Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
Sheet a Q500 Wing
Old 10-09-2015, 07:01 PM
sahartman21
Default Sheet a Q500 Wing
The following provide the basics to sheet a foam core wing. Kevin Matney (from Matney's Models) taught me the basics and now this information is being provided to you.
The cores shown were purchased from Don Stegall. Over the years Don has provided cores and sheeted cores for some of the popular Q500 racers.
I purchased the 10.5" x 48" by 1/16 balsa sheets from National Balsa. Contest or Light grade balsa wood is recommended.
Two sheets were joined using masking tape to make a sheet resembling a book cover.
ID:	2124614   Click image for larger version
Old 10-09-2015, 07:07 PM
sahartman21
I followed by adding a 3" wide strip of 2 ounce fiberglass cloth at the top and bottom of the sheeting.
Begin by marking the location of the cloth (both top and bottom sheeting) using a marker.
Follow by lightly spraying the sheeting where the cloth will go.
Then follow by laying the cloth in place.
ID:	2124618   Click image for larger version
ID:	2124619   Click image for larger version
Old 10-09-2015, 07:15 PM
sahartman21
For this model I chose to make the leading edge out of carbon fiber tow. This process makes a strong leading edge but adds about 0.3 ounce to the final weight vs. a balsa leading edge.
Two screwdrivers were used to make to jig to hold the carbon fiber tow.
Ten strands of tow (12K) to make up the leading edge.
http://www.cstsales.com/carbon_tow.html
The tow needs to fill the void between the sheets once they are folded over. The 10 strands fills an area about 1/8" diameter.
ID:	2124623   Click image for larger version
Old 10-09-2015, 07:21 PM
sahartman21
I followed by providing identification marking on the cores.
I used a marker to identify the top and bottom of the core and shucks.
Additional marking was added to the edges of the cores. This makes it easier to identify when the cores are straight within the shucks.
ID:	2124625   Click image for larger version
ID:	2124626   Click image for larger version
Old 10-09-2015, 07:29 PM
sahartman21
Adding waxed paper to the shucks helps to prevent them from getting stuck to the wing.
A light mist of 3M77 was applied to the shucks and the waxed paper was laid in place.
ID:	2124628   Click image for larger version
Old 10-09-2015, 07:37 PM
sahartman21
The location of the carbon fiber laminate (7 thousandths) was marked on bottom wing skin and the carbon was tacked in place with 3M77 adhesive.
http://www.cstsales.com/carbon_laminates_48.html
Generally you should attempt to place the carbon fiber at the thickest location of the wing. I placed the carbon about 5" back (4 1/8" to the front of the carbon) from the leading edge of the wing.
ID:	2124630   Click image for larger version
ID:	2124631   Click image for larger version
Old 10-09-2015, 07:46 PM
sahartman21
The location for the vertical carbon fiber sheer was identified by looking at one of the wing tips and identifying the center of the laminate (on bottom sheeting).
This was approximately 4 1/4" back from the leading edge.
Mark the location for the carbon fiber sheer. I used a piece 18" x 1/2 x 14 thousandths.
A slot was cut using a razor saw.
ID:	2124633   Click image for larger version
ID:	2124634   Click image for larger version
Old 10-09-2015, 07:54 PM
sahartman21
At this point I verified the vacuum pump still worked by plugging it in and listening for the hum.
I make vacuum bags using 4 mill thick pieces of plastic tarp. My favorite is about 36 wide and is cut longer than the wing span.
A piece of rope provides the path for the vacuum.
Caulking will later be used to seal the edge of the bag.
ID:	2124636   Click image for larger version
ID:	2124637   Click image for larger version
ID:	2124638   Click image for larger version
Old 10-09-2015, 08:01 PM
sahartman21
I mixed 1 1/2 ounces of finishing epoxy for use on the vertical sheer, the leading edge, and wing sheeting.
I prefer to thin the epoxy about 10% by adding a cap of 91% alcohol. This makes it spread easier and allows you to use less on the wing.
Epoxy was spread on the vertical sheer and then it was slid in place.
Some epoxy was applied to the carbon fiber tow and it was laid on the sheeting.
ID:	2124640   Click image for larger version
ID:	2124641   Click image for larger version
ID:	2124642   Click image for larger version
Old 10-09-2015, 08:07 PM
sahartman21
I had about 0.8 ounce of finishing epoxy remaining (from the original 1.5 ounces) and this was used on one wing half.
A squeegee (type used for car body work) was used to spread the epoxy to the skin. The picture is prior to spreading out the epoxy.
About 0.75 ounces of finishing epoxy was mixed for the other side and the earlier steps were repeated.
Old 10-09-2015, 08:15 PM
sahartman21
The bottom shuck was placed under the bottom wing sheeting.
About 1/4" of sheeting should be visible in front of the foam leading edge. This space is for the addition of the carbon fiber tow.
Once the core is properly positioned pin the core in place.
ID:	2124645   Click image for larger version
Old 10-09-2015, 08:21 PM
sahartman21
The top sheeting was folded over and placed on top of the cores.
The top shuck was added and aligned as needed.
They were pined and taped in place.
ID:	2124647   Click image for larger version
Old 10-09-2015, 08:30 PM
sahartman21
The package was then placed on the plastic tarp.
A piece of rope was located at the back of the cores. The rope provides the path for the vacuum.
Latex caulking provides the seal around the edge of the vacuum bag.
The tarp was folded over onto the caulking and edge was pressed to seal.
The vacuum pump was turned on. It is set to cycle and provide about 6" of Hg vacuum.
I always check for leaks around the caulking seals. Particularly review an area that has folds in the tarp and address accordingly.
ID:	2124649   Click image for larger version
ID:	2124650   Click image for larger version
Old 10-10-2015, 08:05 AM
sahartman21
The wing was removed from the bag by cutting off the outside seal that contains caulking.
Follow by using a sanding block (with 60 grit paper) to true up the leading edge. Then round the leading edge to shape.
The trailing edge is trimmed to make the wing cord 9 7/8" wide. A metal rule and zona saw work good for this process.
ID:	2124684   Click image for larger version
ID:	2124685   Click image for larger version
ID:	2124686   Click image for larger version
Old 10-10-2015, 08:08 AM
sahartman21
The rough shaped wing weighed in at 9.85 ounces at this step.
This is a good target weight for either 424 or 426 class.
Old 08-27-2016, 07:13 AM
sahartman21
Four wings were sheeted using variations of this method. At least one of the wing has a balsa leading edge.
These have been in storage until recently. In the next thread it will show how add the tips, ailerons, and cover the wing with fiberglass cloth.
ID:	2178420   Click image for larger version
Old 08-29-2016, 06:30 PM
DHULEN
Four at a time one of them must be for me
looking good Scott
Old 05-11-2019, 06:29 AM
fly4food18
My Feedback: (15)
great build. Do you have a link to finishing the wing?
Brian
