Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
Build an Ashley MM
Reply
Old 02-09-2016, 07:05 PM
  #76
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Build an Ashley MM
Two pieces of balsa of 1/4" thick balsa were joined together.
A piece of heavy grade fiberglass cloth was place on the surface and finishing epoxy was added.
The top was added and parts were placed in the vacuum bag (tarp with latex caulking)
The pump was turned on and compresses the surfaces for a good fit.
ID:	2146357   Click image for larger version
ID:	2146358   Click image for larger version
ID:	2146359   Click image for larger version
ID:	2146360   Click image for larger version
ID:	2146361   Click image for larger version
ID:	2146362   Click image for larger version
sahartman21 is offline
Old 02-10-2016, 12:34 PM
  #77
kane
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Scott,
What are you using this 1/4" balsa with glass cloth on it for?
DK
kane is offline
Old 02-10-2016, 01:05 PM
  #78
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by kane View Post
Scott,
DK
The two pieces with glass between will be used for the wingtips.
Old 02-10-2016, 06:28 PM
  #79
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The balsa laminate was removed from the vacuum bag and was cut into widths about 2" wide.
The tips shape follows that of the real Miss Ashley.
A jig saw was used to cut out the tips.
ID:	2146479   Click image for larger version
ID:	2146480   Click image for larger version
ID:	2146481   Click image for larger version
Old 02-10-2016, 06:30 PM
  #80
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Parts were dampened with water and glued on with Gorilla Glue.
Tape holds the tips in place until the glue is dry.
ID:	2146483   Click image for larger version
ID:	2146484   Click image for larger version
ID:	2146485   Click image for larger version
ID:	2146486   Click image for larger version
Old 02-10-2016, 08:08 PM
  #81
DHULEN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You better hurry up we leave for Phoenix a week from Sunday
DHULEN is offline
Old 02-11-2016, 08:50 PM
  #82
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing tips were shaped and the wing was sanded as required.
ID:	2146762   Click image for larger version
ID:	2146763   Click image for larger version
ID:	2146764   Click image for larger version
ID:	2146765   Click image for larger version
ID:	2146766   Click image for larger version
ID:	2146767   Click image for larger version
ID:	2146768   Click image for larger version
ID:	2146770   Click image for larger version
ID:	2146771   Click image for larger version
ID:	2146772   Click image for larger version
ID:	2146773   Click image for larger version
ID:	2146774   Click image for larger version
ID:	2146775   Click image for larger version
ID:	2146776   Click image for larger version
Old 02-11-2016, 08:57 PM
  #83
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fiberglass cloth on the outside of the wing provides most of the strength.
A small amount of finishing epoxy was applied in the area of the ailerons and peel ply was attached.
Numerous layers of 1.6 ounce glass cloth were applied at the center section.
The wing tips were given an extra layer of glass since they are easy to damage.
A final layer of 1.6 ounce cloth was laid over the entire wing surface.
ID:	2146779   Click image for larger version
ID:	2146780   Click image for larger version
ID:	2146781   Click image for larger version
ID:	2146782   Click image for larger version
ID:	2146783   Click image for larger version
ID:	2146784   Click image for larger version
ID:	2146785   Click image for larger version
Old 02-11-2016, 09:05 PM
  #84
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Approximately 1.5 ounce of finishing epoxy was mixed and applied for each wing half. A squeegee was used to spread out the epoxy.
The wing was placed between layers of peel ply and then placed in the vacuum bag (tarp sealed with latex caulking). Most of the air was removed from the bag with the vacuum pump.
The bag was then placed between the shucks and a couple quarts of paint were used to hold parts in place.
ID:	2146787   Click image for larger version
ID:	2146788   Click image for larger version
ID:	2146789   Click image for larger version
ID:	2146790   Click image for larger version
Old 02-12-2016, 04:38 PM
  #85
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing was removed from the peel ply.
Edges were trimmed with a sanding block and the surface was also lightly sanded.
The wing will weigh about 16 ounces after the aileron rods are installed.
ID:	2146949   Click image for larger version
ID:	2146950   Click image for larger version
ID:	2146951   Click image for larger version
Old 02-13-2016, 01:34 PM
  #86
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A second wing was glassed and vacuum bagged today.
Old 02-14-2016, 03:16 PM
  #87
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's time to finish these up. Duane and I are scheduled to travel next Sunday.
Old 02-14-2016, 06:55 PM
  #88
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My models are equipped with skin type hinges.
Holes are drilled for the aileron torque rods to stick out the other side.
The pictures shows the cutting of the ailerons.
One of my prototypes will have 1 1/4" wide ailerons and the other will have 1 3/8" wide ailerons.
The slot is 14" and the outward side will be left uncut.
ID:	2147314   Click image for larger version
ID:	2147315   Click image for larger version
ID:	2147316   Click image for larger version
ID:	2147317   Click image for larger version
Old 02-14-2016, 07:00 PM
  #89
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Heavy duty aileron torque rods are being used on the models.
The torque rods are long enough to go about 3" into the aileron stock.
They were bent and trimmed (with a Dremel) to shape.
ID:	2147321   Click image for larger version
ID:	2147322   Click image for larger version
ID:	2147323   Click image for larger version
ID:	2147324   Click image for larger version
ID:	2147325   Click image for larger version
Old 02-14-2016, 07:05 PM
  #90
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I taped off areas to keep epoxy from sticking to the surface of the ailerons.
Some scraps of balsa are used to make jigs to hold in the glue.
A mix of finishing epoxy and micro balloons was applied and holds the torque rods in place.
ID:	2147327   Click image for larger version
ID:	2147328   Click image for larger version
ID:	2147329   Click image for larger version
Old 02-14-2016, 07:35 PM
  #91
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing was set out of the way to allow the epoxy to dry.
Old 02-15-2016, 09:29 AM
  #92
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most of the excess epoxy mix was removed with a Dremel tool.
I followed with a scrapper blade to bring the epoxy flush with the balsa.
Old 02-15-2016, 01:17 PM
  #93
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing hold down block was trimmed to allow for the aileron torque rods.
The wing was aligned and taped in place.
ID:	2147445   Click image for larger version
ID:	2147446   Click image for larger version
Old 02-15-2016, 01:20 PM
  #94
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Holes were drilled and tapped for nylon bolts.
The holes were later countersunk and bolts reinstalled.
ID:	2147448   Click image for larger version
ID:	2147449   Click image for larger version
ID:	2147450   Click image for larger version
ID:	2147451   Click image for larger version
Old 02-19-2016, 09:53 AM
  #95
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sometimes despite your best efforts the plan falls apart.
I was planning to pot the wing to zero-zero between the engine wing. Setting up identified that the engine (on both models) was way off.
I could fill an extremely large void with micro balloons and epoxy or fix it. I chose to fix it by reinstalling the firewall and mount.
Below are pictures of the progress.
ID:	2148297   Click image for larger version
ID:	2148298   Click image for larger version
ID:	2148299   Click image for larger version
ID:	2148300   Click image for larger version
Old 02-19-2016, 10:05 AM
  #96
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The fiberglass fuselage had some built in down thrust. The stock long version had about 1 degree of down thrust.
The version I shortened had more.
The following steps should be followed to insure that the thrust line is reasonably close.
The model must be assembled and the level (or incidences) of engine and wing must be checked.
I had to adjust the engine by grinding part of the top surfaces of the engine thrust ring.
The wing was setup level and the engine thrust line was checked.
ID:	2148302   Click image for larger version
Old 02-19-2016, 10:10 AM
  #97
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I continued to reinstall the mount and engine similar to last time.
ID:	2148306   Click image for larger version
ID:	2148307   Click image for larger version
ID:	2148308   Click image for larger version
ID:	2148309   Click image for larger version
ID:	2148310   Click image for larger version
Old 02-19-2016, 10:15 AM
  #98
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The engine mount and firewall were temporarily tack glued in place.
A long drill bit was used to identify and drill the holes for the blind nuts.
The mount and firewall were removed from the model for further work.
ID:	2148313   Click image for larger version
ID:	2148314   Click image for larger version
ID:	2148315   Click image for larger version
Old 02-19-2016, 10:20 AM
  #99
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The holes were drilled larger for the installation of blind nuts.
An engine kill was made out of a piece of 1/4" ID aluminum tubing.
The tubing was filled with Vaseline to help keep glue from plugging the hole.
The blind nuts were glued in place.
ID:	2148317   Click image for larger version
ID:	2148318   Click image for larger version
ID:	2148319   Click image for larger version
ID:	2148320   Click image for larger version
ID:	2148321   Click image for larger version
ID:	2148322   Click image for larger version
ID:	2148323   Click image for larger version
Old 02-19-2016, 10:29 AM
  #100
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
About 3/4 ounce of finishing epoxy was mixed.
A small amount was applied to the front of the firewall.
The mount, engine, spacer, and spinner were installed. The spinner was taped onto the nose.
Cotton flocks were added to the remaining finishing epoxy and were mixed. This was applied to the back of the firewall and particularly around the joint.
The alignment was double and triple checked and then the fuselage was set out of the way to dry.
ID:	2148326   Click image for larger version
ID:	2148327   Click image for larger version
ID:	2148328   Click image for larger version
ID:	2148329   Click image for larger version
ID:	2148330   Click image for larger version
ID:	2148331   Click image for larger version
ID:	2148332   Click image for larger version
