Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
VIPER 500 SWITCH MOUNTING
Reply
Old 05-17-2011, 04:52 AM
wvrcracer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default VIPER 500 SWITCH MOUNTING
good day all. I am a newbie to pylon racing and am assebling my first sacrificial lamb-a viper 500 for 424. With the help of some other racers in our local club i just about have it ready to race. i'm looking for some different types of ideas for switch mounting and was hoping some folks would share some pic's of how ya mount your radio switch. Thanks in advance
wvrcracer is offline
Old 05-17-2011, 10:51 AM
PylonDave
PylonDave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: VIPER 500 SWITCH MOUNTING
Most mount the switch on the front of the servo tray and run a wire or pull pull string out the side of the fuse.
PylonDave is offline
Old 05-17-2011, 11:14 AM
kane
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is a servo tray for a QM40 But the same principle applies. I use a paper clip through a hole drilled in the switch to actuate it. I use a paper clip because it is soft and easy to bend plus you don't end up stabbing yourself with the cut end of piano wire, if you choose to use piano wire. String works well too. You still drill a hole through the switch and pull the string through, knot each side so when the string is pulled it grabs the switch. The string exits the airplane on both side with enough length that it can't fall inside and you pull from one side to turn it on and pull from the other to turn it off.
DK
kane is offline
Old 05-18-2011, 09:36 AM
wvrcracer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for sharing the info. I was hoping to see a setup with the pull string. I understand how it would work n all. just hoping to see a photo.
thanks
Old 05-18-2011, 10:23 AM
Scorpion Racing
Scorpion Racing's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, here is the string method in pictures! I use gorilla string (fishing line with a cord, kinda like fly fishing line) thru a 1/16" hole drilled thru the switch and thru both sides of the fuselage. Once I pull the strings thru the fuselage, I tie 2~3 knots in it (in a bunch) so that it won't pull back thru the fuselage and then trim and melt the ends of the string with a heat source so they won't Frey. I align the switch so to the left is always on, and to the right is always off when looking forward toward turn one..
Scorpion Racing is offline
Old 05-19-2011, 03:12 AM
wvrcracer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks. Thats what i wanted to see. its just to simple sometimes
Old 05-19-2011, 04:40 AM
Alabama Racer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wv - make sure you hook up with some of those flying hillbillies. The help of
an experienced racer will make all the difference in the world in your success.
The races at the Hillbillies club were some of the most enjoyable ones I have
attended.
brad
Alabama Racer is offline
Old 05-20-2011, 10:40 AM
wvrcracer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh yea, dave n mike are hookin me up. should fly it next week. Dave makes it look easy n im ready to start racing. just gotta get the switch in it and balance it then warn everybody at the field. Im sure this is just the begining.
Contact Us Archive Advertising Cookie Policy
