Quadra 42 in Byron P51 -Ignition Help required
1 Post
Hi guys
I'm finding my Q42 very hard to start and I see that Dick Bennet has a Engine Points Eliminator listed.
Has anyone tried these out ?
Also How do you get the magneto fly wheel off to get the points.?
Any help would be great
Alan
Alan
My Feedback: (16)
RE: Quadra 42 in Byron P51 -Ignition Help required
You may have a seal problem and not actually anything wrong with the ignition.
If the rear seal is bad, fuel will not be pumped by the carb, or drawn into the crankcase or forced up into the combustion chamber very well. If you prime directly into the combustion chamber the engine will pop or maybe even go through three or four cycle but will never continuously run.
Test your spark on a plug outside the combustion chamber first.
1 Post
W8ye
Thanks for the tip ....I've checked all seals and they seem fine but I will have another look.
I assume the points have an advance/retard mechanism (similar to an auto ignition distributor), I think they may be getting stuck in the full advance position as the engine runs at over half to full throttle but stalls down low or runs very rough.
The carb is new and the needles set at 1 1/2 turns as per the manual
The engine has plenty of compression and a strong spark but want start until it get really warm/hot.
Any idea on how to remove the magneto flywheel to get to the points to check if they are Ok ??
I'll also try and find a full seal kit
cheers
Alan
cheers
Alan
My Feedback: (16)
The timing is fixed at 26-28 degrees. It doesn't move.
To pull the flywheel, you will need a flywheel puller. They are available at the better auto parts stores.
If you are getting a strong spark, there is nothing wrong with your points or coil.
Does your carburetor pump fuel? You may have the crankcase pressure route to the carburetor blocked?
PA
Dear US41 user,
In case your points are not good anymore.
You can change the ignition to a normal US41 ignition setup with a new flywheel and a normal ignition module.
All US41 paerts are in stock. Please contact USQ AERO, inc. under [email protected] check out our home page www.usqaero.com
Best of luck,
Hanspeter Naef
Best of luck,
Hanspeter Naef
1 Post
Hey Guys
I just received the Dick Bennet transistor ignition module to retrofit to my Q42...........have anyone out there tried this setup ??
cheers
Alan
cheers
Alan
can you help....i have a byron p51 i am restoring and i can not get the engine to start...i prime it and it acts like it will start but then it dies...and solutions???
