Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
ViperDog Build Thread
Old 07-23-2011, 10:01 AM
  #76
sahartman21
Default RE: ViperDog Build Thread
The other end was attached similarly.
The nylon ball coupler was screwed on.
ID:	1638876   Click image for larger version
ID:	1638877   Click image for larger version
Old 07-23-2011, 10:05 AM
  #77
sahartman21
The control horns were drilled out to fit the Z-bend.
I used Z-bend pliers to bend the rods.
ID:	1638880   Click image for larger version
ID:	1638881   Click image for larger version
ID:	1638882   Click image for larger version
Old 07-23-2011, 10:08 AM
  #78
sahartman21
The throttle plastic tube (antenna tube) was slid in place.
Some Shoe Goo was used to glue the tube to fuselage side.
ID:	1638884   Click image for larger version
ID:	1638885   Click image for larger version
Old 07-23-2011, 10:11 AM
  #79
sahartman21
I used an existing gear from an earlier model.
Holes for the tap were drilled first.
The tap was used next.
A large drill bit was used to countersink the bolt heads.
ID:	1638887   Click image for larger version
ID:	1638888   Click image for larger version
Old 07-23-2011, 10:14 AM
  #80
sahartman21
A Tetra 4-ounce bladder tank is used as a CG tank.
A Dremel tool was used to fit the fuselage for the tank.
ID:	1638890   Click image for larger version
ID:	1638891   Click image for larger version
ID:	1638892   Click image for larger version
ID:	1638893   Click image for larger version
Old 07-23-2011, 10:16 AM
  #81
sahartman21
A couple 1/4" diameter holes were drilled for the silicone tubing.
ID:	1638895   Click image for larger version
Old 07-30-2011, 07:54 AM
  #82
sahartman21
I washed the exterior of the fiberglass parts to remove any last traces of release wax.
The surface was dried.
Lightweight Spackle was squeegeed over the surface to fill pinholes on the surface.
ID:	1641939   Click image for larger version
ID:	1641940   Click image for larger version
Old 07-30-2011, 07:58 AM
  #83
sahartman21
Very carefully sand the surface smooth.
Stop standing before you go through the Spackle. This prevents opening new pinholes.
Blow off the dust with an air gun.
ID:	1641944   Click image for larger version
Old 07-30-2011, 08:00 AM
  #84
sahartman21
I sprayed white KlassKote primer to the surface of the model.
About 2 ounces of part A and 2 ounces of part B were mixed.
Allow to set about 1/2 hour.
I added about 4 ounces of reducer to the mix.
This was applied with a spray gun.
ID:	1641946   Click image for larger version
ID:	1641947   Click image for larger version
ID:	1641948   Click image for larger version
Old 07-30-2011, 11:19 AM
  #85
sahartman21
You then lightly wet sand with 320 grit wet-and-dry sandpaper.
The goal is to be smooth without going through the primer.
I later found how important an even white finish, from the primer, is required.
Yellow does not cover very well. Make sure the white primer evenly covers, or spray a coat of white paint prior to applying yellow.
Old 07-30-2011, 07:02 PM
  #86
sahartman21
About 5 ounces of Acrylic Enamel car paint was mixed per the directions. About 1 part of reducer was added to 2 parts of paint.
This was applied with an inexpensive detail gun, from Harbor Freight.
Old 07-30-2011, 07:19 PM
  #87
Kevin Matney
Kevin Matney's Avatar
Looks great keep up the great work!!!!!
Old 07-31-2011, 04:03 PM
  #88
sahartman21
I've got to wet sand the paint to get a reasonable finish.
At this point the runs, bugs, and other imperfections are removed.
Old 07-31-2011, 06:13 PM
  #89
fizzwater2
My Feedback: (61)
I like the bright yellow, Scott
Old 08-01-2011, 12:24 PM
  #90
epr3
where do you get the pushrods from? I like how they look and they appear to be easy to work with
Old 08-01-2011, 05:22 PM
  #91
sahartman21
I got the carbon fiber pushrods from DarrolCady.com
Darrol sells a lot of racing products. Tell him Scott Hartman referred you.
http://www.darrolcady.com/Carbon_Fiber/carbon_fiber.htm
Old 08-01-2011, 05:24 PM
  #92
sahartman21
What's black, white, and yellow all over?
One hint, It's not a newspaper.
I used a few stickers and pinstripes to add a little personality.
The automotive clear coat goes on next.
Old 08-03-2011, 05:27 PM
  #93
sahartman21
Automotive clear coat was applied.
I used a relatively low pressure setting (20 psig) along with a thinned clear coat.
Approximately 4 to 5 ounces of clear coat was mixed. I added about 1.5 ounces of reducer to this mix.
Apply a light coat first. Wait a few minutes and then apply more coats to cover.
ID:	1644039   Click image for larger version
ID:	1644040   Click image for larger version
Old 08-04-2011, 04:31 AM
  #94
GSJames
GSJames's Avatar
Hi Scott: How do you suspend/support your wing and fuselage for painting/drying to allow full paint coverage but avoid marks? I'm currently painting a Venom. (yellow/black) See ya in Hillsdale. Thanks.
Old 08-04-2011, 04:52 AM
  #95
sahartman21
I used to try to support the wing with a coat hanger through the wing hold down bolts. This can be done to prevent marks on the bottom of the wing.
More recently I just support the wing between two boxes. I then touch up or rub out any marks on the bottom of the wing. The marks are small compared to the days marks from hanger rash and racing.
Old 08-04-2011, 08:22 AM
  #96
GSJames
GSJames's Avatar
ORIGINAL: sahartman21
OK, the coat hangar trick is what I've been using. I'm trying to come up with a clever method that is more stable than the coat hangars but still avoids marks.
THANKS!
Old 08-04-2011, 10:07 AM
  #97
PylonDave
PylonDave's Avatar
Scott, How much weight does the paint add to the model??? both the yellow and clearcoat.
Does the wet sanding and buffing of the clear reduce the weight of the clear coat???
Old 08-04-2011, 05:36 PM
  #98
sahartman21
Concerning weights, the following are the approximate contributions of each category:
1) Sandable primer (most sanded off) - 1 to 2 ounces
2) Acrylic Enamel paint - typically <1 ounce. This time the yellow paint did not cover well and about twice the normal amount of paint was added. Next time I will try applying a dust coat of white first before the yellow.
3) Clear Coat - depends on how much you spray on - from 1 ounce to around 2 ounces
Old 08-04-2011, 05:39 PM
  #99
sahartman21
I wet sanded the model with 2000 grit wet-and-dry sandpaper.
This was followed with a light rubbing compound.
Meguiar's Cleaner Wax was applied last.
ID:	1644363   Click image for larger version
ID:	1644364   Click image for larger version
Old 08-04-2011, 06:39 PM
  #100
BernieV
Scott,
Nice job, are you going to bring it up to Muncie on August 27?
