Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
Question on Q40 tank plumbing
Reply
Old 08-21-2010, 11:42 AM
D.E.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Question on Q40 tank plumbing
I need someone smarter than me to explain running the fuel lines on this motor mount with the needle attatched. I have seen people use fuel dots and had all fuel lines internal. I was supplied with a Jett tank and it already has a fuel line installed and I dont see a way to add one to fuel it? I would like to put the shutoff between the motor and needle, is this correct? Please Help!
This is the first Endeavor with a Jett in it , It looks like it fits good but had to do a little modification to it. This is the airplane that was given away at the basin race and will be done for the Whittier race in October.
ID:	1487655   Click image for larger version
ID:	1487656   Click image for larger version
D.E. is offline
Old 08-21-2010, 11:54 AM
resourcecapital
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Question on Q40 tank plumbing
what you are going to have to do is put a fuel tee between your fuel shutoff (which will be before the needle valve assy) and the tank. use a fuel dot to remove the air from the bladder with your fuel sirnge (sp) and full the tank. you will also need (should) to install a fuel clams between the needle and engine to make sure fuel is shut off to engine.
resourcecapital is offline
Old 08-22-2010, 09:40 AM
diggs_74
diggs_74's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave,
Here's how I did it on my Vendetta.. It's Lyle's mount but the same idea.. So, I have the fuel outlet split with a mini filter then through the fuel shut-off.. I did it this way so I could fuel it without having to close the fuel shutoff with the radio.. From there it goes around the mount and into the bottom of the remote needle and then up to the engine.. Does that make sense?
ID:	1488105   Click image for larger version
diggs_74 is offline
Old 08-22-2010, 02:55 PM
D.E.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys, I guess I was trying to make it harder than it was!
D.E.
D.E. is offline
