Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
skinned hinge materal
Reply
Old 04-05-2012, 05:12 AM
BenG60
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default skinned hinge materal
I see a few different ways of making a skinned hinge, and a few different materals being used, has any of you tried laying 2 layers of 1.4oz glass cloth on the bias over the hinge area on top of the .75 cloth, and then bag it, ?
BenG60 is offline
Old 04-05-2012, 06:30 AM
PylonDave
PylonDave's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: skinned hinge materal
Yes, but i do it below the .75 top layer. It works great.
PylonDave is offline
Old 04-05-2012, 12:28 PM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
After having the glass and even carbon break down over time I now use kevlar for the hinge.
vicman is offline
Old 04-06-2012, 04:16 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've used an extra layer of 2 ounce fiberglass cloth for the hinge. It was not biased though.
The fiberglass cloth hinge looked the best initially but gave up after a few flights.
Many people swear by Kevlar fabric. If you have it then use it.
I'm now using taffeta, peel ply, or window shear material and have not had issues with hinge failure. With any of these materials you must seal all the pinholes or they will be visible after painting.
sahartman21 is offline
Old 04-06-2012, 07:32 PM
djlyon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use epoxy based sheet fiber glass .005 thick CAed in place. Never had an issue or failure.
Denis
djlyon is offline
Old 04-07-2012, 06:17 AM
Scorpion Racing
Scorpion Racing's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Ben. I use a couple of different methods. If the wing is a foam core balsa sheeted than I use the .005 fiberglass sheets (G10 sheet) cut on the bias and applied with laminating resin. This has held up to 424, 426 & 428 speeds with no issues. For a molded wing, I have been using a peel ply hinge under the .75 oz. fiberglass outer skins. I have also had no issues with this method but have only been testing them for about 6 months. I know others who have used peel ply hinges or nylon strips also with great results. Here are some pictures of the foam core tail and main wing with the sheet hinges, and the molded v-tail with the peel ply hinge.
ID:	1747685   Click image for larger version
ID:	1747686   Click image for larger version
ID:	1747687   Click image for larger version
ID:	1747688   Click image for larger version
Scorpion Racing is offline
Old 04-10-2012, 04:02 AM
BenG60
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
thanks for all your input ive used the .10 glass board on the bias for ail on a foam core wing, but having to sand down the surface to get the board flush, and then filling every thing around it is pretty time consuming, just trying to look for somthing quick and clean
BenG60 is offline
Old 04-10-2012, 04:48 AM
twitte1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ben, check this link to a build thread for a wing. The way that Scott does his hinges you will not have to fill around the hinge to make it flush.
http://sempra.org/phpBB3/viewtopic.php?f=8&t=34
Trey
twitte1 is offline
Old 04-11-2012, 01:29 PM
djlyon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mask over the glass sheet hinge before glassing the whole wing and glass right over the masking tape on the hinge. After the glass sets up cut around the edge of the masking tape and lift it off. Now with a little lite sanding you have a flush fit and no gaps. I like really easy also.
Denis
djlyon is offline
Old 04-12-2012, 07:50 AM
Scorpion Racing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Denis, that is a good idea with the .010 hinges. I prefer to use the thinner .005 thickness so that I can leave the .5 or .75 oz. cloth on top of the hinge. That allows me to sand everything flush and then add the final fiberglass layer over the entire surface. I also like the idea of the hinge glued in place top & bottom!
Where is Dave Norman, he started this crazy method!
Old 04-12-2012, 08:33 AM
djlyon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
He sure did. All I have done is refine it a little to suit me. And suiting me means making it easy and fast.
Denis
djlyon is offline
Old 04-12-2012, 12:24 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It wasn't me actually but a local racer here that showed me... I just showed you guys
daven is offline
Old 04-12-2012, 12:25 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I love your idea with the Tape Denis!
daven is offline
Old 04-12-2012, 04:01 PM
djlyon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave I made 3 or 4 planes exactly your way and decided that skinning out a seat for the henge and sanding it was too much work. Especially because had to do some filling to take care of my much less than perfect job. That's when I came up with the masking tape idea. I cover my tails with 2 layers of 2oz cloth for stiffness. I use .005 mil sheet for the henge and mask for the first layer of 2 oz cloth. The second layer I don't mask and glass over the henge. That gives me a good henge with enough stiffness and it is smooth. Here's a couple of pictures.
Denis
Rats, the pictures are too little to tell much.
ID:	1749516   Click image for larger version
djlyon is offline
Old 04-13-2012, 01:20 PM
djlyon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Better pictures. You can see there is almost no indication that a sheet glass henge is used.
ID:	1749789   Click image for larger version
djlyon is offline
