IS a swept wing legal in 428?
CO
RE: IS a swept wing legal in 428?
Mr. Matt,
Most definitely. It is legal as long as it is constant chord and meets the span, thickness and area requirements. You could even have multiple sweep sections of the wing as long as it is constant chord. Imagine a Q500 with a wing shaped like a "W".
edited for grammar.
edited for grammar.
As John says it is legal. However pay attention to the interpretation of "Wingspan". Wingspan is measured from tip to tip at 90deg to the fuselage centre line, not down each wing panel from root to tip. To maintain 500 sq in within the max and min wingspan would result in a narrower chord wing. To maintain the correct wing thickness with a narrower chord would result in a somewhat "Fat" airfoil.
Maybe this is why a swept wing is not used very much.
Ed S
Ed S
UT
Through my interpretation of the rules, a wing with the planform shown would not be legal because of the tips. The wing must be constand chord/thickness for at least 47.5" of it's span. The trailing edge depicted int he pic looks like it would be considerably less than 47.5" Maybe "Mr. Rulebook" Ed Smith can look it up and let us know.....??
Gary Schmidt
Team Futaba
Gary Schmidt
Team Futaba
UT
Uh oh...Duane and I agree on a rule...something has got to be wrong somewhere...
Duane, go right on ahead and do your forward swept wing. Over the years, I've seen both forward and rear-swept wings, and neither one really did anything special.
Gary Schmidt
Team Futaba
Gary Schmidt
Team Futaba
AZ
I think DHG should design one with sweep forward and anhedral.
Don’t know how it would fly, but it sure would confuse everyone watching it. [X(]
My Feedback: (7)
Actually a buddy of mine built one in 1988, it had about an inch of forward sweep on each side and would turn right now. He wasn't the greatest pilot and it crashed after a few flights, so we never did manage to explore its full potential ... probably would need a stopwatch and a lot of test-flying to know for sure. But no one ever got it confused with anyone else's airplane, though. It was green. He called it the Pickle Fork.
IL
My father-in-law flew a forward swept quickee for a couple of years. It was about 2 inches. They definately turned well. He flew them back in 87 & 88 time frame with Rossi's. Those of you that don't know my father-in-law is Pete Waters.
Dan Kane
Dan Kane
Dan,
Aren't you suppose to leave there now for the Phoenix Jr Gold Cup?
Just kidding!
See you at Speedworld this Saturday since I got more questions regarding the plug mold. [8D]
Just kidding!
CO
ORIGINAL: Ed Smith
Ed S
Ed S
True enough however with the sweep, the angle of the airfoil would be parallel to the thrust line, not 90 degrees to the leading and trailing edges of the wing. This would make for a longer airfoil so it might work out to be a wash depending upon the sweep angle.
