Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
Futaba Servos
Reply
Old 03-09-2008, 04:52 PM
Conrod
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Futaba Servos
HI
Can you Futaba Guy's tell which servos you are using in your Quickies?
Thanks Geoff
Conrod is offline
Old 03-09-2008, 05:02 PM
garys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Futaba Servos
For the last few years I've been using the 9650's on aileron and V-tail, with a 3102 on throttle.
garys is offline
Old 03-09-2008, 05:11 PM
waynebang
waynebang's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use the S3002 which is a high torque/metal gear Mini servo. 1.23 ozs and 45.8 oz-in torque.
waynebang is offline
Old 03-09-2008, 08:29 PM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
9650 digis on elevators and ailerons.
3102's on throttle.
daven is offline
Old 03-10-2008, 03:00 AM
dapan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
9650 on elevators and ailerons.
3101 on throttle
dapan is offline
Old 03-10-2008, 04:53 AM
Conrod
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
9650 it is, have some Hitec 85 that I think will do the throttle.
Thanks Geoff
Conrod is offline
Old 03-10-2008, 06:01 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The 85 will work fine on throttle.
daven is offline
Old 03-15-2008, 11:03 PM
Backplate
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi you guys,
Using 9650 Futaba Servos what size battery pack are you using?
Backplate is offline
Old 03-16-2008, 02:29 AM
dapan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi
900mah sanyo eneloop aaa are my choice
dapan
dapan is offline
Old 03-16-2008, 07:22 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
4 or 5 cell 720 mah NIMHS are what I have been using.
daven is offline
Old 07-23-2008, 05:02 PM
bobcat10_4
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not to get into the question at hand,but I have a issue that has been plaguing me lately; I have had to swap-out 3 of my 3004 servos in 2 planes because they "float". By that, I mean if I run the servo(s) in one direction, and let them go back to neutral, they tend to overrun neutral by a little, then neutralize. There is another fellow pilot who experiences the same condition.
Is this humidity related? Or something deeper. I have, at times been able to take the servo case apart, expose it to low to mid range humidity\temperature, them put it back together, and it's fine.
Bobcat
bobcat10_4 is offline
Old 07-23-2008, 07:40 PM
Scorpion Racing
Scorpion Racing's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have seen that happen for a few reasons.
One was from using a long cheap (hobbico) servo extension. I replaced them with the heavy duty JR's and the problem went away.
Sometimes the connectors get corrosion or moisture on them, and this will cause it.
The other time it was just a worn out servo. (I would guess the centering pot was shot)
I would try unplugging the servo wires and cleaning them first. Then try some different extensions (if the servo is on one!) and see if it clears up. If neither of those work, I would switch the servo out.
Good luck.
Scorpion Racing is offline
Old 07-23-2008, 09:47 PM
Truckracer
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: bobcat10_4
Bobcat
The 3004 is the lowest cost, standard sized BB servo that Futaba makes. I think Tower sells them for something like $12. At that cost, if you have any problems just replace them. Perhaps your problems are related to using these low cost servos in a fairly high vibration environment like a racer and maybe they are not up to the task. Maybe moving up to a more suitable servo would be in order.
Truckracer is online now
