Nelson Performance question
NC
What would be considered the acceptable RPM to compete in 428 for a used Q500 nelson with a 8.8 X 9 APC? I understand flying the plane around the poles to be the most important thing, but still would like to know what you guys consider acceptable RPM, or needs new sleeve, piston, whatever RPM. Thanks in advance for the comments.
RE: Nelson Performance question
depends on which Nelson it is.
The newest version is easy to spot versus the older ones
The new one has a 3/16" raised area right around the carb inlet. The older ones have the needle valve right near the opening.
The crank on the new ones has a very big hole in the middle
Look at the Perf Spec. web site for a comparsion
What daven says on RPM's is with the newer ones.
anywhere over 18,500 and up with give a scary ride.
Try a 8.8x8.5 to learn how to tune. then put the big wood on, open the needle a short 1/4 turn and try it.
