Quadra-Aerrow Engines Get direct support for you Quadra-Aerrow Engines here!
Quadra 52 kill-switch question
Reply
Old 04-21-2012, 12:45 PM
Neuhausr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Quadra 52 kill-switch question
I have a magneto driven Quadra 52 and I am thinking that it should have a kill switch as an added safety feature. Can someone recommend a particular type? best installation? etc?
thanks
Neuhausr is offline
Old 04-21-2012, 01:43 PM
w8ye
Moderator
w8ye's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Quadra 52 kill-switch question
There should be a spade connector sticking up from you ignition coil. If this connector is connected to the engine crankcase with a wire - your ignition will not work.
Therefore, to connect a switched wire to this spade connector on the coil with the wire on the other side of the switch connected to the crankcase is what you want.
Tower sells one somewhat like this but it also has a micro switch that can be closed with a servo arm. I don't know if that was what you were talking about or not?
http://www3.towerhobbies.com/cgi-bin...&I=LXJ776&P=ML
w8ye is offline
Old 04-24-2012, 07:07 PM
Neuhausr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
W8ye,
Thanks for the information. That is exactly what I was looking for.
Neuhausr is offline
Reply
Display Modes
