Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
SERVOS
Reply
Old 10-26-2008, 08:58 PM
JEREMYB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default SERVOS
I need to get some servos for my Scat Cat.. I'm looking for some smaller ones that would work good with no proublems. Some thing good enought that would last awhile.. I perfer Hitech or Jr.. What do you guys think..
THANKS
JEREMY
JEREMYB is offline
Old 10-26-2008, 09:13 PM
djlyon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
hitec 225s
djlyon is offline
Old 10-26-2008, 10:28 PM
JEREMYB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
Should I get the metal gear ones or the plastic gear ones.. I guessing the metal ones...
HS-225MG Mighty Mini
JEREMY
JEREMYB is offline
Old 10-26-2008, 11:00 PM
Bill Vargas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
225mg's are ok but they will wear out faster than plastic geared servos,,, another good servo might be the Jr MN48's,,, or if you got money to burn, like most pylon Racers do, then I would suggest digital servos from Jr or futaba.
BV
Bill Vargas is offline
Old 10-27-2008, 06:34 AM
ckeene9
My Feedback: (-1)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
Haven't been into the racing for very long but I know that JR3421's will last in the conditions of racing. Clear as mud right?
ckeene9 is offline
Old 10-27-2008, 06:47 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
Yep, the 3421's have worked well for me, as well as the JR 3121, and the Futaba 9650. They are just kinda spendy options when the HItec 225's and/or JR MN-48 will work just fine for the Scat Cat.
What motor are you putting on the bird?
daven is offline
Old 10-27-2008, 07:02 AM
JEREMYB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
OS AX 46 What prop is going to be the best for that.?
JEREMYB is offline
Old 10-27-2008, 08:22 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
10x7 apc sport prop works great with that motor. A couple other props that work well are:
9 1/2 x 8 N
9 1/2 x 8.25 N
9 1/2 x 8.5 N
daven is offline
Old 10-28-2008, 08:42 PM
JEREMYB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
ORIGINAL: daven
daven, Thanks again for you help with everything.. I'm looking at these servos http://www.servocity.com/html/hs-225bb_mighty_mini.html , and you think I should go with the nylon gears not the meatal? right?
jeremy
JEREMYB is offline
Old 10-28-2008, 08:54 PM
Super Splatter
Super Splatter's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
225's are it ! a bit smaller, a bit lighter. Get 3 of those and an 85 for the throttle, not the 81. get the nylon
Back when Scat Cat's were it, they sold over 4000 kits a year
Super Splatter is offline
Old 10-29-2008, 01:35 AM
SSAN
SSAN's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
For what it's worth, I used many Hitec 225 in the past and was a big believer back then. However, none of them really center well and left me very frustrated at times. After I decided to spend the money and switch to the JR Mini Digital (for AMA 428) and JR MN48 (for AMA 424) with great results, I've never look back. Now, I've purchased six Futaba 3002 and S9650 and will try these out and see what happens.
I'm a Futaba guy when it comes to radio and a JR guy when it comes to servos. Although, I don't mind Futaba servos, but never had much experience with them to really comment on it. I hope these six new Futaba servos makes me a believer and not disappoint me like the 225 did.
BTW... Any of you Futaba boys have any comments on the new Futaba S3115?
I bought this one for throttle on AMA 428 Q500 and like to know if there's any known issue and will it hold up to vibration.
JB - Take it for what it's worth, but I would recommend the JR MN48 Mini over the 225 any days of the week due to good centering. But only for Sport quickie and not 428 Q500. Hope this helps!
SSAN is offline
Old 10-29-2008, 02:13 AM
garys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
I haven't gotten any 3115 servos, but it's basically a replacement to the 3101 which I had used for quite a while on throttle and fuel shutoff with no issues, so it s hould be fine. I used to use 3102's for V-tail and Q40 rudder, but have since switched to 9650's and 3150's for those (may also put 3150's on the tail of my next NemeQ's), and I've found myself with a bunch of 3102's, so I've been using them for throttle and shutoff.
garys is offline
Old 10-29-2008, 08:40 AM
diggs_74
diggs_74's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
I've tried a couple 3115's on the throttle for 424 and not had any issues so far.. I'm going to try them for a shut off in Q40 to see how they hold up..
diggs_74 is offline
Old 10-29-2008, 10:44 AM
scausey
scausey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
Gary,
When you use the S3150 servos in your Q500 .... what battery voltage do you use ... 4.8 or 6.0v ????? I have always used the 6v for more power .... Like Capt. Kirk says .... " We need more power Scotty"
Any do you use them in any of your Q40's ????
Thanks for info ..
Scott
scausey is offline
Old 10-29-2008, 01:25 PM
garys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
Scott,
I haven't yet used the 3150's in Q500, although I'm pretty sure Gino DelPonte has (not sure what b. The only planes I've had them in so far are on rudder of FAI and Q40. I've been using 4.8V NiMh's exclusively so far. If you're using 6V packs, I'd either use a regulator with the 3150's or try the 3155's (not as much torque, but faster), which Futaba's literature says are ok with 6V packs. I looked into going to LiPos with a regulator, but haven't decided to go that direction yet as the NiMh's have been working for me.
garys is offline
Old 10-30-2008, 12:54 AM
garys
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
I talked to Mike DelPonte today. He said that Gino's been using 3150's on the tail of his Q500's with 4.8V, 700NiMh battery packs, and they've been great. He's also going to be using them on his new Jerry Small "Swee Vee" Q40 V-tail.
garys is offline
Old 10-30-2008, 05:02 AM
luv to race
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
Yo G.... can you PM me Mike's contact info, please. email or phone number. thanks
wc
luv to race is offline
Old 10-30-2008, 08:47 PM
JEREMYB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
Well I think I found a servo that will work perfect.. What do you guys think about this.. http://www.servocity.com/html/hs-524...ital_mini.html it looks like its simular to the DS3421, but have the price. Its also faster and will handle more touuqe..
Thanks again,, I know I'm asking alot of questions.. I just want to get a good set up..
JEREMY
JEREMYB is offline
Old 10-30-2008, 11:29 PM
djlyon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
It's the digital version of the 225. Most of my racers have that servo. It's a good precise servo. Much better than the 225. Just don't let them stall. Like stall right at the end of travel because of control binding. They self destruct very quickly when that happens and they fail without smoke or warning. When I first suggested the 225 for the Scat Cat I assumed you weren't planning on racing it above the 424 level. The 225 s will serve you well at that level and cost a lot less. The 5245s come with only metal gears but the nylon gears for the 225 will work in it. Some guys replace the metal gears with the nylon gears after the metal gears wear out.
Denis
djlyon is offline
Old 10-31-2008, 06:57 AM
daven
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
Thankfully, there are a lot of good servos out there for racing, no matter what brand you like and most work just fine.
I've tried just about all of them and to me, the best value to quality servo I use is the futaba 9650. Never a failure, nylon gears, and one of the most economical digital minis available..
daven is offline
Old 11-07-2008, 09:16 PM
JEREMYB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
ORIGINAL: daven
9 1/2 x 8 N
9 1/2 x 8.25 N
9 1/2 x 8.5 N
Where do you find these props.. I ordered a 10 x7, but I can't find any of the others.. What does the N stand for? By the way again these are going to go on a OS AX 46
THANKS
JB
JEREMYB is offline
Old 11-07-2008, 11:31 PM
djlyon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
http://www.apcprop.com/
This where they are made and where you can buy them. With an on-line search you can find many other places you can buy them. N stands for narrow.
Denis
djlyon is offline
Old 11-08-2008, 06:19 AM
JEREMYB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
ORIGINAL: djlyon
Denis
Thanks, I never been on that site.. Looks like a good place to get my props.. Allways in stock
JB
JEREMYB is offline
Old 11-13-2008, 06:30 AM
hbutler
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
ORIGINAL: djlyon
Denis
Hello djlyon
Can you elaborate more on what you mean by "stall". I've just lost a 225 and a 5245 while I was doing a travel adjustment. I suspect what you are describing as a stall occurred. Yes you are right the 5245 when first with no indication that it was burning out. So much so that I just figured that I got some CA in the servo some how.(I just had harden balsa in the area with a lot of CA) I then moved on to the 225 and started to do the adjustment and that guy went up in a puff of smoke... In both I was toying with the travel adjustment.
So two questions...
1. Is there a servo with the same dimensions that is less susceptible to burning out when stalling? Or is this something that is all servos are likely to do? This is my first mini servo; I usually use standards.
2. What is the best way to set your travel adjustment without burning up these mini's
hbutler is offline
Old 11-13-2008, 01:33 PM
djlyon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: SERVOS
Yup your servos got killed by stall. I've killed 2 225s with stall. They were both killed by a receiver that would drive one elevator to limit when I would collapse my antenna after landing and the receiver would loose signal. The circuit board wiring burned up. After that I left the antenna up until the receiver was turned off. I killed 2 5245s one plane (ailerons). I killed 2 of them because I'm a slow learner. The ailerons were on a new composite wing with a very different airfoil that we were testing. The ailerons were very stiff close to the limit of travel I wanted on high rates. The servo would drive the surface to the limit of travel I wanted and not make any noise so I thought all was OK[:@]. It wasn't. The back force from the aileron kept the servo driving in a stalled condition. It only took a few seconds for a component on the board to fail. No smoke no burned wiring.
Now off course I make sure the surface moves freely well beyond the travel limit I want.
I believe there is a Futaba digital with very close to the same footprint but I don't know which one. I've never heard of any other servo dieing like this but I don't really know.
As I said just make sure you have plenty of free movement past where you want your travel limits. It really doesn't take much to stall one of these little servos but most buzz at you if stalled. The 5245s don't.
Denis
djlyon is offline
