My new Q40 STREGA airmodel
Hello racers
this is my new Q40 STREGA airmodel , i have approved the first step of approval proces , now i milling the mould with cnc and hope finisch next week . i think to build one or two models for my friends Paolo Mucedola and Frank Wong(i have called Frank in Muncie F3D WC) .....paint in the mould, two pieces tail ..ecc.. they race in Phoenix in Febbrary .
Ciao Paolo P.
Ciao Paolo P.
RE: My new Q40 STREGA airmodel
ORIGINAL: vertical grimmace
Will you produce these in numbers? How much to get them to the USA?
Ciao Paolo P.
Paolo:
It looks very nice, it is going to be a head turner, good luck in your tests and looking for worth to meat you in Phoinex
Enrique Licea
Mexico
Enrique Licea
Mexico
AB, CANADA
Your project looks great.
I have one technical question. Why do you CNC a plug, as oppossed to the mold. I have seen others do this as well and I am puzzled why not straight to the mold?
Kevin M
Kevin M
ORIGINAL: wkevinm
Kevin M
Kevin M
ou can make multiple molds off a single plug, if you make a mold thats all you got
AB, CANADA
I understand, I assume this is if you are manufacturing as opposed to personal use, however I do see some guys cutting aluminum molds for the purpose of manufacturing.
What material do you use to cnc the plug it looks like a plastic of sorts.
I am only asking because I am curious about the various techniques used, I am currently making a Q500 fuse and V tail plug using traditional methods (by hand) but only for personal use.
Kevin M
Kevin M
ORIGINAL: wkevinm
Kevin M
Kevin M
This material I used is very cheaper and very fast milled...........It is a material-specific modeling prototypes (i dont know the name)
To build molds airmodel this technique is most excellent and that at the same time is cheaper
I had great teachers: the Germans .......and I have followed this forum http://www.rc-network.de/forum/forumdisplay.php?f=56
I used a similar technique to construct a wing of a F3D but in this case I used a different material(A little more expensive)..."Methacrylate "in this case I polished only . http://www.rcuniverse.com/forum/m_4594549/tm.htm
Ciao Paolo
My Feedback: (10)
MN
Ren board from Freeman supply. My R-200 wing molds. http://www.freemansupply.com/index.htm
ORIGINAL: djlyon
Hi Paolo
Which threads in the RC-Network forum provided you with the most information on the plug material.
Denis
Hi Paolo
Denis
You can see similar tenique for F3D Sweden Wing http://www.bahnhofbredband.se/~wb855...tima/start.htm
ORIGINAL: Randy Etken
My Feedback: (10)
MN
I have used two different boards light gray #5020 and red # 5179. The Ren boards have to be sanded, primed and painted after being machined to achieve a pristine surface. The gray is easy to prime and paint. The red is almost imposable to prime and paint. You need some real special products from Dura Technologies. The CNC people like this product because of the ease of machining. If I did it over I would spend the extra money and use aluminum.
Paolo,
Congratulations, very nice looking plane
If it is of any use and for you not to spend money and time, a friend of mine here in MĂ©xico submitt for approval to the AMA and NMPRA a Q40 called Extasis, which first design have winglets and they were not approved.
I see your Strega have winglets too, so I think it would be good for you to ask them before making the wing molds for preventing you to double work on your wing molds.
Good Luck and congratulations again.
VĂ*ctor Arreola.
MĂ©xico.
VĂ*ctor Arreola.
MĂ©xico.
UT
Victor,
I believe Paulo's already receieved initial approval for the airplane.
Paulo's version of Strega is based on when it did have curved up wingtips (see the pics he attached to one of his posts). While his aren't 100% true to scale, they aren't any farther from scale than the rest of the Q40's.
Isn't the Extasis a mid-wing airplane? Which one was it based on? I don't recall any real Forumula 1 type airplanes, other the the Kelly's, having wingtips like Paulo's showing. If the airplane Extasis was based on didn't have them, the model would not be approved with them.
GS
GS
