version
Old 02-09-2013, 06:38 PM
  #130
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The surface of the fuselage was washed with Dawn dish soap to remove traces of engine oil. The fuselage was then sanded with 220 grit sandpaper. The fuselage was cleaned with a dry cloth.
White KlassKote epoxy primer was sprayed on the surface of the model.
ID:	1850117   Click image for larger version
Old 02-10-2013, 10:26 AM
  #131
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The primed surface was lightly sanded and cleaned.
This model was painted with acrylic enamel (Speed Yellow) paint and set out of the way to dry.
ID:	1850376   Click image for larger version
Old 02-13-2013, 02:05 PM
  #132
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Below are pictures showing after the black trim (Krylon) was applied.
Wet sanding was next.
Wait a couple days for the Krylon to dry before spraying clear coat on.
ID:	1851742   Click image for larger version
ID:	1851743   Click image for larger version
ID:	1851744   Click image for larger version
Old 02-13-2013, 02:47 PM
  #133
fizzwater2
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looks fast!
fizzwater2 is offline
Old 02-15-2013, 11:32 AM
  #134
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following pictures show the model with more lettering.
ID:	1852456   Click image for larger version
Old 02-15-2013, 02:31 PM
  #135
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Clear coat was applied to the fuselage in these pictures.
It was 40F outside and the cold temperatures make it difficult to apply the clear coat without running.
I mixed the clear coat per the directions and then added about 1/3 the volume of fast reducer.
A light mist was applied to the surface and then the model was set out of the way for about 10 minutes to dry.
Several more light coats were applied until the surface had a uniform luster, indicating it had covered the paint.
It was then set out of the way to dry.
The small spray gun worked well, considering the conditions. It is normally available at Harbor Freight at around $15.
ID:	1852497   Click image for larger version
ID:	1852498   Click image for larger version
Old 02-15-2013, 03:07 PM
  #136
PylonDave
PylonDave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey can't wait to see these birds in person!!!
PylonDave is offline
Old 02-15-2013, 05:21 PM
  #137
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Scott,
Looking good
How many planes you bringing to the Basin?
You have an entire team there.
MFLOOD3800 is offline
Old 02-15-2013, 05:43 PM
  #138
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll bring 3 racers to the Basin:
One AJ-2 and two AR-6.
I hope to see you in others in a few days. Have a safe trip!
Old 02-16-2013, 10:52 AM
  #139
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The yellow Endeavor is now clear coated and polished.
Next is re-installing the radio, engine, and landing gear.
The other two models (AJ-2 and AR-6) have been test flown. The Endeavor will be tested in California.
ID:	1852771   Click image for larger version
Old 02-16-2013, 10:55 AM
  #140
MFLOOD3800
My Feedback: (51)
MFLOOD3800's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wow on the carpet inside the house Scott?
I could never get away with that!!
Old 02-17-2013, 03:46 AM
  #141
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The model was finished last night.
Now is the fun part, loading.
I should be on the road shortly.
Old 02-17-2013, 02:52 PM
  #142
fizzwater2
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
safe travels, Scott - have fun!
Old 02-23-2013, 05:59 PM
  #143
Kevin Matney
Kevin Matney's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good Luck in Calie,
Kevin Matney is offline
Old 02-24-2013, 05:40 AM
  #144
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The weather was beautiful here most of the week.
I've made this a racing vacation and had a great time![8D]
Old 05-27-2013, 02:14 PM
  #145
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's another AR-6 wing on the build.
A friend of mine cut a pair of slots for front spars using a radial arm saw. The primary function of the spars is to reinforce the landing gear block area.
ID:	1886159   Click image for larger version
Old 05-27-2013, 02:23 PM
  #146
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The following pictures shows the fabrication of the wing skins. I like to build both sides of the wing at the same time.
1) Begin by making a full set of skins.
2) Tape them together so that there is a fold at the wing trailing edge.
3) Tack on a piece of carbon fiber laminate using 3M77.
4) Lay a piece of 1.6 ounce fiberglass cloth over the surface.
ID:	1886161   Click image for larger version
ID:	1886162   Click image for larger version
ID:	1886163   Click image for larger version
ID:	1886164   Click image for larger version
Old 05-27-2013, 02:29 PM
  #147
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The rear carbon fiber spar and wood spars were glued in place using finishing epoxy.
ID:	1886166   Click image for larger version
ID:	1886167   Click image for larger version
Old 05-27-2013, 02:31 PM
  #148
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mix an ounce of finishing epoxy and add approximately 10% (a cap full) of 91% alcohol.
Immediately spread the mix on one side of the wing using a plastic squeegee.
Mix another ounce of finishing epoxy and cover the other side the same way.
ID:	1886169   Click image for larger version
Old 05-27-2013, 02:40 PM
  #149
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Place the wing cores on the bottom skins and fold the top skins over.
Adjust the cores until they fit properly on the skins and them place them between the shucks.
Pin the parts in place and then follow with masking tape.
Place parts in the vacuum bag and turn on the pump. Mine is set to pull about 6" of vacuum.
ID:	1886183   Click image for larger version
ID:	1886184   Click image for larger version
ID:	1886185   Click image for larger version
Old 06-08-2013, 09:19 AM
  #150
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The cores were trimmed and removed from the shucks.
Double check the dimensions before doing the final trimming.
A balsa leading edge was glued on with Gorilla Glue.
Dampen the surfaces with water prior to gluing.
Apply a thin bead as the glue expands to fill the void.
The leading edge is temporarily held in place with masking tape until the glue dries
ID:	1889886   Click image for larger version
ID:	1889887   Click image for larger version
ID:	1889888   Click image for larger version
ID:	1889889   Click image for larger version
ID:	1889890   Click image for larger version
ID:	1889891   Click image for larger version
