Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
Sam-Rai Composite Thread
Reply
Old 03-24-2012, 05:16 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sam-Rai Composite Thread
Sam San is now concentrating on his composite kit business.
Here is one of his Semi-Composite-Kits. His products fly great and are available at competitive prices.
Here's a link to this kit:
http://shop.sam-rairacing.com/SAM-RA...e-Kits_c24.htm
The composite versions are legal for the 426 class racer. They are not legal for 424 (Thunder Tiger) racing.
The wing weighs in at 16.75 ounces and modelers should have no problem building a racer at minimum weight.
I plan on finishing a couple other models before getting started on this one.
ID:	1742324   Click image for larger version
sahartman21 is offline
Old 09-21-2012, 06:46 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Sam-Rai Composite Thread
It's time to get back to building after a few contests. The Albuquerque race cost me a Q500 racer.
In keeping with my philosophy to minimize building time I've chosen to reuse the tail surfaces, landing gear, and pushrods.
ID:	1803629   Click image for larger version
Old 09-21-2012, 06:50 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've gotten used to the following servo arrangement. The two in the back go to the "V" tail and the other goes to the engine kill.
A tray is made from 1/8" thick plywood. Use the kit provided tray as the basis for the widths and tabs. Locate the servos and switch as required.
Drill the holes for the servo mounting screws at this time.
ID:	1803631   Click image for larger version
ID:	1803632   Click image for larger version
ID:	1803633   Click image for larger version
Old 09-21-2012, 07:00 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lay out the fuselage sides, making sure to make a right and left hand side.
I attached the fuselage doublers with 3M77. Apply a coat of adhesive to both sides. Wait at least 30 seconds and then join parts together.
ID:	1803635   Click image for larger version
Old 09-21-2012, 07:02 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Test fit parts and trim them as necessary to fit.
ID:	1803637   Click image for larger version
ID:	1803638   Click image for larger version
ID:	1803639   Click image for larger version
Old 09-21-2012, 07:07 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A piece of wrapping paper was taped to the workbench to provide a building surface.
Draw a line down the length of the surface to provide a frame of reference.
Along the line identify where the formers will be located. I used a marker and identified the appropriate widths.
ID:	1803647   Click image for larger version
Old 09-21-2012, 07:13 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
"Gorilla" glue was used to attach parts.
Begin by dampening the surfaces with water.
Apply the glue to formers.
I then used rubber bands to clamp parts in place.
ID:	1803655   Click image for larger version
ID:	1803656   Click image for larger version
ID:	1803657   Click image for larger version
Old 09-21-2012, 07:15 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The front firewall is squared by placing the nose to the wall and adjusting as required.
Old 09-21-2012, 07:17 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The top wing mounting blocks have a tendency to slide around until the glue dries.
Double check the joint and insure that the fuselage is straight before leaving it to dry.
ID:	1803660   Click image for larger version
Old 09-22-2012, 04:21 AM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I always like reading your threads. Thanks for shareing your tips.
Question...Doing the fuse doublers with spray 77 looks super quick. I never thought of that.
How does it hold up over time? Not that many of mine last too long.
vicman is offline
Old 09-22-2012, 04:45 AM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: vicman
I've attached the doublers many ways. I don't notice any significant difference with the 3M77.
I've went back to the 3M77 to speed up construction.
Old 09-22-2012, 12:36 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It is easier to drill the servo mounting holes prior to mounting the servo tray.
Here's how you can drill the holes after the tray is glued in place. Begin by turning the fuselage over to provide access to the bottom.
Mark the location of the screws with a sharp pencil. Remove the servos and drill accordingly.
ID:	1803819   Click image for larger version
ID:	1803820   Click image for larger version
Old 09-22-2012, 12:41 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The fuselage top and bottom surfaces are sheeted with the provided 1/8" thick balsa sheets.
I glued on the sheeting with CA.
The bottom of the fuselage behind the motor firewall was left unsheeted. This provide access to the back of the firewall for installation of fiberglass or carbon fiber fabric.
ID:	1803822   Click image for larger version
ID:	1803823   Click image for larger version
ID:	1803824   Click image for larger version
ID:	1803825   Click image for larger version
ID:	1803826   Click image for larger version
Old 09-22-2012, 05:16 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The nose moment is a little short and may cause you to add nose weight.
Lengthening the nose will reduce the amount of nose weight required. I added a 3/8" thick piece of plywood to lengthen the nose.
ID:	1803864   Click image for larger version
ID:	1803865   Click image for larger version
ID:	1803866   Click image for larger version
ID:	1803867   Click image for larger version
Old 09-22-2012, 05:21 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The blind nuts are installed in the back of the firewall and pulled flush with the 6 x 32 bolts.
A drop of oil is applied to the bolts to keep glue from sticking.
Strips of carbon fiber were glued in place with medium CA.
ID:	1803869   Click image for larger version
ID:	1803870   Click image for larger version
Old 09-22-2012, 05:24 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The landing gear was attached with button head bolts and blind nuts.
ID:	1803872   Click image for larger version
ID:	1803873   Click image for larger version
Old 09-22-2012, 05:25 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After about 6 hours of work the fuselage looks like this.
Old 09-29-2012, 04:14 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Align the wing to the fuselage and tape the wing on.
Drill, tap, and countersink for nylon bolts.
This step takes about an hour to complete.
ID:	1806102   Click image for larger version
ID:	1806103   Click image for larger version
ID:	1806104   Click image for larger version
ID:	1806105   Click image for larger version
ID:	1806106   Click image for larger version
ID:	1806107   Click image for larger version
Old 10-07-2012, 07:26 AM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Next is making sure the tail surface is ready to attach.
I begin by identifying where to place the level.
There should be plenty of room for the torque rods.
ID:	1808791   Click image for larger version
Old 10-07-2012, 07:31 AM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing is attached and parts are set on a flat surface. You block up the tail as necessary until the wing is level. An incidence meter is used to confirm that the wing is level.
The tail surface is checked for level with a simple string level. Adjust as required until parts are square and tack the tail in place with CA.
ID:	1808793   Click image for larger version
ID:	1808794   Click image for larger version
Old 10-07-2012, 07:33 AM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Small pieces of balsa sheet are glued in place under the tail surface.
A piece of balsa is fitted and then glued between the "V".
ID:	1808796   Click image for larger version
Old 10-07-2012, 07:35 AM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Use a sanding block to shape the fuselage as required.
ID:	1808808   Click image for larger version
Old 10-22-2012, 07:16 AM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I reinforced the landing gear block with a piece of 4 ounce fiberglass cloth. The tail was reinforced with 1.6 ounce cloth.
ID:	1813895   Click image for larger version
Old 10-22-2012, 07:19 AM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Spray a light amount of 3M77 to the wood to tack the fiberglass cloth in place. This time I used 1.1 ounce cloth.
ID:	1813897   Click image for larger version
ID:	1813898   Click image for larger version
ID:	1813899   Click image for larger version
Old 10-22-2012, 07:21 AM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Three layers of 1.6 ounce cloth were applied over the nose to provide strength.
ID:	1813901   Click image for larger version
ID:	1813902   Click image for larger version
ID:	1813903   Click image for larger version
