Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
Jett QM Questions
Reply
Old 06-14-2010, 12:12 PM
rbg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Jett QM Questions
The Engine has lost 5K RPM WHY?
I ran it in on a bench with an FAQ prop. 3 cycles. to break in.
Put a 7.4 X 7.6 prop on and flew it 4 times real rich blowing smoke never on the pipe.
Put after run oil in it and took it home.
Following weekend (yesterday)
Used the same fuel and couldn't get peak over 18K.
Engine when cold still sqeaks at TDC.
Any suggestions on getting the 22K back?
rbg is offline
Old 06-14-2010, 12:41 PM
diggs_74
diggs_74's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Jett QM Questions
I just had the same thing happen to me last night.. Changed the plug and all was good.. The plug looked good and seemed to glow fine but obviously it was short on heat..
diggs_74 is offline
Old 06-14-2010, 01:00 PM
rbg
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Lee..
rbg is offline
Old 06-14-2010, 01:32 PM
Mikey D
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm thinking one or your issues is your selected prop. We run a 7.4 x 7.5 Prop, 7.6 may be just a smidge to heavy?
Should peak 24 to 25 but most likely 25+ for a good motor. Launch around 22.5 to 23 with a 7.5 prop.
BTW, I am speaking in context of the QM2
Mike D
Mikey D is offline
Old 06-15-2010, 07:02 AM
diggs_74
diggs_74's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 7.6 should spin up to 22K no problem.. Still think it's the plug..
diggs_74 is offline
Old 06-15-2010, 12:41 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
take the muffler off and see if the sleeve has turned in the case. check the headbolts and retorque them. try a new plug, double check the prop and make sure its not a 8 pitch.
daven is offline
Old 06-16-2010, 12:14 AM
bigtrev@xtra.co.nz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When do you take the glo leads off the plug...........the JETT is a cold engine and needs, I believe the leads on the plug until after you've needled it to full rpm- then take them off the plug.what plug are you running?Makes a difference.....suspect you're plug is the problem though.
regards trevor hnz
bigtrev@xtra.co.nz is offline
Old 06-16-2010, 03:15 AM
Vendata
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Trevor what do you mean by the jett is a cold Engine?
Vendata is offline
Old 06-16-2010, 02:26 PM
bigtrev@xtra.co.nz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave.....takes a little while to warm up. Thats why you cannot treat/tune like a nelson, big tnz
Old 06-16-2010, 02:33 PM
Vendata
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Trevor I thought that would apply to any engine ? Warm up before needling.
Vendata is offline
Old 06-16-2010, 03:06 PM
bigtrev@xtra.co.nz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes Dave, but the JETT is different, TH,
Old 06-16-2010, 11:56 PM
Vendata
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Trevor can you please explain what is the difference of the Jett engine starting proceedure, compared to the Profi & the Nelson Engines?
Vendata is offline
Old 06-17-2010, 03:13 AM
bigtrev@xtra.co.nz
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yes, I'll show you sometime, the three engines behave very differently at the warmup stage, TH
