Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
Quick Repair before the Nats !!
Reply
Old 07-11-2012, 09:56 AM
diggs_74
diggs_74's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Quick Repair before the Nats !!
I posted this on the NMPRA site but thought I might as well post it here too.
Ok, so all this work I've been doing on my AR-6 has the prototype ready for next weeks Nats(if you are going, please do not look at the paint job, it might be my worst ever, yes, it's that bad).. However, I have a severe warp in the left side that I can not get straightened out.. I've used the old Lyle trick with the heat gun and for some reason the wing will not set in the new/straight position.. I thought I would solicit any advice from the guys that used to, or still do, run foam core wings.. I had never attempted a Q40 foam wing before and won't again.. Molds are coming soon.
If all else fails, I'll fly it with the 1/8" of aileron trim it requires but it would be nice to not have that as it will surely add to the normal crappy times I get in Muncie The only positive is that I've got a pretty good engine on it and once it's trimmed it seems to groove pretty well.
I've got 2 days (including today) to make this repair.. If you've got something quick and dirty, that would be great.
Thanks in advance..
diggs_74 is offline
Old 07-11-2012, 10:23 AM
BarryReade
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Quick Repair before the Nats !!
Wish I could help Lee.  I wish you the best at the Nats!!
BarryReade is offline
Old 07-11-2012, 10:53 AM
diggs_74
diggs_74's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Barry.. Like I said, it flies pretty good once it's trimmed but I'm trying to make it a respectable showing for this model as I plan on selling some in the future..
diggs_74 is offline
Old 07-11-2012, 10:54 AM
fizzwater2
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I vaguely remember something like a knife slice in the skin, diagonal on the wing surface, on the side and in the direction that the slice opens up slightly when you straighten the wing..
twist to straighten, fill the slot with epoxy, clamp till it's cured.
Something like that. I can't remember where I've seen that, but it might be worth some google searching.
fizzwater2 is offline
Old 07-11-2012, 12:34 PM
diggs_74
diggs_74's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yep, that's the most likely fix I've been offered.. Looks like I'll be hacking on it tonight..
diggs_74 is offline
Old 07-11-2012, 04:11 PM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I hope it works for you bud. I'll look for your times in NATS News.
vicman is offline
Old 07-11-2012, 04:28 PM
Kevin Matney
Kevin Matney's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi LEE call me tonight.
Kevin Matney is offline
Old 07-11-2012, 07:45 PM
diggs_74
diggs_74's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, thanks for all the suggestions.. I ended up using Randy's version with a couple mods.. After a couple beers and finally a F**K it attitude I started hacking away. I started by blocking up the wing and making sure where I was at.. I had 2+ degrees of wash in on the left tip.. I also had about .5 of wash in on the right tip.. I figured since I was cutting I might as well fix them both.. Using my zona saw, I cut a diagonal line from the hinge opening on the bottom out to the LE of the wing tip. I then twisted it to where I wanted it and wicked in some foam safe thin CA.. After the smoke cleared, I put in some thick CA and kicked it.. This locked everything in place.. Other than looking like **** I now have both wing tips at .5 degrees of washout, like the original design has.. A little spot putty, some primer and a shot of paint and it's done.. I did end up heating the ailerons and twisting them to line up on the outboard side but they seem to be staying put.
Thanks again.. See you in Muncie..
diggs_74 is offline
Old 07-12-2012, 11:00 AM
diggs_74
diggs_74's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Minor correction to my previous post.. The tips are designed at 0 degrees.. However, this wing is at -0.5 degrees. I don't think my thumbs will notice but I thought I better set the record straight.
diggs_74 is offline
