Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
pics of mh27
Reply
Old 10-11-2012, 05:31 PM
BenG60
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default pics of mh27
Here are the pics I said I'd post of it finished.
ID:	1810408   Click image for larger version
ID:	1810409   Click image for larger version
ID:	1810410   Click image for larger version
ID:	1810411   Click image for larger version
ID:	1810412   Click image for larger version
BenG60 is offline
Old 10-11-2012, 05:53 PM
vicman
My Feedback: (10)
vicman's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: pics of mh27
Wow!
That is a great looking plane. A+ on the finish.
vicman is offline
Old 10-12-2012, 10:17 AM
qm40dego
My Feedback: (53)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks really good and fast........
qm40dego is offline
Old 10-12-2012, 04:46 PM
mikegordon10
mikegordon10's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hard to believe that there is enough room in the stinger for the two internal linkages. Are they both ball joints?
mikegordon10 is offline
Old 10-12-2012, 04:57 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks great! where in Nor Cal is there Q500 racing? Most of what I have heard/participated is warbird racing.
speedracerntrixie is online now
Old 10-12-2012, 06:51 PM
BenG60
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for the comments on the finish and yes, they are ball joints. They almost touch each other and the fuse is about 1/16 or less just around the ball joints. We practiced at an abandoned air strip here in central California. There are a few guys that show up from the bay area. We will fly it tomorrow, will let you know how it flies.
BenG60 is offline
Old 10-12-2012, 08:08 PM
speedracerntrixie
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I may have to just throw together a Q500. Don't have any .40 engines but I do have a Rossi .45 and Ultrathrust muffler. Used to race Q500 when I was a teen. I think I may have been one of the first to do a shoulder wing V tail. It was a modded Scat Cat. There were no electronic mixers back then so had to do a sliding tray setup. Could never get it to center so it was the first and last V tail. I have been wanting to build one for a few years now. Funny though, the warbird racers I have no are much faster then any of the Q 500's I've had in the past.
Old 10-13-2012, 12:08 PM
BenG60
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well the mh27 made it through four flights unscathed. Jacob flew it today. You would think 3/8 of an inch on ailerons would be enough for landing, but its not. Coffey and myself opted not to fly it, due to it being so windy. Hopfully in the morning it wont be as windy, and we will give it a try.
BenG60 is offline
Old 10-14-2012, 05:25 AM
GSJames
GSJames's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: BenG60 We practiced at an abandoned air strip here in central California.
Crow's Landing?
GSJames is offline
Old 10-14-2012, 05:14 PM
BenG60
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, we practice out at Crows Landing and again the mh27 came through unscathed. Coffey and myself flew it today, the cg was at 2 13/16 when Jacob flew it yesterday and it only took about a 1/16 of an inch of elev to get it to turn pretty tight. I felt it was too tail heavy for my liking. Coffey and myself flew it today so I changed the cg to 2 11/16 and turned the elev up to 3/32 on low and doubled it on high. The take offs are pretty good and pretdictable, the plane seems pretty fast, and as long as you keep it banked its predictable It really doesn't like level flight, but it does fly pretty good banked or through a turn. Now for the landings, after it starts slowing down you pretty much loose the ailerons, and need to start using some rudder. You also need to push the nose down as it looses more speed, you need a lot of elev to geet it to flair.
BenG60 is offline
Old 10-15-2012, 07:54 PM
speedracerntrixie
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not sure I would enjoy flying it like that. Sounds like the CG is still aft. I know that aft CG means fast but at a certain point it also means more corrections on the course and that is lost speed. I would not have beleived that 3/32 of elevator travel would be enough to land anything. My V tail experience ( mostly sailplanes ) tells me that at slow speeds they are less effective. Are you running any aileron differential? I have found that when differential is set up correctly the ailerons are a little more positive. Still wish there was some local Q500 racing. If there was I would have to cut some wood and melt some foam to get one together.
Old 10-16-2012, 01:53 PM
kommander
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Actually there was a race in Woodland in September & there will probably be one in Sept. 2013. Quickie has changed in the last year, it now requires a spec engine which is the Jett 40 or 426 engine. The airframes are pretty much the same (mostly composite) except the minimum weight is now 3.75 Lbs. Right now speeds are around 160 mph. Bruce
kommander is offline
Old 10-16-2012, 03:16 PM
DHULEN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ben, just wondering what kind of epoxy do you use on your wood fuses. Because mine tend to yellow if I leave it natural wood. Its not my clear because only shows up on the natural wood. Just curious
Duane
DHULEN is offline
Old 10-16-2012, 06:20 PM
HighPlains
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glad to see that Crow's Landing (the old Naval Air Station) is still being used. I did all my Formula One practice there back in the 80's and early 90's with the late great Jim Kelly. We also had a number of races there with lots of guys from southen California, and Washington state there. Hundreds of acres of unforgiving concrete about 5 feet thick.
HighPlains is offline
Old 10-16-2012, 07:03 PM
BenG60
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The plane is ok to fly, it's the landings that are a little hairy. For flying it has 3/32 on elevator and 1/8 on aileron. When you kill the engine, you switch to high rates, which are aprox 3/8 of an inch of travel on aileron. With some differential, the elevator is just over a 1/4 inch of travel. After the plane slows down some it does seem tail heavy, but when you try to get it to flair for landing it seems nose heavy. That's the best way I can explain it. Kommander would probably agree to this. The airfoil of the mh27 is pretty radical, most of the q500 that are out there like the cg between 2 3/4 to 3 1/8. We are still playing with this one, but it seems it may not like it that far past 2 3/4. It's still at 2 11/16 now. I'm going to put this plane away for Jacob to fly it in the next contest since he likes it so much. The finishing resin is z poxy, and then sprayed with automotive urathane clear. And yes, it will yellow some in time. I'm going to build one more, but this one is going to have a longer nose with a longer tail moment and a conventional tail for Kommander. It's going to stick out like a sore thumb.
BenG60 is offline
Old 10-17-2012, 03:30 AM
luv to race
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ben,
Everything you describe about this plane, bleeds either "Tail Heavy" or the wing incidence is off... Here is the best advice: CG the plane at 2.5" inches.. Set the low rate elevator at 1/8"-3/16", somewhere between there... set the high rate elevator at 1/4"... and go fly it! Then just add lead weight to the tail as you think needed.
The ailerons are probably not cut deep enough into the wing. I'd bet at slower speeds the air loses contact with the wing as it moves past the high point. Thusly if you ailerons never see the air at low speeds. The only fix to that is when you lay up the next wing, try and build it so that you have 2" deep ailerons..
Good luck guys...
Randy
luv to race is offline
Old 10-17-2012, 06:27 AM
BenG60
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Randy , when kommander had sam lay up this wing, he had sam put the ailerons out on the tips, 11 inches long and 2 inches deep. because the wing has some washout, aprox 2 tenths. that starts aprox 12 inches from each tip, I set the wing to the wash out, I dont know if this was right ,but we felt this was as good a place to start with as any. it very well could still be tail heavy
BenG60 is offline
Old 10-18-2012, 08:14 AM
kommander
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Duane, If you want a resin that is clear and doesn't yellow you might want to try Aerospace Composite Products E-Z lam. It comes with two choices of hardener 1/2 hr. & 1 hr.
It's kind of an all purpose resin and sands well.
Old 10-18-2012, 08:26 AM
DHULEN
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok thanks
Duane
DHULEN is offline
