Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
Viper for Q-500
Reply
Old 07-31-2006, 10:18 AM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Viper for Q-500
Hello!
Does the Great Planes Viper hold up for a Nelson engine and is it competitive (the Viper that is).
I have Viper in our Q-500 class (We race 6,5cc sport engines, with 10x6 plastic props and 80/20 FAI fuel) and it is a very good flier and it behaves very well in the air.
Most prefered engine over here is the Webra .40 GT, as it turns a 10x6 RAM or Graupner Cam prop at 14000-15000rpm on 80/20 fuel. Speed is around 180km/h for the fastet airplanes.
Regards!
Jan K
Sweden
ID:	499635   Click image for larger version
ID:	499636   Click image for larger version
jaka is offline
Old 07-31-2006, 11:33 AM
djlyon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Viper for Q-500
Yes it will take it with some ifs. If the factory did a good job fiber glassing the wing center section so the glass is actually stuck to the wood, then the wing will take it. If you strengthen the firewall, wing mounts and fuse in front of the stab then the fuse will take it. It will be fast enough for a good set of thumbs to make it competetive.
Denis
djlyon is offline
Old 07-31-2006, 11:43 AM
djlyon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I flew my Predator with a old Webra quickie 40 and Ultrathrust muffler, 9/7apc and 15%nitro and I'm inclined to think it was hitting between 210 and 230 kph. It was turning the 9/7 around 18000 on the ground.
Denis
djlyon is offline
Old 07-31-2006, 12:35 PM
Super Splatter
Super Splatter's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I helped my partner this past weekend with a Nelson and a Viper. Yes it will work OK, add CA glue to every joint you can see that looks dry.
I glue the fuel hatch and add more glue behind the firewall for added strengh and use a skinny Jett tank installed thur the wing opening.
As far as being competitve, I 've heard of one going 1:07 or 09 when composites are doing 1:03 & 4's
Super Splatter is offline
Old 07-31-2006, 01:00 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Last I heard from the Texas group, was that they are about 2 seconds of the best composities.
Not bad, I've never flown one.
daven is offline
Old 07-31-2006, 10:03 PM
BUDMAN27
BUDMAN27's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You should give one a try Daven you just might like it or not.
BUDMAN27 is offline
Old 07-31-2006, 11:06 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With the advantage that they give the ARFs around here, I'm tempted.
I like to build, so I'll continue to run my own plane, for now.
daven is offline
Contact Us Archive Advertising Cookie Policy
