RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Quadra-Aerrow Engines (http://www.rcuniverse.com/forum/quadra-aerrow-engines-312/)
-   -   Quadr engine... what size? (http://www.rcuniverse.com/forum/quadra-aerrow-engines-312/9512401-quadr-engine-what-size.html)
miklos 02-17-2010 02:35 PM
1 Attachment(s)
I have a Quadra engine in a Byron P-51 that I recently acquired. How can I tell what size engine it is. What should I look for?
Thanks.
51er 02-18-2010 12:19 AM
RE: Quadr engine... what size?
:eek: If I'm correct, it should be either a Q35 or a Q42.
Iflyglow 03-25-2010 12:57 AM
Call B&B specilty's, but here is a quick tip. Older (points type) 35cc and 40cc engine looked the same, but you can look into the exhaust port and count the rings on the piston. 1 ring = 35cc, 2 rings = 40cc. The newer 40cc has 1 ring.:D i would be willing to bet that you have a Q35 in it, because that's what was in them for the first few years.:D Is is a 1 piece or 2 piece wing?
leadgofer 10-23-2012 12:15 PM
Same question. Recently aquired Byron P51. 3rd year production? 1 piece wing. How do I identify the engine without tearing it down & measuring.
