Tachometer Questions
I'm looking for some feedback on tachometers. Good experiences, bad experiences, suppliers and cost vs. accuracy. I've seen tachometer prices from $25 to $185. I'm currently competing in APRA with a goal of competing in 428 sometime in the future. Thanks.
MaxQ
MaxQ
Banned
NC
I've got the Hobbico Tach and the Globee IntelliTach and I like the Globee better even though it is significantly larger. Neither are especially good is less than good sunlight.
I like the idea of a tach like the TNC that supposedly works on cloudy days and even indoors (for electrics in my case), but I haven't been able to justify the additional funds for something that is easily mislaid or abused.
Bill has a well tuned ear from years of experience.
When I first came back to the hobby, I hated setting the needle because I had not done it in so long. Back in the 70's I always used a tach on the control line speed planes, even though I could do it by ear. It helps to have even a low cost one, just to tune the ear.
MN
Tachs
I would be lost without a decent tach. I don't normally carry it to the line with me, but its nice to tach the engine before the first heat to see if you are using the right prop. About 1-2 years ago there was a tach available from Airwild Hobbies for about $50. It is red in color, and you use to see it in the hobby magazines. I'm not sure if it is still available, but it works pretty darn good for the price.
I would suggest trying to locate one of those.
My Feedback: (133)
CA
I highly recommend the TNC. Spend $100 once and you're done. I've got a permanent ringing in my left ear - which was at least partially caused by 30 years of tuning them by ear. Wish I could pay another $100 and stop that D@^# ringing!
The TNC is rugged, reliable and will read in light too low to safely fly without lights. I'd thrown away enough cheap tachs to pay for a couple TNCs before I got one. Now everybody wants to use it!
I recommend the Master Tach from Performance Specialties.
Yes, it's likely the most expensive tach on the market at $185.00 but it has not failed me in over 15 years. I like it for a number of reasons but the main ones are:
a) Analog meter NOT digital ! I cannot stand digital tachs. You need to see the tach "sweep" the scale as you needle and pinch your fuel line etc. This is the best way to find your peak setting and then back off 500 rpm or so.
b) Multiple range settings with expanded scale. The resolution is fantastic
c) Highly reliable optical pickup. I set my tach on the ground and point it at the side of the spinner - not the prop. It reads the spinner cut out as it goes by. There is too much sunlight reflection problems with reading the prop blade. Exspecially with cheap tachs.
For me in Canada, that's a $300.00 tach but I wouldn't be without it. Especially for taching Q40 props and finding the peak. I can needle within 200 rpm and be sure of it. Cheap unreliable tachs cost you motors and frustration.
www.pspec.com then click on "High Performance Accessories", then click on Master Tach.
Randy
Randy
R.Smith, I totally agree with everything you said. I could not function without it, nor would I want to. It is the best $185 bucks I ever spent. And for like $50 to $100 bucks you can send it back in and have it recalibrated and have a new case put on it. I've had mine for about 5 years, no failures and it has become my best friend.
As far as being in a rush getting off the line and throwing your tach in you box and damaging it. Throwing my tach in my box will not save me time, running my butt off is the way to save time.
BUT - from a competitive stand point, I certainly recommend you all by some sort of digital tach. I like to have every advantage possible. :-)
R. Bridge
Team JR
R. Bridge
Team JR
Thanks for the feedback on personal tach preferences. The TNC Model PT seems to be a reasonable choice for my current level of competition.List price is 79 bucks. Any other TNC users out there?
MaxQ
MaxQ
Yeah, I get pretty frustrated with my cheap digital, I was thinking of getting one of the $100.00 digital tachs from TNC that was highly recommended to me. However, I think I would like the analog types better because you can see rate of change or sweep as Randy Smith said. With digitals you have to actually "read it". Randy, you also said it reads the spinner cutouts, what about the small metal spinners with the small holes used for tightening? $185.00....I guess I will have to save a little longer to get one of these.
Lon
Lon
OK
TNC TACH
I too finally got frustrated with cheap tachs and got the TNC PTS-10 last year. Should have saved the money I spent on the others!
The PTS-10 has a push button that changes the readout accuracy from 100's to 10's.
My .02 on the tach issue
Dan
Dan
Lon
Lon
Lon, these small holes are not an issue. The tach will not read them. The Master Tach has its own little wire stand that folds out and allows the unit to point upwards at an angle at the spinner slots while sitting nicely on the ground.
I always needle from BEHIND the right wing panel. The tach sits in front of the wing about mid span pointed at the spinner. I can see it, my caller can see it and it's great.
Randy
MN
Master Tach
I checked with Dave Schadel last week about the Master Tach and was told they were on backorder, and he was not sure when they would be available again.
Anyone know where I could get one? Even a slightly used, good condition one?
My Feedback: (31)
CA
Most tachometer today have a accuracy of +/- 1%. That translates to about 100 RPM resolution for tachs that support multiple-blade mode (2, 3 & 4-blade) which are capable of reading up to 80,000 RPM. With that said, tachs that offer read-out in 10 RPM increment vs. 100 RPM increment are essentially equal because of the 1% accurracy bottleneck. The only exception that I know of is TNC's tach. TNC tach offers extremely good accuracy and can display in 1 RPM increment. The catch is its prices is also about 4X of the average tach. Which is right for you? You would have to decide for yourself.
As for AirWild's multi-function tach, it's essentially a 3-in-1 device that contains tachometer, volt-meter, and continuity meter. Tach supports 2, 3 and 4-blade read-out, volt-meter offers two resolutions (2Vdc & 20Vdc). Continuity is for resistance measurement, great for checking cable or switch connection. I have one. For about $40 its a very worthy investment AirWild's URL is http://www.airwildhobbies.com .
Yojedi
Yojedi
Tach
Dave N.
Im not sure if you will read this before the Nat's , but I have a used one if your intereseted. It's one of the earlier ones, but works great. I'll have it with me a the Nat's if you want to check it out
Mike DeNeve
Mike DeNeve
TX
TNC Tach from PowerfLite
For all you folks out there that LOVED the TNC Tach but HATED to see it be discontinued...
Skyborn Electronics / PowerfLite R/C Power Solutions is in negotiations for the design rights to the TNC Tach. Though we have not decided on a Product Name at this point, we are now taking orders for the first run due in January 2003. It will retail for $104.95 and will be the same design as the no-longer-available TNC Tach. Same high grade optics that allow you to accurately tach your heli, jet, or prop driven model from a safe distance, even in low light, to within 10 RPM accuracy.
THE TNC IS BACK!
Best Regards
Rick Head
Marketing and Public Relations
R/C Power Solutions
[email protected]
http://www.rcpowerflite.com
972-267-5099
THE TNC IS BACK!
Best Regards
Rick Head
R/C Power Solutions
[email protected]
972-267-5099
TX
Re: Tach Pic
Originally posted by Bill Vargas
Hi, do you have a pic of this tach you are talking about?
thanks, BV
thanks, BV
Here is the picture you requested...
For raw info on the tach, go to http://www.ulster.net/~tnc/tncweb.html
What we will bring to the market is the same thing you will find there ... It may end up looking a bit different but the design is the same.
