Q-75 Exhaust Port
GA
Q-75 Exhaust Port
I have a Q-75B with the rear exhaust port. Is there a way to (safely) turn the cylinder head 90 degrees so that it will port from the side? The muffler interferes with the firewall with the present set up.
Thanx
Thanx
PA
RE: Q-75 Exhaust Port
You can ubsoltely turn the cylinder. Turn it to the opposite of the reed induction.
Usually a lot of people like the rear exhaust in order to mount a pitts-style muffler on it.
Hope this helps.
Kindest regards,
Hanspeter Naef
Hope this helps.
Kindest regards,
Hanspeter Naef
PA
Actually it is not possible without modification.
If you still want to do it, please contact me and I will let you know, what you would have to modify.
