Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
Pit Bull Construction
Reply
Old 11-05-2008, 08:08 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Pit Bull Construction
Some of the recent discussion about Scat Cat got me looking for something similar. The Scat Cat is no longer available.
I wanted a low wing model that would fit full size radio gear.
A Matney's Models "Pit Bull" short kit fit my needs fine.
The kit consists of fiberglass fuselage, foam wing cores, plans, and landing gear.
You will also want to purchase glass cloth and Skin It epoxy when ordering your model.
ID:	1066297   Click image for larger version
ID:	1066298   Click image for larger version
sahartman21 is offline
Old 11-05-2008, 09:28 PM
dhal22
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Pit Bull Construction
i remembered this plane AFTER i purchased some wing cores and plans recently for a scat cat. that's alright though, i like to build anyway.
david
dhal22 is offline
Old 11-06-2008, 11:51 PM
JEREMYB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
cool.. I'm looking forward to seeing this come together.. so it gets a balsa sheeted wing?
JEREMY
JEREMYB is offline
Old 11-07-2008, 02:11 AM
Kevin Matney
Kevin Matney's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes this a standard Q/500 balsa over foam wing. I have it set up with 2 way to do the LG. 1 is the MW 5/32" wire, and 2 is with a Q/40 LG
Kevin Matney is offline
Old 11-08-2008, 02:31 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Begin by making 4 sections of wing skins.
Tape 1/16" thick balsa sheets until you have skins about 24" x 10 1/8".
Old 11-08-2008, 02:40 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I chose to use the sheet metal style landing gear.
The plans did not show the installation so I marked them up based upon discussions with Kevin.
Two pieces of half ribs are installed in front of the carbon fiber strips. They are shown approximately 4" and 5.5" from the wing center section.
Old 11-08-2008, 02:47 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This shows the half ribs installed in the wing cores.
Install them similarly to the other side
Old 11-08-2008, 02:51 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In this photo is the beginning of the vacuum bag.
It is made from a piece of 4 mil thick piece of plastic tarp.
The bag will later be sealed with latex cauking.
ID:	1068072   Click image for larger version
Old 11-08-2008, 03:06 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You mix about 1.5 ounces of epoxy per wing half.
The picture shows laying the fiberglass cloth on a wing half.
It is a 5" wide piece of 2 ounce fiberglass cloth that joins the top and bottom skins together.
This will later become part of the trailing edge and ailerons.
Old 11-08-2008, 03:13 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here I am taping a wing half with skins between the top and bottom wing shucks.
By taping the parts are held in place until put in the vacuum bag.
Old 11-08-2008, 03:19 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Install the vacuum tube, rope, and paper towel prior to closing the vacuum bag.
Apply some latex caulking around the edge. Fold the tarp over to make a bag.
Turn on the vacuum pump. It should pull down to 6" of Hg vacuum and turn off.
ID:	1068092   Click image for larger version
Old 11-08-2008, 09:36 PM
Bill Vargas
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Helpful suggestion,,, insure that the surface is completely flat with no bumps prior to pulling vacuum and placing weights on the "wet" cores. Placing weight on the wings during the bagging process on an uneven surface can induce warpage.
BV
Bill Vargas is offline
Old 11-09-2008, 09:26 AM
Kevin Matney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bill you right, I have him start with a flat surface. And then add weight and leave it on , just in case you loses the vacuum
Old 11-09-2008, 03:26 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In about 24 hours the epoxy is dry.
Turn off the vacuum pump and remove the skins from the shucks.
Remove the tape and get ready for the next step.
Old 11-09-2008, 03:39 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Align the cores until they are straight.
Mark a line flush with the edge of the cores.
The wood that overlaps will be cut off.
Old 11-09-2008, 03:41 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Trim off the extra wood where was marked.
Use a sanding block to true up the edge.
Old 11-09-2008, 03:43 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Glue on the leading edge with epoxy.
Tape on parts to hold in place until they are dry.
Old 11-09-2008, 06:35 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
One of the reasons I chose the "Pit Bull" was because full size servos can be used in the model.
Below is a sketch showing one way to install the servos.
Old 11-15-2008, 04:28 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Shape the leading edge of the wing with a sharp knife.
Next use a razor plane and then finish with sanding paper.
I typically just try to get two similarly shaped leading edges.
Old 11-15-2008, 04:31 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The trailing edge is shaped with a razor plane first.
Next use sandpaper to achieve a uniform shaped trailing edge.
Old 11-15-2008, 04:33 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Use a sanding block to true the edge for joining with about 5/8" of dihedral.
Old 11-15-2008, 04:44 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Join wing halves with 30 minute epoxy.
I taped the joint so that resulting edge is relatively smooth and doesn't require much sanding.
Old 11-16-2008, 03:20 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Draw lines about 7/8" above the bottom of the fuselage.
Old 11-16-2008, 03:24 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Make a servo tray out of 1/8" plywood.
CA a couple balsa strips just below the line that was drawn earlier.
Test fit the servo tray and when it fits properly glue it in place using Goop or Shoe Goo.
Old 11-16-2008, 03:27 PM
sahartman21
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I installed the servo tray near the back of the radio compartment.
A couple small holes provide access to the rear servo screws.
