Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
Hard landing
Reply
Old 05-30-2010, 05:09 PM
ecoliburger
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Hard landing
Any of you guys ever had servo break from a hard landing? maidened this thing today, second flight I notice the switch is loose. Take it apart at home and find this: Servo mount busted and switch mount broke off as well. Bounced the landing but I didnt think it was that hard, only tweaked one gear a little no wing damage. Doesnt seem to be vibrating very bad? Any ideas?
ecoliburger is offline
Old 05-30-2010, 06:01 PM
djlyon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Hard landing
Old rotting plastic Maybe both had a crack before you installed them and you didn't notice. The only thing I can imagine might do that is if the servo is bottoming out against the fuselage. But I even doubt that.
Denis
djlyon is offline
Old 05-30-2010, 06:29 PM
TIA
TIA's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Never seen that before in my life!
Brand new servo? Maybe you torqued it down too much and cracked it straight across....
TIA is offline
Old 05-31-2010, 08:51 AM
ecoliburger
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It was an older servo, didnt tighten it too much but maybe it was cracked.
Old 06-04-2010, 07:32 PM
garys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Could be that the servo was mounted in a way that the front and rear mounting blocks could flex in different directions since they aren't tied together...the resulting flex is what broke the servo. Most Q40 racers use an 1/8" ply tray to mount all three servos in the fuse as well as the switch. One tray gives a much larger glue area to the fuse and is stiffer.
garys is offline
Old 06-04-2010, 09:29 PM
ecoliburger
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So the plot thickens, this makes no sense to me. I've been flying over 20yrs and never seen anything like this happen. So I got to take a closer look tonight and found that all of the servos are broken in a similar fashion and the receiver is all cracked and not working as well. Apparently I hit hard enough to crack everything inside the fuse but not damage the wing??? Any ideas?
Old 06-04-2010, 11:08 PM
djlyon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good chance it's a hard hit and like Gary says you don't have a tray. You are mounting each end of the servo independently to the fuselage so that the servo housing is bearing the brunt of the impact flex in the fuselage rather than a servo tray. Also it looks like you have mounted the receiver to the fuse with Velcro without a thin piece of foam in there. That could have made a hard life for the receiver. I normally use two layers of Velcro with a thin sheet of foam between them.
Denis
djlyon is offline
Old 06-04-2010, 11:10 PM
garys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I stand by my thought that the way you have the servos mounted, with seperate mounting blocks for the front and back of the servos, allowed enough flex that it snapped the mounting lugs. As you said it "only tweaked one gear a little no wing damage". The plane very well may have hit in such a way that it twisted the fuse but didn't really put much load on the wing. It wouldn't take much twist to put enough force on the servos to snap the lugs. Personally I'd completely change the radio install to one single tray to mount all three servos and the switch.
garys is offline
Old 06-05-2010, 11:29 AM
ecoliburger
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the suggestions.
