Q-500 Racing Discuss AMA 428, AMA 424, and any other variants of Quickie 500 racing
Airfold MH16
Old 11-05-2009, 05:58 PM
Vicen
Default Airfold MH16
Hi,
Download profile MH16 in DXF ??
Thanks!
Old 11-06-2009, 07:49 PM
GSJames
GSJames's Avatar
Default RE: Airfold MH16
Unfortunately, this forum only allows for the upload of certain types of files, most of which are image type formats. Fortunately, it DOES allow for a .txt file to be uploaded and since .dxf is a plain text ASCII format, I was able to add a ".txt" extension to the .dxf file and upload it for you.
Attached is a 10" chord MH16 airfoil in .dxf format. Just download the attached file and rename it as "MH16.dxf" without the .txt at the end and it should import to your CAD program just fine. I hope this is helpful to you.
File Type: txt
Old 11-09-2009, 10:18 AM
Vicen
Thanks Gary, but not found.
My CAD version is 2004. What version is your CAD?
Vicente.
Old 11-09-2009, 04:18 PM
GSJames
GSJames's Avatar
OK, try this one. It is in dxf R2000 format, if you have a 2004 program, it should open it. You must rename the file first however. Download and rename the attached file as MH16.dxf Let me know if this works.
File Type: txt
Old 11-11-2009, 12:57 AM
Vicen
Perfect! Found.
Thaks Gary!
Old 11-11-2009, 10:34 AM
GSJames
GSJames's Avatar
ORIGINAL: Vicen
Perfect! Found.
Thaks Gary!
You are welcome.
