Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
Nelson LS and SS throttle linkage location
Reply
Old 06-08-2008, 11:37 AM
Scorpion Racing
Scorpion Racing's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Nelson LS and SS throttle linkage location
I would like to know where you guys drill the firewall for the Nelson LS and SS throttle linkage to pass thru. For the TT Pro 40 (424 class) I drill a 9/64" hole at 5/8" right and 7/32" up from the bottom (looking at the firewall) so that I can change engines from plane to plane without having to re-drill anything. I would like to know if there is a standard spot you guys drill yours for 428. That way I can be set up correctly in case I need to swap engines, or loan out a plane in 428.
I guess the best way is if you guys could just let me know how you do it!!
Scorpion Racing is offline
Old 06-08-2008, 04:35 PM
djlyon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Nelson LS and SS throttle linkage location
Drill a 1/4 inch hole. That way it will work for either the TT, LS or SS and you will have enough clearance for the ball socket so you can remove or install an engine without messing with the throttle linkage. The accuracy of the location of the 1/4 inch hole is not real critical.
Denis
djlyon is offline
Old 06-09-2008, 07:21 AM
Scorpion Racing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Denis, I have a Nelson SS but I couldn't remember if the hole drilled in the backplate mount was there when I got it or not! I think I will move my 424 mounts locations to the 5/8" Right and 1/4" up location, as well as enlarge the opening to 1/4" so I can interchange between all of them.
Thanks again!
Old 06-09-2008, 08:22 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Scott, I checked one of mine and it was 3/4" over and 1/4" up. I also use a bigger hole, not quite a 1/4", but close. I use the #1 drill bit in my numbered set. Its easiest to do with the backplate off the motor on a drill press.
daven is offline
