Installs...
Hey all
Wondering if any of you more experienced folks would mind posting up some pictures of your Q500 installs? I've heard that some put the tank on the CG - is this a widespread practice? Many thanks Z |
RE: Installs...
1 Attachment(s)
Here are three quick pictures. I set my seekers and vortex's up the same. Elevator, throttle servo, and switch behind the wing. Battery and receiver mounted with velcro between the rear former and the tank, depending on balance. I don't completely put my tanks on the CG, although many people do. Mine center about an inch in front of the C.G. One of the pictures is a Neme-Q+, servos in front of the wing since there is no hatch. The nose is slightly shorter on the Neme to offset the CG of having the servos in front of the wing.
RE: Installs...
1 Attachment(s)
Here is a picture of the servos/switch behind the wing. Notice the Fly Fishing line used as a pull on/off switch. Helps reduce vibration to the switch in flight.
RE: Installs...
1 Attachment(s)
The picture shows it all, complete with fishing line switch. I put marks on the balance point and tank to check for movement.
Ed S |
RE: Installs...
ORIGINAL: Ed Smith The picture shows it all, complete with fishing line switch. I put marks on the balance point and tank to check for movement. Ed S |
RE: Installs...
In the fuselage, Hi-Tech HS-85BB
Ed S |
