What Rx for a JR 2.4GHz for pylon RX's would you use?????
RE: What Rx for a JR 2.4GHz for pylon RX's would you use?????
Were is the best place to place the 2 antennas In Q/500 and Q/40
1 Attachment(s)
All my 2.4 ghz installations are installed in the area above or below the wing on the inside of the fuselage.
I routed one of the antenna toward the back of the fuselage. The other one should be routed approximately 90 degrees off from the first. The antenna should be in an area that does not have carbon fiber reinforcement. |
ORIGINAL: Kevin Matney What Rx for a JR 2.4GHz for pylon RX's would you use????? |
