Should GP Viper have 2 Degrees positve incedence on tail ?
My Feedback: (12)
RE: Should GP Viper have 2 Degrees positve incedence on tail ?
Ed thank you for that information. Do you know if the New Great Planes viper needs the modifications that have been posted in the distant past.
I plan on using plastic bolts to mount the wing. The question is should I strengthen the tail section? Thanks again. Dan
Hi!
I have built two Vipers!
The first one 4-5 years ago and the second 3 years ago. The first one powered by a Webra GT .40 required only slight up trim on the elevator (1-2,5mm). The second one powered by a LS Nelson required 3-4mm up trim.
I nearly lost the second Viper due to a tail braking just in front of the V-stab ( You can see the crack in the fuselage in one of the pictures below ) I was very lucky as I had flown the plane twice and was about to fly a third time when it suddenly began to rain...and when the rain shover had stopped I decided to wipe the plane clean for third flight. Then I noticed the crack in the fuselage...
So I decided to strengthen the area inside the fuselage with a layer of 3mm balsa and 25g glassfiber/epoxy on the out side, and at the same time lower the V-stab up front 3mm to get ride of the undesirable elevator up trim.
Luckily for me the plane flew with no up trim at all after the fix.
So I expect all Vipers have a slight up trim problem as standard.
