Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
Futaba Setup
Reply
Old 12-31-2012, 08:10 PM
Mikey D
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Futaba Setup
I'm in the process of converting to Futaba. What are most using for QM40 Rx and Servos? I prefer a 2s straight LIPO setup or LIFE
Mike DeNeve
Mikey D is offline
Old 12-31-2012, 08:21 PM
Kevin Matney
Kevin Matney's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Futaba Setup
I use this for the RX battery. I raced all week end with 1 pack.
http://www.hobbyking.com/hobbyking/s...ever_Pack.html
Kevin Matney is offline
Old 12-31-2012, 08:42 PM
Mikey D
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry I need to clarify, what RX and Servos are recomended for 2sLIPO or LIFE in a QM40 setup.
Mikey D is offline
Old 12-31-2012, 08:53 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Typical Futaba QM40 setup:
1) RX - R617FS
2) Elevator Servo - S9650
3) Rudder and Engine Kill - S3102
4) Aileron Servo - S3002 (or replacement) or S9650
http://www.rcuniverse.com/forum/fb.asp?m=11349006
I've been using the 700 mAH Life pack with good results. No regulator is needed.
sahartman21 is offline
Old 12-31-2012, 10:00 PM
JAllen
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike,
I second Scott's set-up. The replacement for the 3002 is the 3016. Like the 3002, the 3016 is very durable but a bit slower and the metal gears eventually will develop more slop than the plastic gears of the 9650 and it's a bit heavier and analog. The I've also used the digital 3150's for rudder and shutoff, as well as for the "V" servos on a Sweet V or quickie. As with all 2 screw servos, it's a good idea to use servo tape and a balsa spacer between two servos to tighten up the mounting side to side but, they work great.
For all of these servos you'll need to use a LiFe if you don't want to use a regulator. For a LiPo, you'll want to use a regulator. The RX is fine on the higher voltage but these servos aren't happy with the higher LiPo voltage. Don't have mini HV servos yet but I prefer LiFe's anyway. The regulator is just one more piece that can develop a problem and several have had problems with them. I actually still have NiMH's in several of my birds at this point.
Jim Allen
JAllen is offline
Old 01-01-2013, 06:50 AM
Mikey D
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you Scott and Jim. That's what I was looking for. No regulators for me ill stick with LIFE or NIMHS for now.
Mikey D is offline
Old 01-10-2013, 08:00 PM
kommander
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Since Futaba and JR don't recommend operating servos above 6.0 volts, and a life battery will charge up to 7.2 volts, isn't there a risk of premature sevo failure?
kommander is offline
Old 01-11-2013, 05:45 AM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm not aware of premature failures of servos when using the 2 cell Life batteries.
Old 01-11-2013, 09:28 AM
luv to race
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bruce,
What LiFe packs are using that you see 7.2V's ?? The Orion packs I have been using are right at 6.7 - 6.9 volts peak.. Either way, I wouldn't worry about performance issues at 7.2V's..
Randy
luv to race is offline
Old 01-11-2013, 07:12 PM
kommander
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was in error, I'm using the orion pack too and the voltage is 6.9v after charge. Dare I take all my regulators out!
Old 01-11-2013, 07:31 PM
garys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bruce, I've been running the LiFe's without regulators...no issues.
garys is offline
Old 01-12-2013, 05:21 AM
BenG60
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
im guilty for passing this on to bruce, a few months ago i tried a life and no regulater, i lost a couple servos, so i contacted futaba, and horrizon, the both advised me not to, it was to high a voltage for a substained time, this came from ther tech dept
BenG60 is offline
Old 01-12-2013, 08:31 AM
kommander
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, I'm taking the regulator out of Joanne's airplane!!
Old 01-12-2013, 01:37 PM
luv to race
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It certainly wouldn't hurt to run a regulator with a LiFe pack. I personally don't. I have used a LiFe pack while using 3121's, 3421's, and 341's, and I haven't seen an issue yet. All my new planes for the past year I only run the 3711 high voltage servos, and no failure.
So if it makes you nervous to apply more than 6V's to what ever servos you use.. add the regulator and be safe.
Randy
Old 01-13-2013, 10:17 AM
garys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree with Randy. I've been running the LiFe's with Futaba 9650, 3150, and 3102 servos. The manufacturers are pretty much always going to error on the safe side recommending not exceeding the voltage ratings of the servos, so I'm not surprised to see the answers from Futaba and Horizon. As I said, I've had no issues, and as Randy said, if it makes you feel better, use a regulator.
garys is offline
