Quadra 42 what spark plug to use
Older motor that has the rcexl ignition.
It's a small plug.
Plug recoomendations for this motor please !
Going on a ultraspadstik build.
Getting close to mounting engine as soon as the fuel tank arrives.
What plugs are you guys using, I plan on trying a 20x8 prop and an 18x8 prop on it.
Also on the ignition battery, rcexl says to use a 4.8v 800 to 1200 mah battery.
I found a 1100 mah at onlybatteries.com thatis priced pretty good.
It's a small plug.
RE: Quadra 42 what spark plug to use
The plug is Denso U20M-U.
I've never seen one of these.
I'm concerned the ignition plug cap might not work with
a diffrent head.
I called Bennett Built today and Mr. Bennett is out of the store until February 21.
And I'm getting close to finishing the SPAD and I sure would like to fly
it before then, and also would like to put a new plug in the motor since it has
been sitting for awhile.
a diffrent head.
