Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
JR 2.4GHz for pylon RX's
Reply
Old 11-03-2008, 04:14 PM
Kevin Matney
Kevin Matney's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default JR 2.4GHz for pylon RX's
JR 2.4GHz for pylon RX's would you use
Kevin Matney is offline
Old 11-04-2008, 06:24 AM
s. wallace
My Feedback: (24)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: JR 2.4GHz for pylon RX's
I converted my 9 channel JR to 2.4 & used the AR6200 all season without any problems. It's considerably smaller & easier for me to mount in a Q-500 than the AR7000.
s. wallace is offline
Old 11-04-2008, 06:34 AM
luv to race
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Kevin,
Take this for what it's worth... Initially there were some reports of issues with the AR6200's. Those issues seem to of gone away, not sure why. Don't know if they changed something with the receiver (software, firmware)? The AR7000 is what Travis Flynn and myself have been using since the Spectrum thing hit the market. We use them in Q500, Q40, and FAI.. They are super solid, lots of range during range check procedure.
However, Like "lotus72D"... lots of guys never experienced any issues. Darrol Cady as well, he used the AR6200's in his stuff, no issues there either.
But if it was me, I'd run the AR7000's.
Randy Bridge
Team JR
luv to race is offline
Old 11-04-2008, 09:07 AM
Bill Vargas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
AR7000 stuff here for me,,, just velcro it and forget it
BV
Bill Vargas is offline
Old 11-04-2008, 12:30 PM
Kevin Matney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Were is the best place to place the 2 antennas In Q/500 and Q/40
Old 01-27-2009, 06:10 PM
BarryReade
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Kevin Matney
BUMP!! What Kevin asked??
BarryReade is offline
Old 01-28-2009, 06:55 AM
luv to race
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In my quickee's I use the AR7000, like I said above. I lay the main RX right on the bottom of the fuse, right behind the fuel tank... oriented so that the end of the RX where the antenna's are... that end is closest to the fuel tank.. and the end of the RX where the servo leads plug in is facing the towards the rear of the plane, or away from the fuel tank. I mount the remote RX with velcro against the side of the fuse, right under the rear wing bolts (just pick a side).. I use the standard 6 inch lead that comes with the RX. ON the main RX..the antenna's may curl up the sides of the fuse a little, because the fuse is more narrow than the length of the antenna's... I don't worry about it, just let the lay as they wish.
In FAI and Q40... I mount the remote receiver further back in the fuse. basically as far back as I can get it. However, I have to change the 6" wire lead between the two RX's to a 9" or 12".. I have probably 10" of separation between my two receivers in my FAI planes. I can walk over forever holding the bind button, and can't make it failsafe...until I turn the off the radio, then it failsafes. Serious range!
Randy Bridge
Team JR
Old 01-28-2009, 08:10 AM
BarryReade
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Randy, every little bit helps, especially when you are playing catch up.
Old 01-28-2009, 12:45 PM
jaka
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!
Ar6200!
jaka is offline
Old 02-05-2009, 01:36 AM
IRLJR
My Feedback: (37)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone having problems with AR7000 and carbon fiber?
IRLJR is offline
Old 02-05-2009, 07:44 AM
BarryReade
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: IRLJR
I have two of the AR7000 and plan on using them for racing. Are you having problems with yours that you think might be caused by carbon fiber?
Old 02-05-2009, 08:59 AM
IRLJR
My Feedback: (37)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Marauderer
ORIGINAL: IRLJR
I have not tried the 2.4 and AR7000 yet. Just trying to avoid any potential problems. Hoping someone here has some actual flight experience to report.
IRLJR is offline
Old 02-05-2009, 09:23 AM
BarryReade
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I was at a Quickie25 race last week and at least 50% of the guys were 2.4. I think that is nthe way to go.
