Stinger Build Thread
#126
TX
RE: Stinger Build Thread
Mask off areas that you don't want painted.
The red covers well over the light yellow base coat.
The picture shows the bottom of the wing, which is essentially all red.
#127
My Feedback: (61)
looking good, Scott! Maybe by the fall races up here I'll have a Q40 sport put together to fly. Don't hold your breath, though - right now I'm in Milan, Italy - it's Sunday morning, and cloudy & rainy. Good thing I did some sightseeing yesterday, eh? This customer could keep me busy for quite a while, running all over Italy fixing problems if I'd let them...
#129
TX
I got some vinyl stencils from the graphics shop.
Apply as needed and mask off the rest of the airplane.
Mask off the canopy as desired.
#131
TX
After the stencils are removed use wet and dry sandpaper to feather in the edges.
Some high quality 1/4" inch wide black pin stripes were applied.
The Stinger will be a good looking model.
Clearcoat will be next.
#134
TX
The clearcoat was purchased from NAPA.
It was mixed per the directions. I mixed about 4 ounces of base to 1 ounce of hardener.
I then added a small amount of reducer to thin.
A mist was lightly sprayed on the model. It was set to dry for a few minutes.
Then the clearcoat was applied until a glossy finish was achieved.
#135
TX
After the clearcoat is thoroughly dry you can wet sand it with 2000 grit sandpaper.
I then buffed it out with some white rubbing compound.
The model has a "5 foot finish". It looks great at 5 foot but if I had to do over I would put a little more Spackle and primer on the wing to fill any grain before applying color.
In the next couple days I plan to test fly it.
#139
TX
A bead of Shoe Goo keeps the throttle barrel from turning.
The music wire pinches the fuel tubing to kill the engine.
Muffler pressure is used.
#142
TX
Here is what it looks like ready to go.
It was getting late so these are flash pictures.
7/01/2009 comment -The model weighed in at 4 lbs 2 ounces. I added about an ounce of weight to the tail to balance.
The minimum weight for 422 class is 4 pounds.
#146
TX
I used 3M clear tape that is purchased from Darrol Cady.
http://www.darrolcady.com/Accessorie...ies_flight.htm
#147
TX
The model needed some some tail weight to balance.
If I had to do it over I'd move the servos farther back in the radio compartment. Probably 2 servos in back and one in the front would work better.
Moving the servos further back should reduce any tail weight.
#148
Super job Scott.Just like the others you've finished and shared with us. I know the I am always eger to see the techniques other modelers use to build and finish a model. You never know when an easier way to do something will pop up. Thanks for taking to time to share your work with all of us.
Arch
Arch
#149
TX
Don,
You can post the pictures on your site. The model flies great.
As with all test flights it was on the windiest days of the week.
Probably 25 mph winds. The wind sock was standing straight out.
It was off the ground in a few feet. It needed some up elevator but otherwise flew great.
I had incorrectly added some down elevator to the horizontal stab. If you build it with the stock tail incidence you will be correct.
The model will track around the turns without gaining or loosing altitude. It also tracks at 45 degrees all around the course.
You've got a winner of a kit. I think your modelers will like it.
Scott
Scott
#150
TX
Here are some notes based upon flying:
I balanced the model at 2.25" back from the leading edge of the wing. It took a small amount of tail weight to get there.
For the first flight the low rates on the elevator and elevator were about 3/16" each way. The rudder should be about 3/8" each way.
On high rates use about 1/4" each way on elevator and about 5/16" each way for ailerons.
I use about 20% exponential on ailerons and elevator.
After flying the model it identified that the stock incidence on the tail was correct.
Align the horizontal stab based upon the molding and glue it on.
Many fun flights to all![8D]
