Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
Digital Servos
Reply
Old 06-21-2008, 03:48 AM
Vendata
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Digital Servos
Hi Guys,
I am using Futaba 9650 digital servos in Q500 424 racing class. Can any of you tell me could I use A 500 mah battery pack at 4.8 volts to run these servos in 5 heats of racing &
10 laps per heat. So I would be looking at 50 laps, & abit of mucking around. Now would I be safe to use this size battery pack? (Your Comments please.)
Dave.
Vendata is offline
Old 06-21-2008, 08:46 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Digital Servos
Nicad or Nimh?
daven is offline
Old 06-21-2008, 01:34 PM
garys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You shouldn't have any issues running a 500mah pack whether it's Nicad or Nimh (provided that it's in good shape). I typically run a 4.8volt 720Nimh, but I rarely put more than 300mah back into the pack after seven or eight flights, and usually put in closer to 250mah.
garys is offline
Old 06-21-2008, 06:48 PM
Bill Vargas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What you could do is to make the charging jack easily accessible for checking the voltage between flights,,, without having to take off the wing. If you think its to low for your standards, then all you would have to do is give it a little charge in preparation for the next flight.
BV
Bill Vargas is offline
Old 06-21-2008, 08:06 PM
djlyon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's a ditto on what Gary says. Where were you two today . It was 110 degrees with down wind take-offs with gusts to 25 mph and we didn't get started till 11:30. i am thrashed.
Denis
djlyon is offline
Old 06-21-2008, 08:11 PM
Vendata
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi there Dave, I am talking about Nicad battery pack?
Would I get eough power using Digitals 4.8 500 mah?
10 laps per haet 5 Heats 50 laps + abit of mucking around.
What do you think?
Vendata is offline
Old 06-22-2008, 05:48 AM
luv to race
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Vendata.....
Gary Schmidt answered your question. yes... 500mah Nicad or Nimh would work just fine. You could probably fly 10 heats. Therefore, flying 5 heats of 10 laps each is not going to be a problem.
Randy Bridge
luv to race is offline
Old 06-22-2008, 07:35 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
500 mah Nicads would be fine. If they were Nimh's I would recommend going up to 720. Both should be fine, I've just had better luck with Nicads in the smaller sizes.
daven is offline
Old 06-22-2008, 02:51 PM
Vendata
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys, for all your comments very great ful.
Dave
Vendata is offline
Old 06-24-2008, 09:26 AM
DMyer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How much more power drain are the typical digital servos used for racing versus the hs-225, jr3021 or jr901? I am still using a lot of pretty old stuff and will have to upgrade at some point. Still using 350 5-cell Nicad packs as well.... plenty of power for the servos I am using but I guess not for digitals?
DMyer is offline
Old 06-24-2008, 10:38 AM
djlyon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use hs 5245 digitals and some times hs5125. With the hs 5245s I've flown 7 heats with a 5cell 350 nicad without issue. But like Gary I find that I have to put about 250 to 300 mamps back after a race. I only use 500 to 750 packs now either 4 cell or 5 cell nicad or nimh. Actually I select my pack for weight and balance. Granted probably not the best reason for what pack to use but I've never had an issue with any of them.
Denis
djlyon is offline
