Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
1/64 Plywood Wing Skins Any Good?
Reply
Old 10-15-2008, 07:21 AM
BobHH
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 1/64 Plywood Wing Skins Any Good?
I’m getting ready to build some foam wings for my 428 design and was wondering if anyone would share their experiences with plywood wing skins. I’ve found the 1/64 birch plywood skins at SIG. I know a few years ago there were guys using them in 428. Are they still being used? What are the plus and minuses over 1/16 balsa skins?
Bob Harris
BobHH is offline
Old 10-15-2008, 07:22 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 1/64 Plywood Wing Skins Any Good?
Weight has been the biggest issue with 1/64 ply skins. Also, quite a bit more expensive than balsa.
daven is offline
Old 10-15-2008, 08:19 AM
BobHH
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave, My prototype came in at around 5 oz light using 3/32 standard balsa skins and solid 1-1/2 trailing edge stock. They claim the skins weigh in at 2 oz for a 12 x 48 sheet. Any structural concerns with being in compression? My calculations reveal tension would be OK. Yep cost is a factor.
Bob Harris
BobHH is offline
Old 10-15-2008, 08:51 AM
HighPlains
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A buddy built a F1 with ply skins some years ago. Really pretty job. Wing folded on about the 5th turn.
HighPlains is offline
Old 10-15-2008, 09:33 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob,
If you coming in 5 oz light, you definately want to beef up areas of your plane. If want to add it to the wing, that is fine. The trick is to get your plane as strong and stiff as possible without adding weight (or being over).
daven is offline
Old 10-15-2008, 11:10 AM
BobHH
My Feedback: (18)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dave you have a point there but if there is an issue with the skins in compression whereas they will wrinkle into the foam and fail I was wanting to know before going down that road. I though we may have some guys here who have tried it before.
Bob Harris
BobHH is offline
Old 10-15-2008, 01:00 PM
luv to race
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
why re-invent the wheel? unless it was cheaper (which it's not according to the thread) or easier to make wings?? plus your wing cores would have to be thicker to make minimum thickness when using 1/64 ply as opposed to 3/32 balsa.
I'd just stick to what you were doing. At 5oz under weight, you could glass the wing and paint it..
WC
luv to race is offline
Old 10-15-2008, 07:29 PM
Bill Vargas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've seen 424 planes with glass covered blue foam cores that did well,,, in 428 I saw one guy who did his with CF,,, it was cool. He glued his ailerons on with silicon,,, the aileron leading edge was an aluminum tube glued to the aileron/wing. It flew very well right up till he crashed or midaired or something like that.
BV
Bill Vargas is offline
Old 10-16-2008, 06:59 AM
Alabama Racer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Back in the early '90's, i used to skin my wings with 1/64th ply. That worked great
with the Rossi's we were running at the time. It made a stiff wing and was strong enough
for the Rossi. When I switched over to Nelsons, the wings were not strong enough and
folded. Around the same time, Jim Katz and Pete Rouark were using Obechi to skin
.15 quarter midget wings. However, it is not strong enough to hold up to todays speeds
and loads. The top skins collapse from compression. If you are just racing Thunder Tigers,
it might work with a spar and fiberglass inside.
Brad
Alabama Racer is offline
