Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
Build a Miss Ashley - Revisited
Reply
Old 02-04-2018, 03:40 PM
  #101
Bozarth
My Feedback: (15)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Scott,
Nice build thread. Great pictures. What are your thoughts behind the dowel aileron servo mounts as opposed to the typical cutout slot in the wing? I have never done the dowel mounting method so I donít know the pros/cons. Thanks!
Kurt
Bozarth is offline
Old 02-04-2018, 06:33 PM
  #102
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Build a Miss Ashley - Revisited
the s
Originally Posted by Bozarth View Post
Hey Scott,
Nice build thread. Great pictures. What are your thoughts behind the dowel aileron servo mounts as opposed to the typical cutout slot in the wing? I have never done the dowel mounting method so I don’t know the pros/cons. Thanks!
Kurt
The method with dowel aileron servo installation works very well with this model. It has long aileron horns and installing the servo on the dowels connects very well with long horns.
I could have used a cutout. The servo would require raising a little as the wing is relatively thin in the location where the hole would be.
Either way should work fine.
sahartman21 is offline
Old 02-05-2018, 08:21 PM
  #103
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The entire model was lightly sanded with 220 grit sandpaper used dry.
ID:	2253660   Click image for larger version
ID:	2253661   Click image for larger version
Old 02-05-2018, 08:23 PM
  #104
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I followed by filling any larger holes with polyester filler (Bondo).
In about 30 minutes the filler is dry enough to sand. Lightly sand as required.
ID:	2253663   Click image for larger version
ID:	2253664   Click image for larger version
Old 02-05-2018, 08:27 PM
  #105
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used the time-proven method of filling the model surface with spackle.
Apply a thin layer and rub it into the surface to fill any pinholes.
Make sure the ailerons and other movable surface is not covered with spackle and set the model out of the way to dry.
ID:	2253666   Click image for larger version
ID:	2253667   Click image for larger version
ID:	2253668   Click image for larger version
Old 02-07-2018, 05:41 PM
  #106
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The surface of the model was lightly sanded with 220 grit sandpaper used dry.
I followed by wiping and blowing off the surface with an air blower.
Old 02-07-2018, 05:45 PM
  #107
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I mixed about 5 ounces (by weight) of epoxy primer. I waited 30 minutes and then added an equal volume of lacquer thinner.
Parts were lightly sprayed (outside) with the primer until the surface was sealed.
The airframe was set out of the way to dry.
ID:	2253872   Click image for larger version
ID:	2253873   Click image for larger version
Old 02-08-2018, 05:52 PM
  #108
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I dry sanded the surface of the primer with 220 and 400 grit sand paper.
There were a few areas that needed touch up. I will fill, prime, and sand those areas again.
ID:	2253954   Click image for larger version
ID:	2253955   Click image for larger version
ID:	2253956   Click image for larger version
Old 02-10-2018, 11:37 AM
  #109
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cold temperatures or not I am running out of time if I want to race this model at Phoenix.
I mixed about 5 ounces of Acrylic Enamel. It was allowed to warm up before spraying.
Several light coats were applied until the surface was covered. This is where I have to tell myself that the model is to race and not show off.
I followed by moving the model inside the garage to dry.
ID:	2254102   Click image for larger version
Old 02-11-2018, 06:40 PM
  #110
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The surface was lightly wet sanded prior to adding the stencils.
I've found that everything that you don't want painted should be covered.
ID:	2254336   Click image for larger version
ID:	2254337   Click image for larger version
ID:	2254338   Click image for larger version
ID:	2254339   Click image for larger version
Old 02-11-2018, 06:44 PM
  #111
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Several very light coats of Krylon rattle can type gloss black paint were applied. Allow to dry between coats.
ID:	2254341   Click image for larger version
ID:	2254342   Click image for larger version
ID:	2254343   Click image for larger version
ID:	2254344   Click image for larger version
ID:	2254345   Click image for larger version
Old 02-11-2018, 06:49 PM
  #112
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In just a few minutes the paint is dry enough to remove the tape and stencils.
Remove them and set the model out of the way to dry further.
Let the paint dry several more days before applying clear coat.
ID:	2254347   Click image for larger version
ID:	2254348   Click image for larger version
ID:	2254349   Click image for larger version
ID:	2254350   Click image for larger version
ID:	2254351   Click image for larger version
Old 02-12-2018, 09:17 AM
  #113
yankee samurai
My Feedback: (175)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great presentation!
yankee samurai is offline
Old 02-12-2018, 06:12 PM
  #114
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by yankee samurai View Post
Great presentation!
Thanks for reviewing and complementing.
This thread is primarily there to help the newcomer.
Old 02-13-2018, 05:48 PM
  #115
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wind settled down this evening and so I took the opportunity to spray on the clear coat.
I used a clear coat intended for spot repairs as that type dries fast and works well. I thinned the mix with about 1/3 part thinner per 1 part of clear coat.
A light mist was applied first.
After about 10 minutes another coat was applied.
This continued until there were no dull areas.
Here are some pictures:
ID:	2254568   Click image for larger version
ID:	2254569   Click image for larger version
ID:	2254570   Click image for larger version
ID:	2254571   Click image for larger version
Old 02-14-2018, 06:51 PM
  #116
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This evening the model was wet sanded (800 or 2000 grit sandpaper) to remove any grit present in the finish. I followed by polishing and waxing.
Pictures are shown below:
ID:	2254720   Click image for larger version
ID:	2254721   Click image for larger version
ID:	2254722   Click image for larger version
Old 02-14-2018, 06:54 PM
  #117
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A cutoff disk was used to gently cut through the inside layer of fiberglass cloth between the foam core and wood.
Take your time and don't cut too deep.
ID:	2254724   Click image for larger version
Old 02-14-2018, 06:57 PM
  #118
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The model is now ready to reinstall the radio, engine, and tank.
With a little luck the first flights will be next week in Phoenix.
ID:	2254732   Click image for larger version
Old 02-15-2018, 02:14 PM
  #119
fizzwater2
My Feedback: (60)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good luck out there, Scott! Have fun
fizzwater2 is offline
Old 02-16-2018, 02:18 PM
  #120
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some pictures showing the ailerons being cut free and the servo being reinstalled:
The servo works equally as well in this location as in a hole cut on top of the wing.
ID:	2254861   Click image for larger version
ID:	2254862   Click image for larger version
ID:	2254863   Click image for larger version
Old 02-16-2018, 02:25 PM
  #121
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The elevator was cut free and a small piece of tape (medical tape) was applied at the corners. This reduces the possibility of flutter and hinge damage.
We now must have the FAA number on your model. The last picture shows my number.
ID:	2254865   Click image for larger version
ID:	2254866   Click image for larger version
ID:	2254867   Click image for larger version
Old 02-16-2018, 06:12 PM
  #122
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are more pictures showing radio and engine installation:
ID:	2254899   Click image for larger version
ID:	2254900   Click image for larger version
ID:	2254901   Click image for larger version
ID:	2254902   Click image for larger version
ID:	2254903   Click image for larger version
ID:	2254904   Click image for larger version
ID:	2256565   Click image for larger version
Old 02-17-2018, 07:39 AM
  #123
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are a few pictures of the completed model:
ID:	2254961   Click image for larger version
ID:	2254962   Click image for larger version
ID:	2254963   Click image for larger version
ID:	2254964   Click image for larger version
Old 02-18-2018, 03:35 PM
  #124
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
These are the approximate throws required on each control surface based upon a model balanced at 3 3/4" to 3 7/8" back from the front of the wing saddle:
  • Elevator low rate = 7/64" up and less down Elevator high rate = 1/8" to 3/16" up and more down
  • Rudder low rate = 3/16" each way Rudder high rate = 5/16" each way
  • Aileron low rate = 1/8" each way Aileron high rate = 3/16" each way
It is OK to start with a little more elevator during the first couple trim flights.
Take off using the low rate settings. During take-off apply full right rudder, full up elevator, and a small amount of right aileron.
Last edited by sahartman21; 03-01-2018 at 08:16 AM. Reason: Added notes on take-off
Old 02-26-2018, 04:59 PM
  #125
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My Jett CG tank is located on a piece of firm foam so that the bottom of the tank is about 7/8" above the wing.
A relatively high tank is necessary to insure that the engine does not go lean when going through a high "G" turn.
