pylon prop pitch gauge
I am looking for a good, cheap?! if at all possible? prop pitch gauge. or does anyone have plans and info on how to make one suitable for trimming pylon props.
any help appreciated
many thanks
clive
many thanks
clive
RE: pylon prop pitch gauge
This is the Prather pitch gauge. It has been around for many years. There must be hundreds of used ones out there. Enquiries in the right places will probably yield one. If you intend to make one you wil have the tedious task of having to calculate the pitch angle for however many prop stations you wish to check for every pitch you intend to use.
Good Luck!
Ed S
Good Luck!
Ed S
