Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
fuel filter - used or not
Old 12-08-2006, 01:53 PM
ezmo
Default fuel filter - used or not
Hi
I have SC 40 with my Viper Q500. Just came up to question is fuel filter used with pylon planes or does it interfere the fuel flow with full throttle? Just noticed I have some dirt in my fueltank eventhough I have filter in the gallon tank of fuel
Old 12-08-2006, 02:43 PM
garys
Default RE: fuel filter - used or not
I use an inline filter on all my racers. As long as it's not clogged, it won't effect fuel feed. If it gets clogged, consider that it saved all that dirt from going through your engine. Here's the filter I use, along with instructions for it, and a picture of it installed on a Q40. As the instructions say, you should backflush the filter after every day of flying to keep it clear.
http://pspec.com/results.asp?category=7
http://pspec.com/fuelfilter.asp
http://pspec.com/ssneedle.asp
Old 12-08-2006, 04:11 PM
ezmo
ORIGINAL: garys
Thanks. You hardly ever see those filters on any q500 racer pics. Made me woder why, cause not using it, I would just cause problems.
Old 12-08-2006, 04:40 PM
diggs_74
diggs_74's Avatar
I wish I had one in Phoenix in Feb... Would have gained me a lot of points.. I didn't get my engine to run right unitil the last heat on Saturday and then cut out.. Go figure
Old 12-09-2006, 10:50 AM
luv to race
I use Shadel's filter on everything... FAI, Quickee and Quarter40. Never in my life have I had a clogged spray bar...never. I unscrew the 2 halves, drop a little red loctite in there.. close it back up.
Randy
Old 12-15-2006, 04:38 PM
jaka
Hi!
I never use a fuel filter in between the tank and the engine... That's just one more thing that could go wrong (leak).
Best way is to filter the fuel Before you fill the tank. Use a good auto fuel filter, not the cheap hobby stuff screen filters that's every hobby shop sells. There are small motorcycle gas filters avaiable at some motocycle shops (Lelles MC in Uppsala in Sweden) that are far better than every filter that are available in hobby shops.
But do use a Tettra "bubble less" tank if you want the best tanks. These are used world wide by all pylon racers. I have them available if you are interested
Regards!
Jan Karlsson
Airracing products
Sweden
Old 12-16-2006, 08:15 AM
Ed Smith
[quote]I never use a fuel filter in between the tank and the engine... That's just one more thing that could go wrong (leak). [quote]
Same here, The fewer connections in the fuel feed line the less chance of problems.
Ed
Old 12-16-2006, 02:10 PM
clb
Like Randy, but with Loctite blue. I prefer to fly in blue sky than red sky!!!!
Claude.
