Quadra-Aerrow Engines Get direct support for you Quadra-Aerrow Engines here!
Quadra 75 or 65 leaking fuel out the carb
Reply
Old 10-31-2010, 05:23 PM
rcpilot_971
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Quadra 75 or 65 leaking fuel out the carb
I have a quadra I beleave its a 65 was told by the preson that sold it to me it was a 75 but it only has a 22-10 prop on it and will swing it at 6900rpms. so I think its a 65. anyway fuel is leaking out the carb at idle and up to all most 1/2 throttle. my plane looks like a it has a nitro motor on it from the mess it makes lol. anyone know what to do about this the motor its pretty new but an older motor less than 2 gallons ran through it. seems to run ok I did try to lean it out on the low end but then it would not run keep dying on me. right now it has good transition from mid to high throttle.
where can I find a manual for this motor
rcpilot_971 is offline
Old 10-31-2010, 08:01 PM
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Quadra 75 or 65 leaking fuel out the carb
Possibly trash under the needle and seat in the metering valve of the carb
w8ye is offline
Old 10-31-2010, 08:05 PM
rcpilot_971
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
how do I get to that to clean it out
Thanks Tim
Old 10-31-2010, 09:14 PM
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You have disassemble the carb on the steel cover side.
Pay extreme attention to exactly how everything is put together.
There is a rubber diaphragm
a pivot arm
a needle
and it's seat
It is probably best that you install a carb rebuild kit in the carb while you are at it. You can get one at a chainsaw dealer. take your carb in to him.
The chainsaw guy can fix the carb for you might be better for you?
w8ye is offline
Old 11-15-2010, 08:10 PM
Kimhoff
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What is the serial number of the engine?  What numbers are on the cylinder?
Kimhoff is offline
Old 11-15-2010, 08:18 PM
rcpilot_971
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
76016XL
Old 04-24-2011, 07:26 PM
Bashfulbob
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If your still looking for a manual for your engine, I found one that covers 30 - 100 at this link. http://www.dieselrc.com/download/aerrow_quadra.pdf
Hope it helps
Bashfulbob is offline
Old 04-24-2011, 07:34 PM
rcpilot_971
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks I sold it to a buddy of mine I will pass along the info
Thanks Tim
Reply
Display Modes
